Old 06-03-2012, 06:10 AM   #5131
hoadie72
Oddometer: 74
Originally Posted by Kannonball8 View Post
But the shutting down the engine thing is what bugs me, maybe you can save a small amount of fuel, but, what about wear on the starter and battery? I start my car in the morning and drive 12 miles to work, I have the possibility of getting stopped at 4 traffic lights during my drive. This could give me a total of 5 starts each way or 10 per day instead of 2 per day. If I only use the vehicle to go to work and I work 240 days per year, I'm starting the vehicle 2160 extra times a year. You can't tell me I'm going to save enough gas to cover the starters and batteries (and maybe ignition switches) I'll use up. (or am I completely wrong?)
Bruce
Those tiny savings across an hour or two's commute per day per week per year add up to considerbale savings.
As for additional load on your battery and starter - if your engine is warm and is maintained there is insignificant wear and load on your battery.
You're obviously not aware that most car manufacturers these days have cars who's engines automatically stop and restart in traffic. These engines are fitted to more or less regular petrol and diesel cars (ie not just hybrids). It helps give them the edge with fuel economony and while I haven't tried it, reviews I've read have said that it works flawlessly - well in premium brands anyway.
hoadie72 is offline   Reply With Quote
Old 06-03-2012, 06:13 AM   #5132
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,509
Originally Posted by slide View Post
Those accelerator pumps didn't have temp sensors to shut them down?
It sounds like you have no idea what an accelerator pump is.
It was something inside the carburetor that squirted extra fuel into the intakes every time you opened the throttle. It was there to make up for the air being able to speed up more quickly than the fuel and helped keep the air/fuel mixture more correct. Usually it was either a plunger (think of a syringe) or a rubber diaphragm. It was 100% mechanical, so no temperature sensors involved. As far as I know, the ONLY temperature sensor of any sort used in American engines in the 50's and 60's was the cooling system thermostat that regulated how much water went to the radiator.
Old 06-03-2012, 06:57 AM   #5133
Tip Over
Whoopsie!
Tip Over's Avatar
Oddometer: 1,027
Those cars that have the auto shut-off, that are not hybrids, have huge heavy duty starters. Hybrids don't use their starter motor unless their battery pack is drained. It's all the electric motor's doing (pretty trick stuff).
On a normal car, even when warm, if you are constantly starting and stopping it, you will wear that starter motor out much faster then normal.
Tip Over is offline   Reply With Quote
Old 06-03-2012, 07:18 AM   #5134
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
** than **
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 06-03-2012, 09:19 AM   #5135
Thanantos
Ride hard.
Thanantos's Avatar
Oddometer: 3,690
Originally Posted by DAKEZ View Post
** than **
You rang?
2013 V-Strom
Thanantos is offline   Reply With Quote
Old 06-03-2012, 11:28 AM   #5136
Tip Over
Whoopsie!
Tip Over's Avatar
Oddometer: 1,027
** than **
Old 06-03-2012, 04:37 PM   #5137
hoadie72
Oddometer: 74
Let's put this in perspective. A typical family might start and stop their car engine 20 times over a weekend and god knows how many times during the week. That starter motor will last 20+ years. So starting and stopping it during a few times during a commute isn't going to make a lot of difference.
Old 06-03-2012, 04:53 PM   #5138
eepeqez
eepeqez's Avatar
Oddometer: 2,068
The average trip length for urban vehicles is something like 10km/6miles; the average traffic light interval is probably more like 0.5km/0.3miles. Restarting at every second traffic light instead of just once per trip has the potential to reduce the life of starter motors and ring gears by a factor of ten, bringing your hypothetical 20 year starter life back to just 2 years.
Automated engine off and restart at stops in traffic lights has only become viable with larger batteries and starters.
eepeqez is offline   Reply With Quote
Old 06-03-2012, 05:05 PM   #5139
Chromer
Not going gentle
Chromer's Avatar
Oddometer: 886
Mazda has a system for their direct-injection engines that doesn't require using the starter motor at all. The engine is stopped with a piston just past TDC ready for the power stroke. To restart, fuel is injected and sparked. Off you go.
To be fair, idling a modern 4-banger for an hour uses a ridiculously small amount of fuel. You'd have a bigger benefit from reducing aero drag by slapping on an underbody tray or finding a way to take 100lbs out somewhere.
Rage, rage against the dying of the light.
Chromer is offline   Reply With Quote
Old 06-03-2012, 05:16 PM   #5140
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,941
Remember when we used to talk about stupid questions people ask you when stopped? Those were the days.
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 06-03-2012, 05:21 PM   #5141
Tip Over
Whoopsie!
Tip Over's Avatar
Oddometer: 1,027
"Hey, I heard goldwings have air conditioning, so why are you complaining about how hot it is"?
Yeah. 96 degrees. Stuck in traffic, and my phone crashed because of the heat, leaving me with no music.
Also, I was almost late for school.
Old 06-03-2012, 05:24 PM   #5142
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Back to the headlights-off question. Any inmates from S. America know if it's still done?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 06-05-2012, 09:43 AM   #5143
Wingfixer
Watch this...
Wingfixer's Avatar
Oddometer: 3,751
I'm just spit-balling here but older cars had generators instead of todays modern alternators, generators will not make sufficient amps at low rpm, idle, to power the lights so the battery is getting drained at idle. Also, generators need a little voltage to "excite" them into working, produce amperage. So, if the battery gets too dead the generator won't come back on line. This would be worse on older, less maintained vehicles.
And, to get back on track.....
While putting my helmet on outside of an Autozone the other day...
Mullet head: (Looks up at storm clouds) Looks like it going to rain.
ME: (Looking up at storm clouds) Yup.
MH: I hope you not going too far.
ME: Baltimore, home, about 130 miles. (No, I did not ride 130 miles to get to the Autozone, its conveniently near my parents house)
MH: Whatcha gonna do when it rains?
ME: Get wet. It happens.
MH: I never ride in the rain, heck, my Harley has never had a drop of rain onnit.
ME: Ah, well, have a nice day!
Just another DAMN rider
Wingfixer is offline   Reply With Quote
Old 06-05-2012, 07:44 PM   #5144
Iowegian
Iowegian's Avatar
Oddometer: 9
That phenomenon is not exclusive to bikes. I had a lady ask me once if I knew "George", because he was in the Air Force.
She didn't know his last name, what he worked as, what squadron he was in, or if he was even at my base anymore. She just thought that I would know.
When I was in the army and asked "do you know John, he is in the 82nd Airborne too?", I would say "Yeah, bummer about his leg." then walk away.
When in Danger or in Doubt, Run in Circles, Scream and Shout.
Iowegian is offline   Reply With Quote
Old 06-06-2012, 01:29 PM   #5145
JGNC
JGNC's Avatar
Oddometer: 395
Some fat old guy wearing a novelty helmet, homemade v-neck sleeveless shirt, 90's swimming trunks, and flip flops said to me, "Do you have any idea how fucking stupid you look with all that shit on?"
Watched a guy on a Harley do a 25ft diameter u-turn in a gas station parking lot then waddle the bike the last 15ft to the pumps. He walked over to my DRZ and inquired when I was going to get a real man's bike in a nasty tone. I asked him when he was planning on learning to ride his.
JGNC is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
