Old 07-07-2012, 06:55 PM   #4381
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,693
Originally Posted by ramjet View Post
On a warm day and especially slow moving traffic I'm getting 8-10 bars on the gauge pretty quickly. How does this compare to what you guys are getting? No, stalling and engine doesn't seem to complain but is this headed towards overheat?
Mine seems to run hot as well, hotter than my friends 2011 for sure. In slow traffic temp will rise quickly to the point where the fan kicks in but even on hot days on tight trails it has never run up into the last two bars. I may change the coolant to see if I can cool the bike a bit with a bit more water in the mix. Also check you coolant level, I was surprised to see the bottom hose connection on the overflow tank has a slow weeping leak, it being a brand new bike and all. I did have the bike back fire and stall in the heat once. Likely this is also when my TB started to work loose, a lean condition in the heat I guess. I've since added a FMF pipe and Akro map. No more back firing and TB hasn't moved since.
CanadianX is offline   Reply With Quote
Old 07-07-2012, 07:36 PM   #4382
jared1843
Drifter
jared1843's Avatar
Oddometer: 144
Originally Posted by gen View Post
I hear that the 2012 headlight on the Enduro and SMC is much improved. As good as on the 990 ADV I'm told?
Does anyone know what the difference is and if we can install the 2012 headlight into a 2011 or earlier bike?
I'm trying to figure out which 690 to get and I want a black frame and the longer travel suspension that's only 2011 or earlier but would love better light output too.
2011 has an orange frame... As the ktm gods intended.
2002 Suzuki DRZ400E - SOLD
2002 Honda RC51 - track only
2005 Suzuki DL1000 - SOLD
2010 KTM 990 Adventure R - SOLD :(
2011 KTM 690 Enduro R!
jared1843 is offline   Reply With Quote
Old 07-07-2012, 08:27 PM   #4383
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by Noyah View Post
Both screws/bolts holding the airbox cover are no longer attached to the airbox... Not sure how to solve it, glue?
Another way is to pull both inserts out, drill the holes all the way through and then use longer bolts bottom up through the holes and hold them in by pulling the inserts (use a suitable locktite) back into position leaving studs to hold the air box cover (RR filter, etc) with nuts.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-07-2012, 08:37 PM   #4384
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by Night Falcon View Post
Found the casue of my flashing error code!! Both wires going into the temp sensor snaped off right at the base of the connector . Before i attempt to pull it apart, has any one else managed to sucessfully reconnect the wires back to the connector?
I had the same problem and I completely disassembled the plug and was able (it took a long time) to even un-crimp each connector and then re-assemble with new wire (longer) and covered the whole assembly with individual shrink covered by a shrink over both wires. My recollection was that the hardest part was inserting the new wires through the waterproof connector because the wire I had on hand had a slightly larger OD. It is doable if you work slowly with a bit of patience.
2008 KTM 690 Enduro
Old 07-07-2012, 09:37 PM   #4385
BCC283
Oddometer: 4
Wunderlost
I just purchased an new '11 690 after much research (most of which was on here) and have been 2 for 2 on rides so far, i.e. couldn't make it back half the time. 350 on the odo and will stall and or not start when warmed up. I'm thinking maybe the fuel pump as I can only hear a "click" when I turn the key, but I really have no idea. I just came up on 5 days off and was going to go for a good ride, but as the bike is now at the dealers I decided to head to MX and rot on the beach.
Anyone else having these problems?
BCC283 is offline   Reply With Quote
Old 07-07-2012, 09:38 PM   #4386
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,371
More importantly, you should try to figure out why they snapped so you can mitigate it for the replacement.
I think its just vibration fatigue but managed to fix it ok. Have put some pictures of fix on my 690 thread but heres the finished job
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is online now   Reply With Quote
Old 07-07-2012, 10:04 PM   #4387
dirtbikeslob
Oddometer: 300
dirtbikeslob is offline   Reply With Quote
Old 07-08-2012, 05:18 AM   #4388
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by CanadianX View Post
connection on the overflow tank has a slow weeping leak,.
i was going to just remove and replace the overflow tank because of this but for the life of me could not figure out how to pull it out of the frame, so i painted it up with rtv
MookieBlaylock is offline   Reply With Quote
Old 07-08-2012, 08:40 AM   #4389
snakepilot
Oddometer: 64
Bartron Partial Canisterectomy
I have performed the above procedure, including installing a Renazco billet filler neck and an in-line one way valve to the scavenge fuel hose. My problem is that I am building pressure inside the tank (fuel vapors normal expansion).
I thought the one way valve would stop the denser fuel from escaping, while allowing some air to exit to accommodate fuel vapors and ,of course, allowing air to come in to fill tank as fuel is depleted. Do I need a different valve, or should I just vent the hose to atmosphere without any valve?
I would appreciate a comment from those that have performed this modification.
TIA,
John
snakepilot screwed with this post 07-08-2012 at 08:56 AM
snakepilot is offline   Reply With Quote
Old 07-08-2012, 11:03 AM   #4390
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,666
I'm sensing a trend that Mookie is fond of RTV.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 07-08-2012, 01:05 PM   #4391
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
TIA,
John
I installed the Renazco neck as well but with no valve. I eliminated the evap canister so just cut the hose to the correct length after running it down by the right side of the shock.
I was fueling one day and when I removed the gas cap I noticed a vacuum had built in the tank. Removed the seat to see what was amiss (it's just a rubber line wtf could be the issue? ). The seat bumper that rests on top of the battery hold down was pinching the vent line. Moved the line and zip tied it out of the way.
Gotta give credit to the fuel system on the 690, not even a hiccup out of the engine with a vacuum in the tank.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 07-08-2012, 01:13 PM   #4392
Evil Invader
Evil Invader's Avatar
Oddometer: 697
Originally Posted by Barman View Post
Gotta give credit to the fuel system on the 690....
Well that´s a first!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 07-08-2012, 01:16 PM   #4393
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Gotta throw the dog a bone occasionally.
Old 07-08-2012, 02:31 PM   #4394
snakepilot
Oddometer: 64
Question Canirestomy
Barman,
I appreciate your reply. In your case, the pinched fuel line was the culprit. I do not have any "kinks" on the line, but following the procedures on Bartron's "code orange" thread to do a partial canirestomy and installing the one way valve has not worked as advertised.
I know that lot's of inmates have done this modification, so my question is: have you just vented to the atmosphere as Barman did, or did you use a one way valve? If you did, how is it working out?
Old 07-08-2012, 09:53 PM   #4395
SnapCracklePop
Re-Noobified
SnapCracklePop's Avatar
Oddometer: 7
Barman,
I've been just running the vent to the atmosphere ... been like this for more than 3 years now with zero problems.
I just don't trust those 1-way valves.
- Rick
'08 KTM 690 Enduro
SnapCracklePop is offline   Reply With Quote
Times are GMT -7.   It's 03:29 PM.
