06-27-2012, 12:21 AM
#16 |
Oddometer: 508
Just had a look at what Montesa states for the Cota 348... 30wt oil @ 4% = 25:1
It's almost a oil engine compaired to some others..
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 Pete-NZ screwed with this post 06-27-2012 at 12:31 AM |
06-27-2012, 05:52 PM
#17 |
Got Snow?
Oddometer: 2,026
OK...
I'll get this thread even more wound up I use Honda HP1 @ 32:1 in my 200 Cota...
Wayne - 1984 HD FXRS... Not your stereotypical Harley rider. 1980 Montesa Cota 200 Got Logs? 03 DRZ 400s Gone but not forgotten... Days get shorter, Nights get longer, Snow gets deeper... Life is good! |
06-27-2012, 06:01 PM
#18 |
Oddometer: 110
06-27-2012, 06:03 PM
#19 |
Oddometer: 770
Well I just went to autozone and bought two gallons of pennzoil XLF two stroke at 15.99 each. Just so happened that my rewards card hit the $20 off at the register. Cha ching, the wife just bought me a 30 pack of coors and don`t know it!!
![]() Who said auto lube was a bad thing!
06-27-2012, 07:09 PM
#20 |
Buffoonery, Inc.
Oddometer: 2,273
+1, since I can do nothing right in the OP's opinion.
![]() Motul 800 full-synthetic at 80:1 in my 314 and 315 Montesas, and an "Eyeball-Rite" mix of 50:1 in the Team TY80. By "Eyeball-Rite" I mean that I pour the Motul out of the bottle into the TY's fuel tank at what I think will make a 50:1 mixture when I add in the already made pre-mixed 80:1 fuel from the 315's fuel can. I'm simply too damn lazy to mix up two separate cans of fuel for a Trials weekend. Been doing it for 3 years now, with no problems so far. Not yet anyway. I did take a peek at the piston through the intake and exhaust ports, no piston scratches noted as of last week. Very important, since the Team TY has to be in TOP SHAPE to take on some NMTA interlopers who have purchased a TY80 and assembled a rag-tag team of wannabes who's greatest desire is to try to horn in on the League's superior accomplishments. Good luck boys, looking forward to the challenge!! ![]() Hijack over. More to come on another thread. Back to the discussion at hand....
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. brewtus screwed with this post 06-27-2012 at 07:15 PM Reason: Nothing!!! |
06-28-2012, 12:57 AM
#21 |
Oddometer: 993
Motul 800 is a full synthetic pre mix oil, and perfect for trials use. Using this at 80:1 in an air cooled motor will cause no problems whatsoever, and several UK twin-shock championships have been won on air-cooled bike using this mix ratio.
06-28-2012, 12:02 PM
#22 |
Oddometer: 35
I'm running Opti-2 at 80:1 in my rev3, seems to run nice and clean. I'll likely start running the same in my Bultaco once I run out of the Belray h1-r that I'm using now.
Jay 2004 Beta Rev 3, 1972 Bultaco Sherpa T 250, 00' Kawasaki Super Sherpa 250 (Wife's) |
06-28-2012, 03:13 PM
#23 |
Oddometer: 993
As long as you are running full synthetic pre mix only oil, 80:1 will work just fine in any air cooled trials motor. Provides better throttle response, cleaner running, and means a far longer time between servicing exhaust system.
06-28-2012, 06:45 PM
#24 | |
Bourbon Tester
Oddometer: 82
I have been using the Maxima 927 oil at 80-1 since I got the bike earlier this year, do you think the M a better oil to use for a 2001 Gas Gas 321TXT ? I am using ethanol free 93 octane. |
06-28-2012, 11:55 PM
#25 |
Oddometer: 993
If you are running at very lean mix ratios a fully synthetic pre-mix only product is a better choice than semi synthetic. However if your riding isnt likely to involve extreme conditions or extended WOF riding, then the semi synthetic isnt likely to cause any sort of problems. Main thing to remember if you are running a pre-mix bike, is to use pre-mix oil, and try to avoid using dual purpose oils intended for autolube use.
06-29-2012, 05:21 AM
#26 | |
06-29-2012, 06:56 AM
#27 |
Oddometer: 35
Anyone else running Opti-2 oil? When I started running it I assumed it was full synthetic as the manufacturer recommends 100:1 mix but nowhere on the packaging does it say synthetic at all.... I know plenty of folks up here that run it in their trials bikes, chain saws etc.
http://opti2-4.com/index.php?dispatc...ategory_id=165
06-29-2012, 09:22 AM
#28 |
Oddometer: 993
I would guess Opti-2 is semi synthetic, but it seems strange there is nothing to clarify this?
06-30-2012, 05:54 AM
#29 |
Oddometer: 35
Does seem strange eh? I'm going to call the distributor next week and get the full scoop, who is also the local Beta dealer, he has been selling the stuff for years and I'm sure knows all there is to know about it.
06-30-2012, 06:14 AM
#30 |
Oddometer: 993
Many dealers sell dual purpose 2T oils for trials use, and I am not sure many are aware of the fact oils appropriate for autolube use, shouldnt be used at the same type of ratios that are OK for fully synthetics?
Maybe better to start to use something like Motul 800, rather than rely on a product whose manufacturers provide no technical data about it whatsoever? |
