Old 06-06-2012, 06:40 PM   #1
KLRsys OP
KLRsys's Avatar
Oddometer: 131
KLRsys build
KLRsys = Versys powered KLR - two cylinder, fuel injected, six speed KLR.
I've been thinking about doing this swap ever since I saw a review on the Versys and they remarked how narrow the engine was for a 650 twin. I few years went by and I found myself with an extra KLR. Last fall I decided to seriously look into this and came across RepsolRider's Super Rio thread in this same forum. That's all I needed to see, within a week I had a donor bike in the garage and I got started. I'm not quite finished but I've ridden it a bit now and I'm very pleased with the results so far. It doesn't feel any heavier than my other KLR and it's a lot smoother and faster.
Couldn't leave well enough alone so I built another one. Link
And there's a third one in the works now. (it's done) Link
And we rode them all from Texas to Alaska and back.
More pictures
KLRsys screwed with this post 12-21-2013 at 10:14 PM
KLRsys is offline   Reply With Quote
Old 06-06-2012, 06:53 PM   #2
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 405
Good job. Looks like fun.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 06-06-2012, 06:59 PM   #3
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,498
get the heck outa here, you got it done?
tell us the whole story, more pics!
What were the hassles?
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 06-06-2012, 09:37 PM   #4
ktmklx
ktmklx's Avatar
Oddometer: 689
Very nice job, that looks like a fun project.
ktmklx is offline   Reply With Quote
Old 06-06-2012, 09:48 PM   #5
KLRsys OP
KLRsys's Avatar
Oddometer: 131
The biggest hassles were getting the throttle bodies hooked up to the original KLR airbox/filter, and dealing with the fuel pump. The TB's are normally aimed at the bottom of the tank where the airbox is on the Versys, closer to straight up, and of course the KLR airbox is under the seat. I flipped the TB's and manifolds upside down to get them to about a 45 degree angle, made a new bell crank for the cables and made a "box" to connect the TB's to the airbox. It's a very tight fit. The fuel pump was tank mounted and I couldn't put it in the KLR tank so I made a small tank for it and put it in the battery box along with the electronics (ECU, relay box, etc). Figuring out how to do a lot of it took far more time than actually getting it done. Getting the engine in and frame modified wasn't all that hard. I did have to get a real tubing bender though. The electrics were not bad, I used the complete wiring harness, electronics, switches and instruments from the Versys, so it all pretty much plugged in with just a few modifications.
Old 06-07-2012, 04:49 AM   #6
DRjoe
DRjoe's Avatar
Oddometer: 5,096
great job, looks factory
Old 06-07-2012, 02:01 PM   #7
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,797
Nice!
What scares me most with the KLR is the brakes and frame flex- I hope that you have some plans in that direction too?
Tsotsie is online now   Reply With Quote
Old 06-07-2012, 02:07 PM   #8
Unstable Rider
Fart and run
Oddometer: 2,498
WHY would you want to remove the fantastic frame flex?
I count on that for riding comfort!
My KLR would ride like a Harley if you fixed that.
~Butch Cassidy
Old 06-07-2012, 04:46 PM   #9
KLRsys OP
KLRsys's Avatar
Oddometer: 131
Originally Posted by Tsotsie View Post
Nice!
I really didn't do this for the extra power although more passing power is always welcome. I expect that 98% of the time I won't be riding it any harder than I did with the original motor so I'm not too concerned about additional frame flex. Plus the new lower frame is tied together in more points (8) than the original (4) and the front motor mounts are much wider than the original so it might even stiffen up the lower frame.
I used the front master cylinder off the Versys and it gives better feel to the front brake. I prefer a somewhat mushy front brake, easier for me modulate in the dirt. But I have boiled the fluid in the rear brake before, coming down a mountain once so I may upgrade anyway to prevent that sort of thing from happening.
Old 06-07-2012, 04:54 PM   #10
pilot815
pilot815's Avatar
Oddometer: 1,443
I just got this in an email from a local rider. Seems like we are in the same location. I would love to see this bike. Would you be interested in doing it on a 2009?
Check this link for more ADVriders in the area.
2009 KLR650
pilot815 screwed with this post 06-07-2012 at 05:07 PM
pilot815 is offline   Reply With Quote
Old 06-07-2012, 06:01 PM   #11
KLRsys OP
KLRsys's Avatar
Oddometer: 131
I don't think I'm up for doing this again, not exactly my line of work. I'll loan you my tubing bender though. I should be in Harlingen Sunday morning at the Ghostriders meet. Otherwise I'm in Brownsville, come by and see it.
Old 06-08-2012, 07:09 PM   #12
ohiofathead
Oddometer: 308
Man, that's clean! I really have to take a close look to tell it's not a stock KLR.
ohiofathead is offline   Reply With Quote
Old 06-09-2012, 12:35 PM   #13
LukasM
Oddometer: 5,415
Great work, quality craftsmanship makes it look like stock!
Old 06-09-2012, 10:11 PM   #14
elgato gordo
KTMRFS
elgato gordo's Avatar
Oddometer: 510
Great looking bike. Sure would like to see some more details about the build. Got any pics of her nekid.
elgato gordo is offline   Reply With Quote
Old 06-09-2012, 10:28 PM   #15
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,506
That's a clean install. Well done.
Times are GMT -7.   It's 12:38 PM.
