Old 06-16-2012, 01:41 PM   #11356
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
It's like tires.....a compromise
Does it help with the life of the output shaft?
My belief is that output shaft wear is directly related to chain tension. And, to be on the safe side I'm only using Honda CS sprockets. I have no way to test the hardness (Rockwell number) of the "hardened" aftermarket sprockets so I'm hoping that Honda is smart enough to have made their CS sprockets just a bit softer than the shaft. No way to tell with the others.
I think that's the best you can do other than just keeping your eye on it.
On chain oilers:
I built my own (cheap) version chain oiler and after 2 years of use I think I can provide some information.
When compared to my son's Transalp ridden in almost identical conditions my conclusions are:
Chain oilers do NOT significantly improve the life of a high quality X-ring chain as long as reasonable lubing and care is taken of the chain.
Where the chain oiler did make a significant different is in the wear of the sprockets. My CS sprocket lasted about 1.5 times as long as the manually lubed bike. My rear sprocket still looks almost new after 2 chains.
The disadvantage.....the chain oiler makes more of a mess. You'll get lube splatters on your spokes, rear tire and rim and a bit more goo around the CS sprocket. This is not a problem and it easily wipes off with a rag. It does help to preserve the finish of the rear spokes. It's also nice to just reach down and turn the oiler on after a dusty gravel road rather than fooling around with spray bottles and cans of lube at fuel stops.
Ladder106 is offline   Reply With Quote
Old 06-16-2012, 01:52 PM   #11357
CBR-ELEVENTY-TEN
Tastes Like Chicken!
CBR-ELEVENTY-TEN's Avatar
Location: Down...lower....lower..... Yeeaaagggghhhhhhhh!!!
Oddometer: 632
Originally Posted by ericGSsti View Post
As above lads got out for an hour today on the bike during my lunch break. Here a few pics I took.
I see you're in my old stomping ground, Eric. I miss the Phoenix Park... and my Africa Twin :-(
CBR-ELEVENTY-TEN is offline   Reply With Quote
Old 06-16-2012, 01:53 PM   #11358
ninety
Oddometer: 20
Thanks to the steering stem manufactured by Rugged Roads, I was able to convert the original forks to KTM USD. Result:
What needs to be done:
The rear rim wil be converted to a silver 18" next week.
The front fender. I prefer a low fender so if any off you have any suggestion to solve this.
Simon
ninety is offline   Reply With Quote
Old 06-16-2012, 02:54 PM   #11359
gpmucci
gpmucci
Oddometer: 245
Originally Posted by robie View Post
Hi, I see you have use showa/kayaba/ forks..what have you done with steering stem?
I bought showa forks from RMZ 450 2008 and I have to say it's kinda tricky to do all measurments precisely...
Do you have any sketch or drawing for that or anybody else?pleeeeease?
I 've done drawing in Autocad, so I can get it machined, I just wanna make sure that it is correct and I will not have to do it again...simply I need to compare it with somebodys else drawing...
Thank you very much for any reply
Ciao, usually I build up another axle. Those are wp.
gpmucci is offline   Reply With Quote
Old 06-16-2012, 02:56 PM   #11360
brittatel
brittatel's Avatar
Oddometer: 6
Originally Posted by wide View Post
Nice would like some pics of the Transalp to And what exhaust does it have ??
Yes GPR trioval...
Here some pictures of the transalp
Enrique Gonzalez
1988 Honda Africa Twin RD03 650
"The leg breaker"
brittatel is offline   Reply With Quote
Old 06-17-2012, 12:36 AM   #11361
gpmucci
gpmucci
Oddometer: 245
Old 06-17-2012, 03:46 AM   #11362
robie
robie's Avatar
Oddometer: 6
Yes, I will have to make new one as well..if it's wp than you can't help apparently, but thanks
robie is offline   Reply With Quote
Old 06-17-2012, 04:07 AM   #11363
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
My conversion from 2007
Originally Posted by atgreg View Post
Operation CR Kayaba fork has started. A big thanks to Pezz and his neighbour for the machining, I owe you big time !!!
just to remind you, Im fitting up a 96 CR250 front end to my AT
The CR stem is 4mm bigger in diameter than the AT stem
Original CR stem
Machined down to fit the AT bearings
Cutting the threads for the nuts
Done and the AT nuts fit, excellent
The stem will be pressed back into the triple clamps tomorrow, then Ive just got to wait till the forks come back from being revalved and sprung and we can bolt it onto the bike and sort out the steering stops and a plate to mount the ignition and sort out some sort of front mudguard.
I'd really like to still have a low front guard, any ideas for a low guard to suit USD forks ??
stem in the clamps !!!, thanks Pezz !!!
Forks are Go !!!. Thanks Pezz mate, cant say it enough !!!!
Well it was off to Dr Pezz's Skunkworks today to fit the new front end.
This one came off
The Dr at work
Tope triple clamp off
And a forkless AT
New forks in !!!!
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 06-17-2012, 04:18 AM   #11364
robie
robie's Avatar
Oddometer: 6
I wish I saw it before I bought the forks, because mine comes from RMZ 450, so it's different:
Stem is shorter(6mm) and bigger in diameter. Beacuse it's shorter I will have to get machined a new one.
I've done drawing for machinist, but I'm not 100% sure...I was wondering if somebody else have any drawing too, so I can compare it and make myself sure about the sketch....
But thank you ;-)
Old 06-17-2012, 04:24 AM   #11365
robie
robie's Avatar
Oddometer: 6
atgreg: by the way is that 320mm brake disc? How it works with only one brake calliper? is it weaker or same as a stock two discs brakes? cheers
Old 06-18-2012, 12:42 AM   #11366
svestenik
armchair adventurer
Oddometer: 35
One question regarding the KTM WP conversion. I have trouble finding a KTM front fork from any enduro/cross model, but on ebay there are loads of KTM Duke front forks. Are they shorter than enduro ones ? Can they be used with 21" enduro wheels without problems ?
svestenik is offline   Reply With Quote
Old 06-18-2012, 02:07 AM   #11367
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
Probably a bit weaker, I find it fine on the tar and dirt
Old 06-18-2012, 07:42 AM   #11368
Squily
Squily
Squily's Avatar
Oddometer: 1,223
Ready for the pits
Got the last bits today (thanks Jonathan). Claimed a family emergency today and finished her off. Still waiting for the chassis punch so I can finish the bash plate and skid plates, but she's ready for the pits on Thursday.
Without crashbars:
And with:
Business end:
Squily
Squily is offline   Reply With Quote
Old 06-18-2012, 09:23 AM   #11369
Ladder106
Ladder106's Avatar
Oddometer: 4,975
Saaaweeeetttt
Old 06-18-2012, 02:48 PM   #11370
GSPD750
GSPD750's Avatar
Oddometer: 1,445
Business end:
I like it. Where did you get your decals from? Are they pattern?
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
