Old 06-05-2012, 10:07 AM   #2341
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,226
Awesome job cyborg!
I'm totally going to copy that tool tube mounting position as it will solve many problems for me, thanks for posting.
I understand it's been covered here many times over, but I did manage to boil my gas on a 3000' technical climb last weekend and obviously need to do something about shielding the tank. The bike wouldn't start for 15 minutes and I could hear/feel the gas boiling... lots of pressure venting out of the tank. I ended up manually running the fan to help cool it off and it did start.
It also has me a little worried about my fuel pump, I'm going to check and see if I have the old version or not.... my bike doesn't start immediately all the time, sometimes I have to turn the key on and off to get it to start while on the trail after I either kill the motor or turn the handlebar switch off.
Hiking out from where I was late in the day would have been bad, I hate hiking in MC boots....
What's the latest greatest heat shield stuff to use? I remember reading somewhere about the precut berg specific blankets coming apart or something not good.... what's the cheapest product to help with the heat under there that's lasting for people?
Also, here's my oil analysis I sent in with 1000 miles on it, 3800 miles on the bike at the time. I'll be sending in another sample soon as I put a lot of miles on the bike last weekend so we'll see how that one goes
And a couple of photos for good measure.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider screwed with this post 06-05-2012 at 10:18 AM
Lost Rider is offline   Reply With Quote
Old 06-05-2012, 11:23 AM   #2342
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 200
Regarding fuel tank insulation:
Here's what I used: http://www.ktm-parts.com/07010521.html
The install (once you've got the tank off) is a little time consuming but it fits real good and saves a LOT of time trying to make a template yourself. I've had no issues with it tearing or coming loose. I installed it while I was adding the fan kit and cleaning out the tank when the bike was new. I've had the tank off once since. When I need to remove the tank I disconnect the right radiator and swing it and the fan fwd to make removing the fuel tank a non-issue.
Love your photos !!!
R1
Husqvarna FE250...Street Legal
Rider1 is offline   Reply With Quote
Old 06-05-2012, 02:14 PM   #2343
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,193
Thanks guys! Looks like the mirror thing got handled.
Here's a link for the Double-Take Mirror thread
http://advrider.com/forums/showthread.php?t=571500
and my mods to make the short RAM arms work better
http://advrider.com/forums/showpost....&postcount=368
and Ghost Mutant's post on making the long RAM arms work better
http://advrider.com/forums/showpost....&postcount=365
Lost, I used the DEI Reflect-A-GOLD Film and cut my own patterns, a bit tedious and I ran out of it so didn't cover everything, but got all of what I thought were hot spots. So far it is staying in place. That along with ceramic coating the pipe I think has really cut down on heat to the fuel. I also have gold foil on the area the fan blows on the tank, to help reduce heat transfer when the fan is running. I plan to finish covering the underside with Gold foil the next time I have the tank off.
Thanks for sharing the oil lab results, and the nice pix as well.
cyborg is offline   Reply With Quote
Old 06-05-2012, 09:00 PM   #2344
cyborg
cyborg's Avatar
Oddometer: 5,193
Ran across this seat vendor by chance when web surfing something else, anyone tried them?
I think they are like Seat Concepts in reworking your stock seat, and they sell their seat rework on eBay
http://www.fishersaddlebags.com/seats.html
For Husaberg
Old 06-05-2012, 09:15 PM   #2345
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,226
thanks cyborg!
By chance what size kit did you buy?.... so I know to get the next larger one if I go that route!
#010391 - 12 x 12 sheet, $20.52
#010392 - 12 x 24 sheet, $35.64
#010393 - 24 x 24 sheet, $65.88
#010394 - 1-1/2 x 15 roll, $33.75
#010395 - 1-1/2 x 30 roll, $62.09
#010396 - 2 x 15 roll, $43.19
#010397 - 2 x 30 roll, $80.99
LostRider.com
Old 06-05-2012, 09:29 PM   #2346
cyborg
cyborg's Avatar
Oddometer: 5,193
Originally Posted by Lost Rider View Post
thanks cyborg!
#010391 - 12” x 12” sheet, $20.52
#010392 - 12” x 24” sheet, $35.64
#010393 - 24” x 24” sheet, $65.88
#010394 - 1-1/2” x 15’ roll, $33.75
#010395 - 1-1/2” x 30’ roll, $62.09
#010396 - 2” x 15’ roll, $43.19
#010397 - 2” x 30’ roll, $80.99
My best guess is the #010393 - 24” x 24” sheet, $65.88 should do the whole thing if patterns carefully planned. My patterns were disposable and didn't survive the job.
That gold stuff does seem to cut heat well. I use it on my KTM990, under seat and sidepanels to cut heat on rider and passenger, and on certain areas on the fuel tanks near the exhaust header. The DEI stuff has been sticking since 2007 and 35K miles so far, all weather and temps. Used it on my 990 airbox too, has held up to engine temps for years and going strong.
Old 06-06-2012, 09:21 AM   #2347
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 378
The 24" x 24" is the same price as the CV4 kit just FYI that that is an option.
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is offline   Reply With Quote
Old 06-06-2012, 09:24 AM   #2348
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,226
I see that, makes it harder to decide.
I think it was LukasM that said his CV4 blanket had shredded or something like that, as why I'm researching a little more.
Maybe he will see this and can comment.
I do understand it's been discussed, but things change.... thank you for the ongoing discussion!
LostRider.com
Old 06-06-2012, 10:28 AM   #2349
Navin
Navin's Avatar
Oddometer: 7,828
Mine has shredded in the area of the fan from removing the tank, even after pushing the radiator forward. There just isn't enough room on this bike, 20lbs of crap in a 5lbs bag.
Navin is offline   Reply With Quote
Old 06-06-2012, 10:51 AM   #2350
JayG
Oddometer: 2
BRP rubber submount
Cyborg,
I have a 570 and have been thinking about getting the BRP rubber submount for the Scotts stabilizer but have not seen any reviews. Have you ridden it enough to say whether it significantly reduces vibration or hack and whether it is comparable to Flexx bars? I am actually thinking of using both the rubber submount and Flexx bars but would be happy to just use the submount and save a few $'s.
Thanks for any input
JayG is offline   Reply With Quote
Old 06-06-2012, 11:51 AM   #2351
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,300
For Husaberg
I haven't but have been eyeing them for months !
Let us know how you like it if you go that route.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Old 06-06-2012, 12:13 PM   #2352
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,109
I personally know 2 guys who have the Fisher seats on their Bergs, and one guy who has the seat on his '11 GG EC300, and they are all happy customers. Price is about the same as the Seat Concepts if you send the seat out for the labor. The SC uses an all new cover, whereas the Fisher adds material to the stock cover.
Mark
'11 KTM 250 XC (dual sported)
'05 KTM 450 EXC (dual sported)
OhioPT is online now   Reply With Quote
Old 06-06-2012, 12:52 PM   #2353
ram1000
ram1000's Avatar
Oddometer: 1,833
Can the 390 Berg be licensed in Oregon? The closest dealer in Boise didn't know. He says the 570 comes complete but the 390 has to have signals and stuff added.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 06-07-2012, 06:41 AM   #2354
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Spent a few days of high altitude exploring this past weekend in the Rockies near Taos, NM.
I was anxious to test my 390 above 10,000 ft. elevation, see how it performed. Made it past 12,000 ft a good bit.
Its a bit risky to explore so far into the wilderness completely unsupported......but I like it. A real free feeling!
Was not without some tension.....like when I got swallowed by this cloud as it passed over me. I stopped, dismounted, and threw a rock up into it, as soared by me. But, I never saw the rock come back down! I kid you not. That was weird.
Found my new campsite way above the bug line:
Now....about the performance:
My 390 definitely felt down on power compared to Rancho Highfive at 700 ft. elevation. That was somewhat expected, even with the fuel injection. However, I still had plenty of power to do the job any way I pleased.....when the bike was running. But I can sure see why the Rocky residents would opt for the 570 instead.
LOST....listen up! First day out, my bike would not restart after shutting off. This began occurring after some lengthy...heated....long steep climbs. Felt like it was flooding out (at first). Then, maybe starving of fuel....I donno. After dinking around with it staring....probing...wiggling.....praying, she restarted and seem to run fine. Until the next time I shut it off. Repeat same scenario....over and over. Seemed it would restart after about 15 minutes of rest (and cooling). Sound familiar?
I incubated on this problem in my hammock overnight. Then, had my "Ah-Ha" moment. I took off the gas cap, turned it over, disassembled, and removed the stainless steel "check ball" in the vent. I know.....I know....many have said to "take that thingy out of there pronto". Well, I had never had a problem with it at home (below 1,000 ft. above sea level). I typically don't mess with something until it causes a problem.
Guess what? THEY were right. Remove and throw that little ball bearing as far away as you can. And, just stop falling down.....no more worries.
Here's the deal: At high altitude, under heavy work, the fuel was boiling (even with the CYBORG DEI mod on my tank). Apparently, the excess vapor was pressurizing the tank enough to lift that steel ball bearing and block the hole. The tank appeared to be vapor locking and/or over-pressuring which was definitely affecting the fuel flow/pumping action. Either the bike was starving of fuel or flooding with fuel.....it was hard to tell, exactly. I think starving.
After removing this check-ball, the problem was completely solved! I never had the issue reoccur....even during periods when I could hear the fuel boiling furiously inside my tank (upon shutting the bike off). This...when above 12,000 ft. It would fire right back up, on demand, every time.
The symptoms appeared to be clogged fuel injector.....clogged fuel line/filter.....failing fuel pump, when in reality, it was simply locking up the tank vent.
So, my question to LOST is: Have you removed the check-ball in your fuel tank cap?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 06-07-2012, 08:51 AM   #2355
cyborg
cyborg's Avatar
Oddometer: 5,193
Good report HF, and nice pix!
The DEI is not magic, but it helps probably as well as the blanket and it's thinnner, takes less room and won't fall apart from taking tank on and off. After I ceramic coated the pipe, I have not heard any boiling of fuel at all even in slow, 1st & 2nd gear uphill rough climbing at 8-9K elevation with the fan running almost continuously. Of course my 390 has no fuel venting problems because of the 70degree sub tank. It has it's own large vent that also helps the main tank in odd pressure/vacuum situations. LOST has the subtank too IIRC so should not have that problem.
Times are GMT -7.   It's 04:48 AM.
