06-04-2012, 09:29 PM
#151 | |
Syndicated
Oddometer: 11,286
07-02-2012, 01:09 PM
#152 |
Oddometer: 187
A new question in an old thread....
Would the "waterless" hand cleaner goop that comes in small tubs be OK to use as a bead lubricant? Looks to me like it's almost identical to the tire bead paste they sell for a whole lot more. EDIT: The term "waterless" is misleading. Waterless refers to using it to clean hands without the use of water. The main ingredient on the can is water, but it also contains petroleum distillates, nonoxynol-6 (anti-bacterial, I think), triethanol amine, carbomer, magnesium aluminum silicate, and lanolin. Basically, a gelatinous soap...
Some people will tell you that slow is good, and it may be on some days, but I am here to tell you that fast is better... Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S Thompson, Song of the Sausage Creature Badjuju screwed with this post 07-02-2012 at 01:18 PM |
07-02-2012, 02:14 PM
#153 |
Rides slow bike slow
Oddometer: 9,543
So...the consensus so far is that this really works, eh? I can have tires mounted for $20...is it worth doing it this way?
You couldn't hear a dump truck driving through a nitro glycerin plant!Cobbie Award Winner |
07-02-2012, 02:22 PM
#154 |
Oddometer: 2,536
looks pretty neat
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
07-03-2012, 06:38 AM
#155 | ||
Oddometer: 1,108
For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move. Robert Louis Stevenson |
07-22-2012, 04:09 PM
#156 |
Oddometer: 172
I have an even better trick. If I remove the wheel, any of the local tire shops will swap tires for two bucks. Being the super nice guy that I am, I generally tip another fifty cents.
If I drive the bike to a dealer and buy new tires, they do the entire job (front and rear) for $15 |
08-17-2012, 01:07 AM
#157 |
Oddometer: 9
Ive got to put a big
in for this Poolside.. I just put a rear Kenda 761 (tubed) on trying this..a combination of a b@@%%d head cold, general haste, and a few shots of vodka to help me a long and I with a fair amount of struggling got it on...backwards![]() Spooning it off I'm convinced its the stiffest sidewall that Ive ever had the misfortune to encounter. Round 2 and a bit more lube, taking my time and it just literately slid on to the rim ..couldn't believe it.. Cheers! |
09-01-2012, 07:14 PM
#158 |
Oddometer: 462
Thanks very much! tried this for the first time today and it worked great, mounted a 150/70 tire with a tube very easily, Rather than lashing straps I used six 24" cable ties and they worked great, got a bag of 8 for $5- FWIW they can be reused too, it is easy to lift the locking tab with a small screwdriver and undo them. Bought a gallon of Ruglyde from Napa per suggestions here and it does seem better than straight soapy water...the tire went on so easily I probably could have not used lubricant but like to anyway since it makes the bead seat much easier.
victor441 screwed with this post 09-01-2012 at 08:23 PM |
09-03-2012, 01:03 AM
#159 |
Syndicated
Oddometer: 11,286
Boy, I haven't checked in here for a while. Thanks for the kudos folks! I'm glad many of you found this tire mounting method useful. Cheers! |
09-03-2012, 10:35 AM
#160 |
Knee deep in snow.
Oddometer: 474
I'm no expert, I've probably changed 10 tires in my few years with a motorcycle. But I on average pinch 1 tube for every other tire I change. The cost adds up quick, especially when I was 23, newly married and the only one working. I wish I knew about this trick years ago!
09-03-2012, 10:36 AM
#161 |
Knee deep in snow.
Oddometer: 474
Did I mention I ride a KLR! I am not as cheap as a lot of other people I meet on the road with them, but pinching a tube is a biuzzkill.
09-03-2012, 10:51 AM
#162 |
Knee deep in snow.
Oddometer: 474
I still feel the need to defend myself.
The last tire I tried to mount was a Duro 904. I wrestled with it for an hour, pinching two tubes in the process. I realized I was in over my head, so I brought it in to the motorcycle shop down the road. The guy working has been a mechanic for 10+ years, we are on a first name basis since I've brought my bike there for other things/see him around Milwaukee for different motorcycle events. We were talking as he put the tire on, I saw him pinch 3 tubes! It scared the shit out of me. But the walls were so stiff! I was hoping I was doing something wrong with my shitty studebaker tire irons. It makes me nervous to think I could be stranded somewhere and pinch the only spare tube I have on me. |
