Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-16-2012, 07:57 PM   #13111
Vzuke
Vzuke's Avatar
Oddometer: 152
Triumph Radiator Guard.
I thought it was a good idea to put some protection in front of that expensive piece of hardware. Not that I am going to be going off road anytime soon. The roads around here are rough enough!
You know how you are supposed to look at your instructions and make sure all the parts are in there before you begin? Yeah I know, who looks at instructions! Well I hit a snag on my simple install.
I had already removed some radiator shroud parts when I discovered I was missing my captive nuts! Luckily I had a couple of left over M5 nuts from a windshield project so I was able to put the bike back together. Bike Bandit later sent me the correct nuts.
It is an easy install with all the parts. You don't even have to remove the entire radiator shroud, just the right hand side (there are less things attached to wires in there).
Remove enough tank/radiator parts to get to the two screws (Green Arrows) holding the shroud backing onto the radiator. This will allow you to slip the radiator tabs A and B into the left shroud. When you re-install the backing you slip the right side tabs into the slots (Yellow Arrows). Don't forget to install your elusive captive nuts (Magenta Arrow). Okay, you do have to remove the lower half of the left side to do that.
Button everything back up and you are done.
Vzuke is offline   Reply With Quote
Old 06-17-2012, 03:13 AM   #13112
KildareMan
KildareMan's Avatar
Oddometer: 692
Originally Posted by Johno33772 View Post
I just removed mine & crimped the wires together & cut off the bracket...simple fix
Just rerouted mine so it's out of the way inside the frame & up near the gear change
KildareMan is offline   Reply With Quote
Old 06-17-2012, 04:53 AM   #13113
bluesman
Oddometer: 3,385
Sidestand solution - I think this is best so far
http://www.tiger800.co.uk/index.php/....html#msg78075
bluesman is offline   Reply With Quote
Old 06-17-2012, 06:29 AM   #13114
cronos1013
Oddometer: 33
Originally Posted by Snapper View Post
I was seriously thinking about just leaving it with the plunger ripped off, since it was running fine and I generally don't like idiot switches that can go wrong and leave you stranded... then I recall that I seem to be idiot about once a decade and ride away with the sidestand down - I have been saved by these devices a few times.
There is a way to relocate it under the swingarm that Xsilvergs demoed on the tiger800.co.uk forum with pictures.
Link to his post
cronos1013 is offline   Reply With Quote
Old 06-17-2012, 07:39 AM   #13115
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
Is anyone else having an issue with grooving on the wheel spacers? I have changed tires 3 times and each time I have rotated the spacers, but now I think I may need to buy another set for my next swap. The spacers are aluminum, and I am worried about premature bearing failure similar to the gs800s. I know some one is making steel spacers for the beemer guys, but I haven't seen anything on the tigers yet.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 06-17-2012, 07:46 AM   #13116
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,373
Sargent seat update
After I sent my stock seat to Sargent for reworking and new foam I got a call a little over a week later from one of the owners. They were in the development stages for their own version of a seat for the T800 and had a loaner bike on its way to them so they could develop their seat design. He asked if he could keep my seat a bit longer and use it for the development process, which I of course agreed to.
I got a call from him last week. He said the foam was done and it was headed to upholstery, and would then ship to me. They must have worked fast because I received it yesterday.
You can clearly see the dished area towards the back of the seat. The dish is actually a bit more than you can see in the photos because the vinyl seat cover tends to float a bit and doesn't fully represent the shape.
I rode the bike about an hour yesterday. I generally need a bit of time on a seat to get used to it but I can say without a doubt this seat is worlds better than either the stock seat or the Triumph gel seat (which I would be happy to sell at a discount to anyone who wants to try it). The dished area provides a lot more support across a much larger area, and I can still easily move from the dished area up onto the nose of the seat for a change if desired. Having owned several Sargent seats over the years I knew the foam would be a huge improvement, and was not disappointed.
I believe Sargent will release their seat somewhere around September, but for anyone who wants to have them make one based on the stock pan they should now have templates based on the one they made for me.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-17-2012, 07:56 AM   #13117
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,965
Thanks for the update. That looks real nice. PM sent re: gel seat.
swimmer is offline   Reply With Quote
Old 06-17-2012, 09:24 AM   #13118
bluesman
Oddometer: 3,385
When I had modified DR800 I had 2 set of wheels for it. And DYI aluminium spacers made on my small lathe.
I changed wheels million times, rotated spacers etc. and never ever had any problem with bearings in 70 000 km.
Old 06-17-2012, 09:43 AM   #13119
internalcombust
Oddometer: 1,586
I was questioning the grooves being cut into the spacers by the seal lip and dirt. Maybe I should have been more specific. As the grooves get bigger and deeper it will allow dirt and water to enter the wheel bearing area. It doesn't sound like you were experiencing any of the issues I was asking about.
2012 Tiger 800XC
04 DRZ400S
Old 06-17-2012, 10:17 AM   #13120
bluesman
Oddometer: 3,385
I see what you mean. No, my "DYI" design of adapted wheels did not allow that to happen, you right...
Plus I used really good quality sealed bearings...unlike BMW
Old 06-17-2012, 10:45 AM   #13121
RichardU
Let's Ride
Oddometer: 903
I only have 3,000 miles and haven't seen that yet, but it seems like a fairly common problem for aluminum spacers in general. My DRZ had the same problem until I bought a set of stainless aftermarket spacers.
RichardU is offline   Reply With Quote
Old 06-17-2012, 11:56 AM   #13122
TonyLoco24
Oddometer: 23
Wolfman Alpha on 800XC?
I have a wolfman alpha bag from a klr I use to have. Has anyone put one of these on the T800XC successfully? It's looking like it might sit on the exhaust, which would not be good. thoughts and/or ideas?
TonyLoco24 is offline   Reply With Quote
Old 06-17-2012, 09:06 PM   #13123
Stein67
Oddometer: 64
Does the GL Coyote bag work fine without any sort of pannier rack or racks or any sort on the XC? I really don't want to add anything permanent as most of my riding is just local but would like an option that I could throw on if I wanted to go somewhere. I suspect it's fine as they run them on KLR's and DR650's.
I put my hand on the stock exhaust heat shield today while riding and it was almost ambient temp when moving. I did read somewhere where someone added some self adhesive reflective metal tape as added protection for heat. I can imagine that it will get hot when stopped or in town.
I drive a BMW, but I ride a Triumph.
'12 800 XC
Stein67 is offline   Reply With Quote
Old 06-18-2012, 05:15 AM   #13124
Marsh Tiger
Marsh Tiger's Avatar
Oddometer: 550
Yes, I've noticed grooving too.
Marsh Tiger is offline   Reply With Quote
Old 06-18-2012, 08:00 AM   #13125
fbj913
I ride
fbj913's Avatar
Oddometer: 2,402
Rox Risers for you Tiger?
Want some? I know of a guy...
http://www.advrider.com/forums/showt...5#post18936405
fbj913 is offline   Reply With Quote
Times are GMT -7.   It's 06:41 AM.
