Old 07-07-2012, 06:59 PM   #1726
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,220
Originally Posted by helotaxi View Post
SteveO- What's the wiring conversion for that switch? The wires don't match up directly and I have to splice it all together so what color wires go to what color wires? What about the extra wire in the factory switch harness?
ETA-It would figure that now that I have this switch in hand, Sicass gets theirs back in stock.
Sorry for the wait, here is my wiring coordination:
Combination Switch wire colors -> KTM Wiring Loom
Dark Green -> (not connected to any wires on the KTM side)
Black -> Green w/Yellow Dashes
Light Green -> Brown w/Violet Stripe
Light Blue -> Blue w/Black Stripe
Orange -> Blue w/Red Stripe
Gray -> Green w/Brown Stripe
Blue -> White w/yellow dashes
White -> Yellow
Yellow -> Green w/Red Stripe & GRAY [tie the green w/red stripe to the gray, then connect to the yellow]
If you're hooking up a TrailTech Headlight, here is what works
TT Wires -> KTM Wiring Loom
Pink -> Green
Black -> Brown
Yellow -> Blue
If you're hooking up a TrailTech Computer, here is what works
TT unit -> KTM Wiring Loom
Green -> Yellow w/Blue Stripe
Orange -> Brown w/Red Stripe [These two are for the Fuel Indicator, which must use a standard Bulb, the LED does not work with this setup]
Blue -> Violet -> Lt Green
Black -> Brown -> Lt Blue [These two are for the HI-LO headlight indicator ]
Black -> White
Black -> Orange [Use the existing light, as there is a chip on the end of this setup]
Lt Green -> Violet -> Lt Green
Black -> Black [These are for the Turn Signal Indicator]
NOTE: If you want to use a LED light for the Turn Signal indicator, you MUST use a DIODE (part # 276-1114) from Radio Shack, inline with the Violet and Black wires, one Diode on each wire, with the Anode facing the KTM Wiring loom, and the cathode facing the light. Tie the two wires AFTER the diodes together so that each signal will go to the LED light. Then tie the other end of the wire to a Brown wire, to create the ground loop. This has worked very well. Soon, I'll have a schematic up on how to do this....
cheers
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO screwed with this post 07-08-2012 at 05:38 AM
SteveO is offline   Reply With Quote
Old 07-08-2012, 08:00 AM   #1727
harcus
harcus's Avatar
Oddometer: 1,333
Originally Posted by SteveO View Post
Got around to getting my Acerbis 5.3 gallon tank put on.
I took some pics of before and after to give ya'll an idea of the size comparison.
Tank looks good. Nice lines. Interesting color, flat black. Did fit up go ok? Dealer type told me of fit up issues. Any truth to it?
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 07-08-2012, 08:05 AM   #1728
avconnect
Oddometer: 119
13T countershaft wear issues
I need all the boys running a 13T countershaft sprocket to chime in on wear issues on the swing arm pivot an slide bar. At my current rate of wear I will be cutting into the swingarm shortly. Any thoughts/solutions? I like the 13t and have a 50T on the rear and still can get to 90mph.
avconnect is online now   Reply With Quote
Old 07-08-2012, 08:22 AM   #1729
Mifune
Mifune's Avatar
Oddometer: 493
I have a 50T rear sprocket and am seriously considering going with a 13T countershaft sprocket, so am also interested in feedback on wear.
How many links on your chain for the 13/50 combination?
2013 Ducati 1199 R
2012 KTM 500 EXC
2005 KTM 640 Adventure
Φίλα μου τον κώλο.
Mifune is offline   Reply With Quote
Old 07-08-2012, 09:11 AM   #1730
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,220
Flat black was all that was available. Being that the RMAR is coming up, i need some longer range, so this tank is it. As for fitting, it seems to be ok. I mean, its a dirt bike that takes a lot of falls and crashes, so lines aren't that important to me, i suppose. Now on a street bike, yeah, it needs to line up right.
Old 07-08-2012, 10:06 AM   #1731
Rock-Yot
Oddometer: 2
Tires
Got any recommendations for replacement tires? 50/50 dirt street riding here in SoCal.
Rock-Yot is offline   Reply With Quote
Old 07-08-2012, 12:59 PM   #1732
avconnect
Oddometer: 119
116 links.
Old 07-08-2012, 07:15 PM   #1733
jpdiller
Oddometer: 21
I ended up going with 118 links on the chain. It seems like it will work good, I have the axle adjusted a little more than half way closer to the front of the bike. I figure this is good cause when the chain stretches I can adjust the axle back. I think I remember reading something about having as much wheelbase as possible with the pds non linkage suspension. If the chain stretches to much I'll just take another link off. I am running 14 49 combo. I'm finally ready to get this thing in the dirt!!!
JP
jpdiller is offline   Reply With Quote
Old 07-08-2012, 07:17 PM   #1734
jtmajors
OCD with motorcycles
jtmajors's Avatar
Oddometer: 307
I have an xcw so it has 13/50 stock with a 118 chain.
jtmajors is offline   Reply With Quote
Old 07-08-2012, 07:32 PM   #1735
jpdiller
Oddometer: 21
Ya I forgot to mention I got a exc.
Also does anybody have detailed instructions on how to flip the rocker shafts? I am scared of the "mechanics" at my local dealership, I have the service manual. But I'm wondering if anybody has done this themselves? Thats my last thing and I'm ready to rock!!
JP
Old 07-08-2012, 07:53 PM   #1736
robmeoff
robmeoff's Avatar
Oddometer: 115
Start button a bit dicky??
I jumped on my bike on Sunday and hit the button..................................... nothing
hit it again and waited a good 5 seconds and then bang it lit up. i sprayed some WD40 into it thinking maybe a bit of moisture but still not working great. Anyone else have this issue?
robmeoff is offline   Reply With Quote
Old 07-08-2012, 08:05 PM   #1737
guns_equal_freedom
Oddometer: 5,591
That fuel tank is the best radiator guard made.
guns_equal_freedom is offline   Reply With Quote
Old 07-08-2012, 09:37 PM   #1738
avconnect
Oddometer: 119
It is an uly sucker though.
Old 07-09-2012, 12:31 PM   #1739
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,673
3 weeks after I purchased the bike I yanked the 17 in street set up and replaced it with the dirt combo that came with the bike.
It was an easy project but did take some time. The longest part being the sprocket and rotors being removed and installed on the other rims. I was looking to make it strictly a quick wheel swap
I have the stock 45 cause I went up to 48 and got some Moose Racing rotors. The last step is $19.00 worth of bolts that I hope to get this week.
The rotors are a stock replacement but look different.
I wanted to know if there was a performance difference as well?
Is one style of rotor better than the other?
Guns keep society safe.
Colemanfu screwed with this post 07-09-2012 at 12:41 PM
Colemanfu is offline   Reply With Quote
Old 07-09-2012, 03:29 PM   #1740
Enduro Outlaw
Enduro Outlaw's Avatar
Oddometer: 27
Originally Posted by jpdiller View Post
I'm in the process of putting on a 14 49 sproket combo. I got a brand new 120 link chain. Here's my question, do I leave all the links on the chain and adjust it from there? Like attach the master link and then try to adjust it.... Then if its too long take off the master link and a link or two? Any one out have a similar setup?
JP
Don't over think the chain adjustment. If the wheel is all the way out and your chain is to loose then take it up a link and so forth. I would not cut the chain so long that the axle adjusters are all the way out or so short you have to flip the axle blocks, somewhere in the middle is perfect. I would rather have the chain a hair long but not to long rather than cutting it to short and have the tire rubbing the mud flap.
I have a 13/48 setup and love it. The bike runs fast enough for town use and slow enough for tight trails. I was going to try 14/48 first but it was late and said screw it and i put the 13 on it and glad i did. Hell 13/50 would of been ok for what i do.
Enduro Outlaw is offline   Reply With Quote
Times are GMT -7.   It's 10:40 PM.
