Thread Tools | Search this Thread | Rate Thread | Display Modes |
05-09-2011, 10:03 AM
#31 |
Ciao, Marco
Oddometer: 1,006
05-09-2011, 02:36 PM
#32 | |
Oddometer: 33
Do you have pictures of your cable end you plug in the unit? I've had an issue of it corroding inside the usb connector, but it sounds like you already tried to clean it off. I am upset they won't give you a new cable. It's obvious the customer service rep doesn't know the cable sold with the Zumo 220 is exactly the same as the cable sold for the nuvi500. The P/N: on the black box is exactly the same. You might consider asking if they could get you a new P/N:320-00322-40? That's the one on mine anyway. For working with the battery, it has a 1 amp fuse to keep from over powering the unit. Good luck! |
05-09-2011, 02:40 PM
#33 | |
Ciao, Marco
Oddometer: 1,006
the first customer service rep was acting wierd, though. after a few emails, they just said they'd send me a new one. i dont think corrosion is the problem. i proved this by using a multimeter before and after the transformer. i'd like to know what caused it's demise, so it doesn't happen again in an inconvenient place. i guess i'll never know........... |
05-12-2011, 03:05 PM
#34 |
Oddometer: 1,853
vibrations on a bike are bad enought. ad to that wiring or black boxes , unsecured and you'll probably be troubling shooting sooner than later. the wires in thoes power cords are small .- in my own case, i noticed that brakage happened within a few inches of the gps connection.
05-12-2011, 05:32 PM
#35 | |
Ciao, Marco
Oddometer: 1,006
i'm going to use industrial strength velcro and secure it close to the battery. |
06-09-2012, 03:48 AM
#36 |
Oddometer: 3,494
Power cable
Bump for a re-hash, please. I have same cable as OMG WTF and it's failed too. Wondered why in the heck my battery was dying and when I started checking all my wiring I find the transformer on this thing really, really warm. I get nothing when I plug it up to my Nuvi 550, so I figure the cable is toast but the transformer is suckiing juice. It is this cable:
http://www.gpscity.com/garmin-bare-w...-zumo-220.html ![]() Rather than try another round with that one, I was thinking about this: http://www.gpscity.com/garmin-power-...-zumo-220.html ![]() I'd just do away with the data wires like I read in some of the reviews. It'd be nice not to have that big black box under the seat and I thought maybe the smaller transformer on this one might have an easier life up on the handlebars. And I'll go with a switched wire this time instead of direct to the battery. What do you all think?? I'm a gadget dummy so I feel like I need to double-check myself. Thanks very much for the help. Sarah
'08 DR650 |
06-16-2012, 11:28 PM
#37 |
Choosing to be here.
Oddometer: 283
Sorry to bump up this aging thread, but has there been any developments with any of you having problems? Anyone else with issues? I too have the USB power cable/cradle shown in the first post, and have been having problems.
Essentially, whenever the unit is plugged in to the charger, it will randomly go into the "PC Connect Mode". This obviously is a big problem when you're moving along on the street and you get greeted by stupid computer icon on the unit when you have a series of back-to-back turns coming up. It will stay in that mode anywhere from a few seconds to a few minutes; totally random. The unit works fine just running off battery power, so I'm inclined to think there's something funky going on the the charger, and I'm concerned that it's just going to fail outright someday. I'd get a replacement, but it's not entirely clear if there's something inherently wrong with the design or if some of these just ship defective from the factory. |
06-17-2012, 02:17 AM
#38 |
Oddometer: 3,494
opmike,
I have no clue about these things, as you can tell by my above post. I ended up with my own thread, maybe the feedback there will be helpful to you: http://www.advrider.com/forums/showthread.php?t=798509 Good luck! Sarah
'08 DR650 |
06-17-2012, 06:07 PM
#39 | |
Oddometer: 756
![]() I replaced the cord but still had the same problems. On mine it turns out that the USB connection is just not strong enough for motorcycling and engine/road vibrations would make it lose it's connection. Once that happens it re boots as the connection is made again. Anyway, I fixed it by gluing a pigtail in to the Garmin. An additional bonus is this makes it a waterproof connection as well. ![]() I posted directions/pics for my fix a while ago here: (see post #2). http://www.advrider.com/forums/showthread.php?t=672276 The fix lasted 2 years, 20,000 hard miles on my DR650. I just had to re-do it recently, and everything's working right again. hope this helps........................shu |
