Old 07-07-2012, 11:34 AM   #4396
Noyah
poser
Noyah's Avatar
Oddometer: 258
Both screws/bolts holding the airbox cover are no longer attached to the airbox... Not sure how to solve it, glue?
KTM 690 Enduro R
--> My Movies <--
Noyah is online now   Reply With Quote
Old 07-07-2012, 12:49 PM   #4397
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 817
I screwed up...
I am replacing the tank fuel filter with one outside the tank...
I purposely left the return hose on the connection where the fuel is pumped from the tank. Ran to napa... when I came back i removed it with out thinking.. now I cant remember which of connections is the return and which one goes to the pump
Its a 50/50 choice but i know i will get it wrong %90 of the time
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting.
Open-Exporers----->A collection of travel blogs
Old 07-07-2012, 01:06 PM   #4398
ramjet
ramjet's Avatar
Oddometer: 1,671
Question about 2012 model running temp
On a warm day and especially slow moving traffic I'm getting 8-10 bars on the gauge pretty quickly. How does this compare to what you guys are getting? No, stalling and engine doesn't seem to complain but is this headed towards overheat?
Qui Desiderant Pacem Preparate Bellum
ramjet is offline   Reply With Quote
Old 07-07-2012, 01:24 PM   #4399
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,830
Super glue the insert back into the airbox.
Guess what doofus, nobody reads your lame blog.
Old 07-07-2012, 03:58 PM   #4400
gen
2003 KTM 640 LC4 SM
gen's Avatar
Oddometer: 150
I hear that the 2012 headlight on the Enduro and SMC is much improved. As good as on the 990 ADV I'm told?
Does anyone know what the difference is and if we can install the 2012 headlight into a 2011 or earlier bike?
I'm trying to figure out which 690 to get and I want a black frame and the longer travel suspension that's only 2011 or earlier but would love better light output too.
Gen Kanai | '03 KTM 640 LC4 Supermoto Prestige | my blog | DoD#1458 | GaijinRiders
gen is offline   Reply With Quote
Old 07-07-2012, 04:00 PM   #4401
gen
2003 KTM 640 LC4 SM
gen's Avatar
Oddometer: 150
Originally Posted by Night Falcon View Post
Found the casue of my flashing error code!! Both wires going into the temp sensor snaped off right at the base of the connector . Before i attempt to pull it apart, has any one else managed to sucessfully reconnect the wires back to the connector?
More importantly, you should try to figure out why they snapped so you can mitigate it for the replacement.
Old 07-07-2012, 04:04 PM   #4402
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,293
have as much slack as possible, i painted it up with rtv where the wires meet the plug
MookieBlaylock is offline   Reply With Quote
Old 07-07-2012, 04:29 PM   #4403
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
Standard Super Glue will not work well, or not at all ... You need to use this: http://www.loctiteproducts.com/p/sg_...ing-System.htm And read this: http://advrider.com/forums/showpost....&postcount=715 It's the post 715 of this New and improved KTM690 WUNDERFEST. You can navigate there + or - 10 posts and read the whole story.
Good luck.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 07-08-2012 at 01:47 PM
Gros Buck is offline   Reply With Quote
Old 07-07-2012, 06:55 PM   #4404
CanadianX
Oh!? That is deep.
Oddometer: 761
Mine seems to run hot as well, hotter than my friends 2011 for sure. In slow traffic temp will rise quickly to the point where the fan kicks in but even on hot days on tight trails it has never run up into the last two bars. I may change the coolant to see if I can cool the bike a bit with a bit more water in the mix. Also check you coolant level, I was surprised to see the bottom hose connection on the overflow tank has a slow weeping leak, it being a brand new bike and all. I did have the bike back fire and stall in the heat once. Likely this is also when my TB started to work loose, a lean condition in the heat I guess. I've since added a FMF pipe and Akro map. No more back firing and TB hasn't moved since.
CanadianX is offline   Reply With Quote
Old 07-07-2012, 07:36 PM   #4405
jared1843
Drifter
jared1843's Avatar
Oddometer: 143
2011 has an orange frame... As the ktm gods intended.
2002 Suzuki DRZ400E - SOLD
2002 Honda RC51 - track only
2005 Suzuki DL1000 - SOLD
2010 KTM 990 Adventure R - SOLD :(
2011 KTM 690 Enduro R!
jared1843 is offline   Reply With Quote
Old 07-07-2012, 08:27 PM   #4406
DirtJack
DirtJack's Avatar
Oddometer: 331
Another way is to pull both inserts out, drill the holes all the way through and then use longer bolts bottom up through the holes and hold them in by pulling the inserts (use a suitable locktite) back into position leaving studs to hold the air box cover (RR filter, etc) with nuts.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 07-07-2012, 08:37 PM   #4407
DirtJack
DirtJack's Avatar
Oddometer: 331
I had the same problem and I completely disassembled the plug and was able (it took a long time) to even un-crimp each connector and then re-assemble with new wire (longer) and covered the whole assembly with individual shrink covered by a shrink over both wires. My recollection was that the hardest part was inserting the new wires through the waterproof connector because the wire I had on hand had a slightly larger OD. It is doable if you work slowly with a bit of patience.
2008 KTM 690 Enduro
Old 07-07-2012, 09:37 PM   #4408
BCC283
Oddometer: 1
Wunderlost
I just purchased an new '11 690 after much research (most of which was on here) and have been 2 for 2 on rides so far, i.e. couldn't make it back half the time. 350 on the odo and will stall and or not start when warmed up. I'm thinking maybe the fuel pump as I can only hear a "click" when I turn the key, but I really have no idea. I just came up on 5 days off and was going to go for a good ride, but as the bike is now at the dealers I decided to head to MX and rot on the beach.
Anyone else having these problems?
BCC283 is offline   Reply With Quote
Old 07-07-2012, 09:38 PM   #4409
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 858
I think its just vibration fatigue but managed to fix it ok. Have put some pictures of fix on my 690 thread but heres the finished job
"You cannot harm me...my wings are like shields of steel" - Batfink
My KTM 690
Night Falcon is offline   Reply With Quote
Old 07-07-2012, 10:04 PM   #4410
dirtbikeslob
Oddometer: 282
dirtbikeslob is offline   Reply With Quote
Times are GMT -7.   It's 03:40 PM.
