06-10-2010, 04:32 AM
#16 | |
Procrastinators
Oddometer: 5,789
Manuals Important Product and Safety Information (Multilingual), Rev. J, Nov, 2009 | Download Installation Instructions, Rev. A, Jan, 2009 | Download ML Declaration of Conformity, Rev. A, May, 2009 | Download Owner's Manual, Rev. B, May, 2009 | Download Quick Start Manual, Rev. A, Jan, 2009 | Download DA brugervejledning, Rev. B, Nov, 2009 | Download DA Installationsvejledning, Rev. A, Feb, 2009 | Download DA lynstartvejledning, Rev. A, Feb, 2009 | Download DE Benutzerhandbuch, Rev. B, Nov, 2009 | Download DE Installationsanweisungen, Rev. A, Dec, 2008 | Download DE Schnellstartanleitung, Rev. A, Feb, 2009 | Download ES Guia de inicio rapido, Rev. A, Feb, 2009 | Download ES Instrucciones de instalacion, Rev. A, Dec, 2008 | Download ES manual del usuario, Rev. B, Nov, 2009 | Download FI asennusohjeet, Rev. A, Dec, 2008 | Download FI kayttoopas, Rev. B, Nov, 2009 | Download FI pikaopas, Rev. A, Feb, 2009 | Download FR Instructions dinstallation , Rev. A, Dec, 2008 | Download FR manuel de demarrage rapide, Rev. A, Feb, 2009 | Download FR Manuel dutilisation, Rev. B, Nov, 2009 | Download IT Istruzioni di installazione, Rev. A, Dec, 2008 | Download IT manuale di avvio rapido, Rev. A, Feb, 2009 | Download IT Manuale utente, Rev. B, Nov, 2009 | Download NL gebruiksaanwijzing, Rev. B, Nov, 2009 | Download NL Installatie-instructies, Rev. A, Dec, 2008 | Download NL verkorte handleiding, Rev. A, Feb, 2009 | Download NO brukerveiledning, Rev. B, Nov, 2009 | Download NO hurtigstartveiledning, Rev. A, Feb, 2009 | Download NO Installeringsinstruksjoner, Rev. A, Dec, 2008 | Download PT Instrucoes de Instalacao, Rev. A, Dec, 2008 | Download PT Manual de Inicio Rapido, Rev. A, Feb, 2009 | Download PT manual do utilizador, Rev. B, Nov, 2009 | Download SV Anvandarhandbok, Rev. B, Nov, 2009 | Download SV Installationsinstruktioner, Rev. A, Dec, 2008 | Download SV snabbstartshandbok, Rev. A, Feb, 2009 | Download
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
06-20-2010, 02:57 AM
#17 |
Oddometer: 3
It's NOT in the manual!
All this discussion about the manual and the information is nowhere in there!
It does not tell you WHERE to put the MP3 files. - not \Garmin\media\ or ANY OTHER location. I've tried \Garmin\media\music and it does not work!!! If I put the same files on the internal flash and it works fine. I REALLY would like to use the SD Card though! |
06-20-2010, 04:45 AM
#18 | |
Procrastinators
Oddometer: 5,789
Just saying.
06-20-2010, 07:44 AM
#19 |
Long Haul Adventurer
Oddometer: 3,173
MP3 files should go here:
\Garmin\MP3\ You will get better indexing performance if you place your MP3's in multiple sub-folders. If this does not work, Format your SD Card and try again. Optimally your SD Card should have the following folders (directories): \Garmin\GPX \Garmin\JPG \Garmin\MP3 \Garmin\POI \Garmin\userdata
Cheers, Dan |
02-24-2012, 08:18 PM
#20 |
Oddometer: 1
Zumo 660 and 16GB
I've seen some people posting 8gb max capacity of zumo 660, my works just fine with 16GB and also tried a 32GB and had no problems, The only thing is that they have to be converted to MP3 and perhaps volume adjusted with MP3Gain to have them all play equally and not having to adjust the volume every time since getting to the volume control it's a pain.
02-26-2012, 05:09 PM
#21 |
Oddometer: 730
Are your music files MP3
If you use apple or Windows media player they will not always be MP3
COG 7524, IBA 46513, GLMC 214 |
03-07-2012, 08:19 AM
#22 |
Oddometer: 7,705
The Micro SD Card should show up as a separate drive on your computer. I named mine something catchy so I can remember what it is when it appears on my Mac desktop. I have dumped music files in the Audible folder, a MP3 folder I made, etc. It indexes the card and find all media files so putting them in a certain folder is not necessary but will keep the file system easier to navigate and update files as you go and make the chance of loading duplicates less...
2013 Tiger 800XC | 09 KLR650/685 *SOLD* | 04 Wee Strom *SOLD* | Explore: Backwoods, MS | My Daytrippin Thread MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map |
06-16-2012, 08:09 PM
#23 |
Oddometer: 40
32gb works well in zumo 660
I had a hard time finding exactly which memory cards would work with my 1 week old zumo 660 too. It wasn't totaly clear to me how big of a card I could get. I read this form and bought a scandisk 32gb card from amazon. It works perfectly.
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00 |
06-18-2012, 06:35 AM
#24 |
Oddometer: 237
Zumo 660 Music
Ours is on a 64GB Scan Disk with over 3800 songs and works fine.
Do not listen while we ride, but is a great entertainment center at night. Regards Ride Safe
Different in Every Way |
04-03-2013, 10:25 PM
#25 |
Oddometer: 9
maybe too many tunes
I just got a 660LM a few weeks ago. I had an 8GB card in the house which I started with, but went out and spent the $25 to get a 32GB card (man, is memory ever cheap now!). I then loaded about 4000 songs on the disk (about 20GB of data), and the zumo started working very, very slowly - and seemed to get stuck and not work at all much of the time.
![]() So I deleted about 1/2 of them, and now it's working fine. ![]() It'd be nice to be able to have as many songs on there as is space on the card, but looks like there is some sort of indexing process going on when I turn it on. My guess is that the processor can only handle so much data at a time. When I had too many songs on there I had 2 things happen: 1) The maps simply wouldn't render and navigation wouldn't start for quite a while...if at all, and 2) when the media player did it's thing, I could play whatever playlist I had at the last use, but wouldn't let me browse for quite a while..if at all. But once I reduced the amount of songs by 1/2 (around 2k songs and 10GB of data), it works great again. Of course, my entire music collection on my PC is more like 60GB+, but looks like I'll just swap out music now and again. If I played the entire collection from my PC, it would take about 40 days with continuous music playback (still have about 6 full days of tunes on the zumo now....that's an awful lot of hours of music still |
04-25-2013, 12:26 PM
#26 |
Politicians suck
Oddometer: 714
Do you have you MP3 files in sub folders, or just a bunch of MP3s?
Garmin\MP3\Artist\Album\MP3s works well, 16g card; 2g City Nav map, 2g Topo24 Map, about 1000 songs
2005 BMW F650GS-DAKAR 2008 BMW R1200RT |
