06-17-2012, 09:10 PM
#5281 | |
Oddometer: 135
![]() Thats an example for an 1/2 inch master cylinder (Xl250 degree)
scrambler66 screwed with this post 06-17-2012 at 09:34 PM |
06-18-2012, 01:57 AM
#5282 |
Booze Merchant
Oddometer: 547
I replaced mine with a new xr250 master cylinder not too long ago as the old one was shot. Works fine and I can still lock up the front wheel at will ( not that I want to be doing so too often! ).
CambodiaYeah! |
06-18-2012, 03:40 PM
#5283 |
Oddometer: 76
About supertrapp
If you decide to put it on it is important to know how many disks are inside Is it more “free” (with fewer disks) or not? And then you must re-tune the carb accordingly And if necessary re - jet of course you must know what supertrapp you will put on Quiet core? Race Core Quiet Race Core And adjust accordingly ONLY THEN you will understand the difference not only in the sound but in acceleration and top speed... Be aware IF someone will use the race core supertrapp the mixture if using 38 -145 and 1.5 turns is VERY POOR on gasoline the bike goes like hell in acceleration but… not very much gasoline The start of the sweet point is between 2.5 and 3 turns & 1/4 of a turn But re tune the carb is a pain in the @s$ believe me I know.... |
06-19-2012, 02:36 PM
#5284 | |
All-season-rider
Oddometer: 88
Since last time I've got time for riding a little. Nice weather and a nice bike. Perfect combo ;-) Ill guess youre quite happy with the weather where you are (well, except for the rainy times, of course), but here now its summer, and Im happy its dry roads and I only need one layer of wool under my leather suit, not to freeze ;-) Ive been thinking a bit, and mostly certain I will not go for anything but "the best", a complete set of suspension, suited my wheight, from Hyperpro. Its quite some money, but I have a damaged backbone, and in need for a relative comfy ride. A bikerfriend of mine told me he had "converted" to this Hyperpro on his rather new BMW-bike, and he describes the suspension now as a Citroen - driving in the skies. That sounds interesting to me! It must be lovely to have the possibilty to get crafts for that low price :-) Here in Norway its in the complete opposite side of scale. One hour at a bike-garage now is approx 1.000,- NOK, or $170!!! And I know a few garages here where they talk "bibblish", almost as Thai is for you ;-) Like when I told my KTM-garage; this and this (and this and this) electric things will not work properly in freezing temps. I offered them a video, who showed the trouble. "No-no, we do not need (to use the extra 2 minutes) to watch the video, we perfectly understand the problem. We will have a look, and discuss with central KTM". My fool, I trusted them. When retreiving the bike, they said "couldnt find any fault, are you sure its true?". This after 10 days at the garage. I asked them if they had testet by putting the bike outside in the winter-weather. "Why should we do that.. We have tested it in the garage, no faults now". Dooh.......! AFAIK it is only the miniDuke (125-200cc) thats made in India. The other KTM-s I belive still are made in Austria, with its european quality. Ive been working a little on a Austrian made KTM, and I liked the quality and solidity. Not equal as Honda, someplaces better and someplaces not as good. But generally good. And they generally have very nice components as brake-suspension-etc! So please do not let my story scare you from looking at the 690. :-)
Life is a just a game - lets play! |
06-19-2012, 02:43 PM
#5285 | |
All-season-rider
Oddometer: 88
Once again, thanks alot for your thorough description Scrambler66 Ive just had a thorough service on my stock brake: new sealings and fluid, sintered pads from EBC. Still dont like what I get. Im used to quite some sharper stuff. Within this summer Ill hope the oversized one will sit on my bike
Life is a just a game - lets play! fikse screwed with this post 06-19-2012 at 11:32 PM |
06-19-2012, 03:05 PM
#5286 |
Oddometer: 76
Remonal of cam chain
Do i have to remove the Oil pump to remove the cam chain ?
clutch is removed the nut that hold the cam chain removed but it seems i can't remove the cam chain unless i remove the Oil Pump under it is this the case ? or is something else and i am close to make a terrible mistake ??? thank you |
06-20-2012, 05:06 PM
#5287 |
Oddometer: 179
Shadow, stop. Go to cmsnl.com
type in your bike and look at the parts fiches. This way you know what your working with. the cam chain either has a masterlink or it needs to be broken apart if no masterlink. Are you changing the chain? Please do some study first. Also try dansmc.com to learn about this stuff. Good luck my friend. |
06-20-2012, 08:39 PM
#5288 | |
Oddometer: 226
Wrong. You do not break the cam chain and there is not masterlink. Remove the right side cover, remove the clutch, remove the locknut and gear off the crankshaft. You also do need to remove the oil pump. I just did this today. Then I split the cases and removed the crankshaft. Very easy engine to work on.
Buncha dirt bikes with license plates. |
06-20-2012, 11:12 PM
#5289 |
Oddometer: 76
ok so i do rermove the oil pump ok thank u also
there is a gasket behind the oil pump i must change that also i believe? |
06-21-2012, 07:44 AM
#5290 | |
Oddometer: 179
06-21-2012, 08:40 AM
#5291 |
All-season-rider
Oddometer: 88
Try single malt next time. Ive heard its more "correct"
06-21-2012, 09:42 AM
#5292 |
Lost Boy
Oddometer: 2,972
I am back for more advice on mods to our friend CrazyJill's NX250.
You may find this quite shocking, but the original rear shock is shot. So we are swapping in a GSXR shock this weekend. Looks simple enough. Next up, since she is kinda tall, we (she) are thinking about the XR250 front fork & wheel swap (followed by a 17" rear wheel). I saw the post where someone swapped the triple clamps & steering stem with the forks, but looking at them only being 1mm larger diameter I am thinking about just boring our the clamps to accommodate the forks. Any thoughts?
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. |
06-21-2012, 11:42 AM
#5293 | |
Oddometer: 226
Are you changing your cam chain tensioner also? I think mine failed, the chain was still acceptably tight (in my opinion) and it slipped on the crankshaft, stripping out the crank gear and bending both exhaust valves. Now I get to swap cranks and rebuild the head. Fun!!!
06-21-2012, 12:34 PM
#5294 | |
Oddometer: 76
to avoid the tensioner problem such as yours ( damn it man bad luck) i put a bolt with 2 nuts just touching the spring so if the tensioner spring goes bad the bolt and the 2 nuts will stop it You said paper gasket and o ring... damn.... dowe know numbers for the order? I mean the oem number thanks |
06-21-2012, 12:42 PM
#5295 |
The mud in your eye
Oddometer: 215
I have a 91 xr250l I am parting.
I'll let go the 21" wheel and the entire front end (forks, triples, spacers, axle, brakes (rotor is warped and master and slave need rebuilds) for $175 +shipping. That front wheel alone is $75 +shipping and will swap right into my NX (I have raised the fender and modded the fork brace). Adding a 17" rear and a 21" front brings the ground clearance up and balances the bike nicely.
Some will fall, others will laugh. I will do both. 06KLX250S 05CRF450X 98ST1100 |
