06-20-2012, 07:58 AM
#14 | |
Oddometer: 3
Bliping the throttle harshly when my bike is idling DOES occasionally make the first detonation mis, or at least make it sound very harsh. In my daily work I work with engine control software but not that close to combustion control. Hence I'm not an combustion expert and have attributed the behavior of the R1200 engine during very very rapid "blips" to - wire throttle in combination with the EFI system (compared to a system with an electronic throttle module) and - a lean A/F ratio (due to modern emission requirements). I guess the easy way to make the engine run richer is to fit the well-known Accelerator Cable, which essentially modifies the engine intake air temperature sensor value to be somewhat lower. Most posts on the internet regarding the Accelerator Cable have been quite positive in terms of improving low-end torque. However I have no idea if it would cure the response to throttle blips. Something which might be interesting to try is bliping the throttle in netural from a slightly open position rather than from fully closed. Will the system react differently then? |
