Old 07-12-2012, 09:38 AM   #1216
Mr. Cob
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,404
Originally Posted by gspell68 View Post
I think Ural did have a recall on some of the rear hydralic brakes and sidecar brakes for about 3-4 consecutive years. Maybe the front brakes are catching up on the failures?
I don't know how well the 750 OHV can engine brake, but a 750 SV in the mild foothills of Germany, from a 5mph rolling start in first gear, will eventually, under the power of gravity, exceed the RPM's and speed it's capable of under its own power. It's really scary having to rely on the motorcycle's (no sidecar brake) hard, nasty, oil-soaked, "lineoleum" brake shoes for the whole ride down the mountain.
Howdy gspell68,
Thank you for your post. I have been trying to explain to bokad that if you start at 20 mph in 1st gear whilst going down hill you have already exceeded most of the engine braking the low compression engine of the Ural is capable of providing. When descending steep grades especially with a low compression engine you have to do so SLOWLY if you want to maintain control.
bokad, in an honest effort to help you understand engine braking and how compression ratio factors into it please do a bit of goggling and read up on "Jake" brakes and "exhaust" brakes that are commonly used on trucks. I have thought about experimenting with building an "exhaust" brake on the Ural similar to the one that my diesel truck is equipped with.
Years ago a person could buy from speed shops what was commonly called and "exhaust cutout", this was a devise that allowed by use of a cable operated valve the ability to direct your exhaust to exit the tail pipe BEFORE it entered the muffler. This lessened back pressure and to an extent increased horse power. The "exhaust" brake on my Cummins diesel works the same way only in reverse, it has an air powered valve that when you let up on the throttle partially closes off the exhaust pipe which causes the exhaust to back up into the engine thereby increasing the resistance to the pistons as the crankshaft rotates.
Like I said I have thought about experimenting with this but as I have never really had any problem being able to control the speed of my Ural's when braking on hills it hasn't been worth the effort to pursue the project.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 07-12-2012, 09:43 AM   #1217
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
Originally Posted by MotoJ View Post
Present company excepted, of course, but I've never seen such heinous personal attacks as in this thread, from some Ural owners against Bokad. Whatever his retorts he hasn't stooped to the level some here have. His criticisms have been about the bike. In return he's been called a pussy, an idiot, stupid, etc., and he's now held by one member in "contempt and disgust". I think anyone reading this thread impartially will see the imbalance. It's a poor showing by some Uralistas IMHO.
I used the words "contempt and disgust" and meant them sincerely, I also used the words "in my opinion" and meant them as well. It would appear that you either misread or over looked bokads knocking of not only the machine but the country and the people who built it as well the other Ural owners. I think there is enough kool aid drinking from both sides to entertain a casual reader who stumbles across this thread, but then again its just my opinion.
Dave, aka "Mr. Cob"
Old 07-12-2012, 09:49 AM   #1218
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,447
Interesting thought.
Would a "Jake" work on a normal engine as opposed to a diesel? Hmmm...
"I had driven to the scene of the accident, and I sat there waiting for me"
Heyload is offline   Reply With Quote
Old 07-12-2012, 10:05 AM   #1219
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
Howdy Heyload,
A "Jake" brake uses a mechanical mechanism to actually hold an extra exhaust valves open, click here for a good explanation of how it works.
http://en.wikipedia.org/wiki/Compres...e_engine_brake
Click here to read how an "exhaust" brake works.
http://en.wikipedia.org/wiki/Exhaust_brake
How such a devise would work on a regular gasoline engine I don't know, I do know that on my old Bultaco TWO STROKE dirt bike that had a compression release on it, you could activate the compression release while engine was running and the bike was in motion and it acted exactly like how a Jake brake works, if this would work in a common four stroke engine I don't know.
Dave, aka "Mr. Cob"
Old 07-12-2012, 10:11 AM   #1220
bokad OP
Difficult Child
Oddometer: 396
Originally Posted by Mr. Cob View Post
At first when you started this thread I kinda felt sorry for your troubles, as it continues and it becomes more and more evident that you truly are not in possession of some basic skills and are in need of being an "Internet legend" I have come to view you and your whining with contempt and disgust. I rarely voice such opinion but some folks yourself included just bring out the "Cob" side of my personality.
It's just so convenient for you to blame everything on one person and completely ignore the fact that other people have identical problems. Very useful mental trick there! Divert conversation away from Ural quality or design problems, attack people who mention Ural problems, pretend it is only a single person problem. Blame the rider! Blame the rider!
I ask again:
Those other people that have identical problems to mine, those other swing arm, final drive, and failed brakes, is that their fault too?
bokad screwed with this post 07-12-2012 at 10:17 AM
bokad is offline   Reply With Quote
Old 07-12-2012, 10:11 AM   #1221
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,182
If you go through and read it all again, you'll see the level of vitriol from the Ural side far surpasses anything Bokad posted. Hell, scroll through just the last 3-4 pages.
And if you have sincere "contempt and disgust" for anyone just because they criticize your brand of bike you're taking this shit waaay too seriously.
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 07-12-2012, 10:13 AM   #1222
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,447
Howdy Heyload,
I am familiar with "Jake" brakes and how they work. I was thinking a regular gasoline engine (four stroke) relies on the throttle to achieve engine-braking rather than the exhaust valve approach of a Jake in a diesel. I don't think there would be enough compression to release in a regular engine on the critical stroke to gain any advantage with a "Jake" styled mechanism, whereas diesels are all about compression.
Back pressure through an exhaust system set up, though...maybe. Diesels tend to turn at far fewer rpms, though. I can't help but think adding in additional back pressure would be a recipe for broken engine parts for an engine already pushing it's limits with regular compression back pressure. Then again, Urals don't rev particularly high, if I'm not mistaken?
Intriguing...
Old 07-12-2012, 10:18 AM   #1223
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
Originally Posted by bokad View Post
It's just so convenient for you to blame everything on me and completely ignore the fact that other people have identical problems. Very useful mental trick there. Divert conversation away from Ural quality or design problems, attack people who mention Ural problems, pretend it is only a single person problem. Blame the rider! Blame the rider!
If the shoe fits, wear it.
Reading through this thread its plain to see that I am not the only one who feels most of your problems are self inflicted as are many of the other problems lamented about by others who ride Ural's. I dare say HALF the problems that are written up on the net concerning Ural's are because of inept owners, how they ride or maintain their machines.
Many of us do things with our Ural's that make your "stressed" ride pale in comparison but if it makes you feel better to discount the experience of MANY who have a heck of a lot more saddle time then you have on Ural's by all means do so it only proves my point.
Dave, aka "Mr. Cob"
Old 07-12-2012, 10:27 AM   #1224
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
Intriguing...
Howdy Heyload,
And there you have hit upon the "probable" reason that gasoline engines DON'T use any type of exhaust brake, the engine itself is NOT designed or built to take the HIGH stresses induced by any form of exhaust or Jake brake. That is what has kept me from fiddling with this, I know what a pain in the ass it is to keep a head gasket in a high performance gasoline engine after having built and driven cars on the drag strip many years ago that ran within 2/10 of a second off the national record.
Adding to the compression ratio by using an exhaust brake would be inviting disaster in a high compression gasoline engine, but "IF" the head gaskets could take it and you didn't over stress the crank-rod bearings on a low compression engine such as the Ural, it just might be of "some" benefit. Then again the adding an exhaust brake to a Ural just might bokad the whole fucking thing and truly make it a bokaded RPOC.
Dave, aka "Mr. Cob"
Old 07-12-2012, 10:39 AM   #1225
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,447
I'm a big fan of the "KISS" principle, myself.
I honestly think, though, that adding any kind of additional braking force with such a system on this engine would gain you as much as say, dragging your feet Fred Flintstone-style.
Adding complexity with such a system..well..sort of defeats the point of having such a simple machine to begin with, said simplicity being a big part of it's appeal.
A Ural sort of reminds me of chess. Easy to figure out, complicated to master...but therein lies the challenge.
Heyload screwed with this post 07-12-2012 at 11:42 AM
Old 07-12-2012, 10:43 AM   #1226
Schatzman
I Saved Latin
Schatzman's Avatar
Oddometer: 3,954
People are pissed because this thread is completely fucking stupid at this point. If in fact the Brembo part failed, that is on Brembo. I don't care if people like Ural or not. What I care about is the misrepresentation going on about Ural and the people who run the company. IMWA has been beyond awesome to me and I won't stand by while someone makes false claims about their product.
Once again, if the bike is so faulty that all of these parts have broken because of quality control on IMWA's part, how would anyone in their right mind climb back on the saddle? If it were me, I would be doing several other things then posting on here about it. I would be parking the thing in a garage, I would be on the phone with IMWA-USA screaming at Jason, and be finding someway to get the issue(s) resolved. To have several major failures like this, and according to the OP being Ural's fault, should not leave him comfortable about the bike. He needs to shit or get off the pot. Don't waste people's time with this thread anymore. If the bike is a total unsafe POS, and I would say having the brakes "fail" would qualify as unsafe, then don't ride it anymore. One's life is more valuable then the Ural. Find a solution. That could be shipping the bike back home and renting something else or calling IMWA and seeing if they will give him another bike to ride in the mean time.
In short, life is made into a nonstop, commercially prepackaged masturbational fantasy.
-Allan Bloom
Schatzman is offline   Reply With Quote
Old 07-12-2012, 10:48 AM   #1227
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
A Ural sort of remind me of chess. Easy to figure out, complicated to master...but therein lies the challenge.
Howdy Heyload,
AGAIN, what you have written is simply common sense and goes along way toward why even thou I have thought about it, I have not spent the time and money to pursue such a devise on the Ural. Like many of the so called fixes that have been offered to the Ural, it is a solution to a problem that if ridden or maintained properly never existed.
Dave, aka "Mr. Cob"
Old 07-12-2012, 10:53 AM   #1228
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,447
Howdy Heyload,
Fair dinkum.
Old 07-12-2012, 11:11 AM   #1229
Mr. Cob
Mr. Cob's Avatar
Oddometer: 9,404
Apparently you haven't taken the time to learn a bit about me and my "brand" of bike. I am currently DOWN to 8 bikes in my stable, all different brands built to different jobs, dirt bikes for playing on the skinny trails, a RCK for knocking down 1,000 plus mile days , and R1 for being truly nuts, etc.
For years I have put up with the same stupidity when it comes to assholes many of whom have never even sat on a Hog let alone ride one talk about what pieces of shit they are. The same type of person seems to gravitate toward Hogs as does Ural's they like the look of the machine but don't have a fucking clue about learning to ride or how to maintain the bike but will piss and moan at the first broken fingernail, dead battery from lack of use, drop of oil on the floor etc. Both brands would be better served if the damned rubs would just go buy a Honda, oh and I have owned and ridden a few Honda's in my time too.
What I take seriously is someone who is partaking in what most of us would agree is the trip of a life time yet wastes his time on the net spewing his opinions and passing them off as a universal condemnation of an entire brand of motorcycle based on HIS limited experience. I would feel the same way if some loon started a thread called, "Why you should NOT buy a Harley, Honda, BMW, Kawasaki, KTM, Ducati, Yamaha,..................motorcycle".
Like I said and not in any bullshitting about this, if I were on a trip like bokad is, if I had the trouble he has had with the machine that he has had be it from bad quality control the fault of Ural or self induced malfunctions, if the rig had nearly killed me and my passenger according to him twice, if I couldn't sell it I would have stripped it of any identification and left it burning in a fucking ditch bought another machine and continued my journey.
Dave, aka "Mr. Cob"
Old 07-12-2012, 11:22 AM   #1230
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Riding
Does anyone want to come ride their POS Ural with us this weekend. Applejam is working out his Cascade Discovery Route and needs some beta testers for new tracks. Meet up is on Mt hood's Barlow Road tomorrow night where the creek crossing is. Oh by the way I'll be on my POS Ural gear up too. Expect break downs, grumpy folks, flat tires, drunkenness (mainly in the evening), final drive failures, break failures, rim distortion, piston melting, sidecar falling off, water in the carbs, yelling and screaming (mainly Yee Ha), flip overs, dangerous ascents and descents, oh and HUGE SMILES!
It sounds way better than reading this thread. Doesn't it? Oh and everyone is invited, even if we have only distain for you. Show up and have some fun on a new adventure route thru the mtns of Oregon. Or keep typing and enjoy the camaraderie of this thread.
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Times are GMT -7.   It's 08:37 AM.
