Old 05-08-2012, 07:49 PM   #106
Conedodger
Wanna Ride
Conedodger's Avatar
Oddometer: 324
Originally Posted by frogy View Post
$650 for that?Was that at the same time while pointing a gun at him? Nice buy,and I bet the wind drag on the lift gate is pretty high.
It was a bargain! I'm tempted to see if I can make a folding ramp like the new ones.
Conedodger is offline   Reply With Quote
Old 05-09-2012, 03:51 PM   #107
frogy OP
frogy's Avatar
Oddometer: 811
Nice idea,kinda hard to get good gas milage with a barn door hangin in the wind.
frogy is online now   Reply With Quote
Old 06-03-2012, 02:29 PM   #108
OldNewRider
OldNewRider's Avatar
Oddometer: 18
I just picked a similar trailer and noticed that the indicated fuel consumption of my VW TDi wagon doubled and that was with the trailer empty! I could actually feel the wind resistance from the ramp at highway speeds. So, I'm going to have to find a solution to that as it could get quite expensive towing the thing. Might be possible to have the ramp modified to fold like the new models but not sure how that might be done. Will also try to get a price on a newer bi-fold ramp as well to see if that makes sense.
Any ideas most welcome!
OldNewRider is offline   Reply With Quote
Old 06-03-2012, 04:45 PM   #109
frogy OP
frogy's Avatar
Oddometer: 811
Why cant they put a shelf under the trailer?Take the ramp off and slide it into the shelf.
Old 06-03-2012, 05:18 PM   #110
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,866
Those ramps, mesh or solid create a tom of drag. Find a way to slide it in, or fold it down.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 06-03-2012, 05:22 PM   #111
high dangler
high dangler's Avatar
Oddometer: 535
why would a trailor need such a big wide ramp for hauling bikes ?
rompin stompin tiger 800 XC rider
high dangler is offline   Reply With Quote
Old 06-04-2012, 05:34 AM   #112
GH41
Oddometer: 822
I would expect the mileage to fall pulling a trailer behind a VW wagon or any other small car. Pulling my loaded trailer behind my F150 hardly affects my mpg. Before I spent anything modifying the ramp I would take the ramp off and do a test run without it. GH
GH41 is offline   Reply With Quote
Old 06-04-2012, 05:41 AM   #113
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,458
I picked up one of these for $650 used a few years ago. Very well built. Incredibly light. Light enough that I can pull it behind the lawn mower for yard work. Torsion suspension for smooth towing. Low deck height, coupled with ramp and chock, make for easy one person loading. I added removable sides and use it for other hauling as well. Works so well that I sold my truck and tow it behind a 4 cylinder car.]
This is exactly my experience with virtually the same trailer, including getting rid of the truck! I had the manufacturer remove the ramp, and instead, had aluminum rails welded on the underside to slide a pair of ramps under the deck and above the axle.
I later had a step welded at deck level on each side extending from the fender to the back, a surface area badly missed to put my foot when loading and unloading two bikes. I usually carry one bike, but can carry the F800GS and the R1200R and pull it all with a 5-cylinder Volvo wagon. Note that careful choice of tie-down locations before drilling or cutting is important.
Fred
FredRydr screwed with this post 06-04-2012 at 07:11 AM
FredRydr is offline   Reply With Quote
Old 06-04-2012, 05:58 AM   #114
OldNewRider
Oddometer: 18
Thanks folks, all great inputs! The more I think about it, the more I think just buying one of those tri-fold ramps might be the best way to go. Just take that huge ramp right off when trailering longer distances and use the portable one which should be easy to stow next to the bikes. These trailers are build for "universal" applications like landscapers, loading quads, mowers, etc. so that's why the wide ramp. Not needed for bikes. I also like the idea of having some racks welded underneath to hold removable ramps.
Old 06-04-2012, 06:03 AM   #115
OldNewRider
Oddometer: 18
Oh, and I've towed a similar trailer without a tailgate/ramp several times with the VW and barely even notice it's there. So I was pretty shocked when I tried this one with the ramp. Felt like I was dragging a parachute behind me when I got up to highway speed. Even had to shift down to 5th for slight hills to maintain speed. Yeah, that ramp has got to go :-)
Old 06-04-2012, 01:47 PM   #116
marine_mike
Oddometer: 315
I'm diggin that trailer, but like everyone else said...has to be able to fold that ramp down. I'm just going to pick up a 4x6 for my 2 enduros. Should be plenty strong and wide enough.
marine_mike is offline   Reply With Quote
Old 06-11-2012, 11:51 AM   #117
eye.surgeon
...riding California
eye.surgeon's Avatar
Oddometer: 221
I have this trailer set up for hauling bikes. It will hold two dirtbikes side by side, or one large street bike, with plenty of extra space for gear.
In this picture I was towing it with my Range Rover, but since then I bought an F150 and will probably get black widow extra long ramp and just use the bed of my truck for shorter trips.
2012 Ducati Multistrada
BMW K1200LT
eye.surgeon is offline   Reply With Quote
Old 06-11-2012, 02:34 PM   #118
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Aluma
I just picked up this 2009 Aluma 548 trailer (54" wide x 8' long bed) for $1K off the Denver CL. With the fixed ramp, two motorcycle chocks, and the spare tire and wheel it was worth it to me. It is much easier to use than the little 3-rail trailers as I can walk up it. I also have a much heavier all steel 5x8' trailer I use for heavier stuff but it's a pain to move around much. I think the Aluma's are a good value used. Weight is right at 320 pounds. I can uncouple it from the car and move it around with one hand. My wife can do it easily.
Second picture shows me with about 1000 pounds of bark mulch in bags on it (40 bags x 25 pounds). I just put a tarp and tie downs over it and called it good. Drove 50 miles into the mountains. No problems. Axle rating is 2000 pounds.
I think I'll remove the ramp for the most part when bike hauling and use one of the little folding units that can go in the back of the 4Runner as the ramp is kind big and I don't want to pay for a folding one. I am going to buy the Aluma solid side rack set as my trailer has stake pockets so you can put sides all around for cargo hauling.
With the "solid side kit" it will look like the trailer in the link below.
http://www.alumaklm.com/single-axle-...y-trailer.html
Tom
Infracaninophile screwed with this post 06-11-2012 at 03:00 PM
Infracaninophile is offline   Reply With Quote
Old 06-11-2012, 04:51 PM   #119
frogy OP
frogy's Avatar
Oddometer: 811
Aluma
Nice trailer
Old 06-11-2012, 05:08 PM   #120
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,203
I have a truck and I am still looking into this idea, albeit a bit bigger. Enough for three big bikes and roo for a queen bed in a loft up fron with two couches that turn into beds. Last DV trip 60+ mph winds.
I like the closed trailer for the protection from thieves. I don't have to worry about the bikes being visible and if the trailer looks scruffy with NO bike stickers on it that much better.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Times are GMT -7.   It's 06:33 AM.
