Old 06-07-2012, 08:45 AM   #2356
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,310
Originally Posted by ram1000 View Post
Can the 390 Berg be licensed in Oregon? The closest dealer in Boise didn't know. He says the 570 comes complete but the 390 has to have signals and stuff added.
Check with Rick Bozarth at (503) 255-8971. He's the Berg specialist in Portland, and I'm sure can fill you in on plating the 390.
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 06-07-2012, 09:07 AM   #2357
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,238
Originally Posted by Florida Lime View Post
I haven't but have been eyeing them for months !
Let us know how you like it if you go that route.
I have a Renazco and pretty happy with that, but I thought I'd toss out the seat link since I spotted it and it looked pretty good.
cyborg is offline   Reply With Quote
Old 06-07-2012, 08:28 PM   #2358
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,745
Originally Posted by cyborg View Post
Good report HF, and nice pix!
LOST has the subtank too IIRC so should not have that problem.
Ok.....could it be possible he has a pinched, kinked, or blocked vent hose? His symptoms appear to be very similar to mine. Just a thought.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 06-07-2012, 08:41 PM   #2359
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,431
I also wanted a higher bar position and a bit more dampening of the bars for my wrists but didn't want to use Flexx bars this time. I spotted a new shock absorber mount from BRP so I got this bundle and installed it, along with the BRP Hand Guard Mounts, which weigh the same as the Cycra clamps and bar clamps they replace, but more rugged.
cyborg - could you show a photo of the submount set-up from directly above the triple clamp, and of one directly in line with the top of the adjustment knobs ?
I have the HDB handguard set-up now, and was curious of the clearances to see if I could keep the HDB top clamp AND run the same "bundle".
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime screwed with this post 06-08-2012 at 09:47 PM Reason: cleaned up
Florida Lime is offline   Reply With Quote
Old 06-07-2012, 09:25 PM   #2360
cyborg
cyborg's Avatar
Oddometer: 5,238
Originally Posted by JayG View Post
Cyborg,
I have a 570 and have been thinking about getting the BRP rubber submount for the Scotts stabilizer but have not seen any reviews. Have you ridden it enough to say whether it significantly reduces vibration or hack and whether it is comparable to Flexx bars? I am actually thinking of using both the rubber submount and Flexx bars but would be happy to just use the submount and save a few $'s.
Thanks for any input
JayG, just put it on and haven't put it to the real test yet. I plan to go riding offroad this weekend so I should know after that. I've owned Flexx bars before and they are very nice but bulky. I don't expect to get quite as much shock absorption from the BRP setup, but not sure about that yet until I try it.
Florida Lime, do these pictures help?
Old 06-07-2012, 09:48 PM   #2361
ffr2370
ffr2370's Avatar
Oddometer: 131
I added the poly mount from BRP. Seems to soften the sharp Zing you feel when hitting sharp edges or rocks. The pain in my forearms and numbness in my hands is better, but it is still more of an issue than I have had with other bikes. As mentioned it uses the rear mount hole location on the TC, not the direction I wanted to go for standing comfort but not too big a problem.
ffr2370 is offline   Reply With Quote
Old 06-07-2012, 09:58 PM   #2362
ffr2370
ffr2370's Avatar
Oddometer: 131
Originally Posted by HighFive View Post
Spent a few days of high altitude exploring this past weekend in the Rockies near Taos, NM.
I was anxious to test my 390 above 10,000 ft. elevation, see how it performed. Made it past 12,000 ft a good bit.
Its a bit risky to explore so far into the wilderness completely unsupported......but I like it. A real free feeling!
Was not without some tension.....like when I got swallowed by this cloud as it passed over me. I stopped, dismounted, and threw a rock up into it, as soared by me. But, I never saw the rock come back down! I kid you not. That was weird.
Found my new campsite way above the bug line:
Now....about the performance:
My 390 definitely felt down on power compared to Rancho Highfive at 700 ft. elevation. That was somewhat expected, even with the fuel injection. However, I still had plenty of power to do the job any way I pleased.....when the bike was running. But I can sure see why the Rocky residents would opt for the 570 instead.
LOST....listen up! First day out, my bike would not restart after shutting off. This began occurring after some lengthy...heated....long steep climbs. Felt like it was flooding out (at first). Then, maybe starving of fuel....I donno. After dinking around with it staring....probing...wiggling.....praying, she restarted and seem to run fine. Until the next time I shut it off. Repeat same scenario....over and over. Seemed it would restart after about 15 minutes of rest (and cooling). Sound familiar?
I incubated on this problem in my hammock overnight. Then, had my "Ah-Ha" moment. I took off the gas cap, turned it over, disassembled, and removed the stainless steel "check ball" in the vent. I know.....I know....many have said to "take that thingy out of there pronto". Well, I had never had a problem with it at home (below 1,000 ft. above sea level). I typically don't mess with something until it causes a problem.
Guess what? THEY were right. Remove and throw that little ball bearing as far away as you can. And, just stop falling down.....no more worries.
Here's the deal: At high altitude, under heavy work, the fuel was boiling (even with the CYBORG DEI mod on my tank). Apparently, the excess vapor was pressurizing the tank enough to lift that steel ball bearing and block the hole. The tank appeared to be vapor locking and/or over-pressuring which was definitely affecting the fuel flow/pumping action. Either the bike was starving of fuel or flooding with fuel.....it was hard to tell, exactly. I think starving.
After removing this check-ball, the problem was completely solved! I never had the issue reoccur....even during periods when I could hear the fuel boiling furiously inside my tank (upon shutting the bike off). This...when above 12,000 ft. It would fire right back up, on demand, every time.
The symptoms appeared to be clogged fuel injector.....clogged fuel line/filter.....failing fuel pump, when in reality, it was simply locking up the tank vent.
So, my question to LOST is: Have you removed the check-ball in your fuel tank cap?
HF
After almost 100 hours I have not had any of these issues, no boiling, injector or filters clogs. I have seen that if after running if I shut off using the red rocker switch near the throttle AND not turn off the power at the key switch, then let it sit like this for 10 or 15 minutes that it will not restart unless I cycle the main power at the key switch. While this is happening I have noticed a few flashes from the EFI light.
Old 06-08-2012, 08:39 AM   #2363
Florida Lime
Oddometer: 2,431
Exactly what I needed !
Thanks for your help.
'10 Husaberg FE570
Old 06-08-2012, 11:40 AM   #2364
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,745
Uhmmmm Cyborg, nice work on the anti-vibe thingy-ma-jiggers. But......
I ain't got no vibes on my 390 at all. At least none to squabble over. Vibes are nearly non-existent on this bike.
Why did you need to anti-vibe your bars? Are you just that bored?
HF
Old 06-08-2012, 04:01 PM   #2365
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,178
Same here HF, no vibes to consider on my 390, though the 450 and 570 do have slightly more.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-08-2012, 04:42 PM   #2366
cyborg
cyborg's Avatar
Oddometer: 5,238
HF
HF, smooth road/trail cruising vibes are very low on the FE 390, like you said almost non-existent like a lot of 400's and that's really nice.
I added dampening for all the sharp-edged rocks gardens I get to 'experience' riding in WA. Long stretches of baby-heads and lots of rock step-ups, rocky trails, and zillions of log/root crossings and the 'ol wrists start complaining a bit (both my wrists have been broken in the past, one twice). The Flexx bars really helped on a long day of riding on my RXV550, but I wanted to try a different system this time on the Berg. I'll report back when I've tried this system on hard riding.
I have my suspension on "Comfort" settings when I do the rocky stuff and no complaints about the suspension in general. The bar dampener should cut the "zing" of sharp edge hits, as was mentioned earlier. I hope so.
Old 06-08-2012, 07:55 PM   #2367
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,745
HF
p.s. All the ladies are paying Sweet Thang a visit this week.
Old 06-08-2012, 08:47 PM   #2368
YamahaTN
Oddometer: 26
Originally Posted by chief_lee_visceral View Post
I run the MT43 on my 570S and it did put a hole in my mud flap but once I noticed that I put a longer chain I had around and it was okay then. Agree totally with Seth because we have trails like that around here and once you use one you start making the time to change it out when you have one on your plan.
Ok........I'm getting confused here (I know......it didn't take much) because I am reading that some folks are getting the MT43 on their FE570S using a slightly longer chain and some folks are saying it cannot be done. I'm used the using the MT43 on my WR250R and would like to use it on my FE570S. Can anyone post up some definitive chain/sprocket information whereby they were able to use the MT43 without rubbing holes in "not nice" places? Were you able to properly tension the chain or did you run out of slot in the swing arm?
YamahaTN is offline   Reply With Quote
Old 06-08-2012, 09:09 PM   #2369
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
HF, I did take that ball out a little while back, but I do have one of this gold vent thingies on my vent hose.... maybe it needs to go too. There was a lot of pressure in my tank when my boiling/no start happened. It took a while for me to let the pressure out of the tank, not letting fuel spit out.
I was at 9,000 feet, and I don't have any additional tanks yet.
I'll lose that vent cap thingy and see how it goes.... heading back up soon.
Thanks for the info and thinking of me, sounds like you had a great solo ride and got a little LOST.
Also I've had the same experience with it not starting when I either kill the motor with the handlebar switch and let it sit while I do my thing (mostly photos) or by my lack of good clutch control and let it sit. Starts up after cycling the ignition, sometimes though it takes a few turns or more. Only once has it taken 15 minutes to start back up after the gas-boil.
A new MT 43 rear tire mounted, we'll see what all the praise is about real soon... but my chain is not the original and I don't recall the number of links Neither is my gearing stock so I'm not sure I can shed light on you're answer YamahaTN.... Most of you wouldn't want to run the gearing I am. Currently 14/45, played with 13/48, 13/45 and 14/48. I figured I can get the most comfortable RPM's and MPG for traveling with this and go to 13/45 for the trails in a few minutes. ( no truck for me = more compromises for my bike) It was at towards the end of the adjusting on the swing arm with 14/48, but I took a link out since I went back 45 on the rear, now I'm pretty close to the swing arm, but it doesn't seem closer than when I mounted my last new tire and before I added a link to facilitate a larger rear sprocket.
If this tire expands much at highway speeds I might need to add that link back and move it back.
I'll post up some photos soon.
Lost Rider screwed with this post 06-08-2012 at 09:31 PM
Lost Rider is offline   Reply With Quote
Old 06-08-2012, 10:14 PM   #2370
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,178
Couldn't use the MT 43 on my 390, clearance was far too close for me and the tyre fitter.
Using a Maxxis Dualmaxx instead and so far it has been excellent compared to a 606 and the oem Six Days tyre.
http://www.maxxis.com/MotorcycleATV/...maxx-Rear.aspx
xronly
Times are GMT -7.   It's 03:30 AM.
