Old 07-12-2012, 05:24 PM   #4456
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Vibrations
Originally Posted by SoilSampleDave View Post
Ride any 640 LC4 KTM and you will build a shrine to the smoothness of the 690
I couldn't agree more. I had an 02' 640 Enduro and it was downright painful to ride any distance. Killed my butt and caused my hands and feet to go numb. My 10' 690 R is infinitely better and, as the miles add up, gets even better.
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 07-12-2012, 05:58 PM   #4457
Biped
NooB Again
Biped's Avatar
Oddometer: 338
You need to be sure the hose is rated for a submersable application. Both the inner and outer casing need to be fuel proof and rated for more high pressure. I have used Gates 27093 in 5/16 dia for my pump/filter upgrade. You can find it online and at NAPA/O'Rielys etc. It is spendy, more than $1 per INCH.
Originally Posted by RoninMoto View Post
Hey guys,
I am replacing the fuel line in the tank. I am thinking of this stuff...
http://www.helixracingproducts.com/H...ductId=-289982
My question: Good with up to %10 alcohol. On an RTW do you think i will hit more then 10% alcohol and or ethonal?
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 07-12-2012, 06:18 PM   #4458
Uller
Uller's Avatar
Oddometer: 1,679
More Vibrations....
Kind of a funny story....
When I first got my 690 I was new to dual sporting. Prior to, I had ridden plenty of street and plenty of dirt, just not both. So, I would take the 690 to the other side of the mountains to go play instead of my truck and dirt bike. Without doing something illegal, It is pretty much mandatory to ride one of our major mountain passes to get to the fun stuff. (I have been looking for 4 years for an alternate route alas, none exist.)
This is a 4 lane and 70 mph Interstate with a ton of semi trucks and people going 80. Now, I would consider myself an aggressive, defensive driver; and by that, I mean that, I typically go between 85 and 100, weaving in and out of the cars and semi trucks, mostly staying in the far right lane because most people drive in the left....... They can't run you over if they can't catch you, right?
(I'm getting to the point)
Now, personally I haven't ever ripped a valve stem and don't want to so, I put a rimlock on the bike at the first tire change. I didn't think too much about it. But, man did the 690 vibrate like no other going 95 down I-90 with an unbalanced, rimlocked MT-21 on the rear. I just didn't know why. My hands were killing me. My feet sometimes went numb. Got a Rox anti-vibe riser.....Nothing really helped. On top of that, I would use an entire tire on just a day trip of a few hundred miles.
Finally, while riding down I-5 on my way home from work in rushour traffic something hits my left leg as I'm going about 65 to 70. Instinctively, I took my hand off the bar and caught it. I was my fancy, undermount side mirror made by Advance Performance Accessories (one side was like $125 They sure looked nice though.) The bike was vibrating so bad that the vibs fractured the mirror mount in half. About a week later the other side broke (I lost that one on the inside shoulder of the freeway. )
Moral of the story/Lessons Learned:
1. Don't use one rim lock without properly balancing your tires and/or try to maintain freeway speeds and up.
2. Don't buy those mirrors again (they will just tell you that your bike vibrates like mad, laugh at you and hang up)
3. It takes a hell of a lot of weight to even out a rim lock and valve stem all on one side of the tire.
4. Two rim locks really don't make it that hard to put the tire on like everyone says.
5. Get good at changing tires because it is a common thing with this bike.
6. Because I like to plug the companies that make good stuff and don't really advertise, I will say that the Marc Parnes Wheel Balancer I got works very, very well. I just rest it on a set of jack stands. Easy.
http://www.marcparnes.com/KTM_Motorc...l_Balancer.htm
Uller screwed with this post 07-12-2012 at 06:31 PM
Uller is offline   Reply With Quote
Old 07-12-2012, 06:47 PM   #4459
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,211
Originally Posted by gbx2001 View Post
Yes the 690 is a single, and yes, it vibrates! Having said that, what have people found worked for attenuating higher frequency vibrations from the:
  • handlebars
  • footpegs
I have a Renazco seat, and don't notice vibes through my seat at all. As I get older (21,535 days), my arms and feet notice the vibes significantly more than a few years back and after a few hours, it tires me out. No, I am not gripping the bars too tightly!
On my 2009 690R I have checked motor mount bolts (ok), handlebar (ok), etc. for proper torque, and nothing unusual found. I have tried a few different grips and handlebar positions without any noticable improvement. I have also tried 3 different gloves (touring, enduro, etc) without any noticable difference.
I currently have Pivot Pegz mounted, but have not noticed any appreciable difference when swapping the stock pegs back on for a test. The stock pipe is currently mounted, but I also have a LV pipe, and did not find any major difference in vibes between the two.
I am looking at making some much longer rides in the near future so would appreciate any feedback to address the vibration issues.
Cheers
I dont notice hardly any vibes on my 09? Maybe your setup isnt working for you. Wheel balance, tire pressures, supension, engine need some work?
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 07-12-2012, 09:23 PM   #4460
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 764
Vibes
I fitted a pair of (old R6) modified bar end weights that I had on my Pegaso (got them from the bike wreckers)with my Barkbusters, and that did make a difference in reducing the bar vibes. But having said that, this is the least vibey single I have owned.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 07-12-2012, 09:56 PM   #4461
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
No Flats In A Long Time
I have been riding the dez, as Bobzilla says, for about 16 years now without a flat. The dez here shall mean Southern Nevada and Southern Arizona. Before that I rode in the Northwest, Seattle and east of the mountains like Uller, and prior to that in and around St. Louis, MO. I like Pirelli MT-21's (I know I am in the minority here) and Michelin Ultra Heavy Duty Tubes. Takes a lot of tape weights to balance the tires but I do it. Qualifiers: I don't slam into sharp rocks and cacti at 80 mph, I don't power through whoops at 100 mph, I don't ride up or down rocky creek beds with an angle of 70 degrees, I don't run my tires down to bald, I don't intentionally do g-outs, just by accident now and then. I know riders who rode like this for some time and they are now cripples. Bad knees, bad shoulders, bad wrists, bad ankles, broken stuff everywhere. Just what you need in your old age! In other words I am now a conservative and to many of you perhaps a boring rider. At 65 I take care of my body and the bike. I still manage to have a damn good time riding the dez exploring old gold and silver mines. I run off-road pressures of 16 psi (not exceedingly low but effective). I have to go back over 16 years to a time when I had rimlocks. So this is what works for me and my riding style, i.e. my lessons learned.
Old 07-13-2012, 06:37 AM   #4462
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Velociraptor View Post
Those SEs do not like deep sand
Are you sure about that?
Just say'IN
crankshaft is offline   Reply With Quote
Old 07-13-2012, 07:27 AM   #4463
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 972
Originally Posted by wino975 View Post
so you don't need more power, but a different power, this makes sense to me
Yes. But fortunately it has more as well. Would have been a lot of money just for better
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-13-2012, 07:31 AM   #4464
Velociraptor
TrackBum
Oddometer: 1,122
Yep!
http://www.youtube.com/watch?v=hBRDPFNY_rA&feature=plcp
I followed one for awhile. Rider did OK but was working hard to stay upright!
Also bike was very hard to get up on a plane from a standing start.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is online now   Reply With Quote
Old 07-13-2012, 11:11 AM   #4465
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Holy Crap,
Everything looks small when Crank sits on it ... At first I tought the bike was a 690 ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 07-13-2012, 12:42 PM   #4466
RoteEddie
Oddometer: 530
After selling my Smc last month I have been looking for a suitable 12' Enduro R. Today I was offered a x-demo with 500 km. The interesting bit is that it is fitted with evo 2 cam and filter plus the Akra pipe and properly set up on the dyno. It also comes with sm wheels.
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 07-13-2012, 03:16 PM   #4467
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
I have tried different tire pressures without any improvement. I doubt the vibration is related to tires or suspension settings though as the higher frequency vibes are evident at idle and increase with engine rpm in every gear, they are not directly linked with speed. I have not noticed significant changes in the vibes when switching between different maps, so I am less inclined to think the engine is the cause, especially after checking the mount bolts.
Cheers.
gbx2001 is offline   Reply With Quote
Old 07-13-2012, 04:56 PM   #4468
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Fyi:
Superplush is now making stainless shock collars for the 690e. Even the '08.
I'm not sure if its on the website yet.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 07-13-2012, 05:33 PM   #4469
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
So, today for the first time I got a big backfire on my 690. Immediately died and wouldn't start. i knew right away what the problem was since it has been talked about here recently. Blew off the boot on the throttle body. Just wanted to say thanks to you 690 "whiners" for keeping me from sweating my ass off today and making short work of getting my bike back up and running.
Old 07-13-2012, 06:17 PM   #4470
ktmmitch
Oddometer: 662
We have built 5 2012 690 Enduro R Rally-Raid Adventure conversions so far,but the last bike blew the throttle body off after 20 miles,and there have been a few cases of this problem in the UK.This is not something we have seen since the 690 Enduro was launched in 08.
Upon investigation we found that with the bike with the TB problem,it was possible to rotate the TB on the inlet stub of the cylinder head,even when the hose clips on the rubber connector were tightened fully.With the other bikes,this was not the case.The bike was checked for any problems with FI,valve timing,TPS and ignition timing problems,but all were found to be OK.
The hose clips have a short steel spacer between the ears,to stop the screw being overtightened,and act as a stop,once we cut this 5mm spacer in half,it allowed the hose clip to be tightened enough to stop the rotation.It was only needed on the cylinder side hose clip.After doing this we had no problems with the TB blowing off.
We have mentioned this to KTM UK,who have a '12 bike in their workshop,along with their own press bike,which both have this "issue" that they are aware of,and are looking into it.
We are going to check the older 654cc engines to see if the inlet stubs on the cylinder heads have changed in diameter,compared to the new 690 Duke engine,or if the rubber sleeve has changed in inner diameter,athough it is the same part no. for all 690 Enduro since new,but they may have changed supplier,which might have caused a tolerance shift in the part,this has happened before with different suppliers manufacturing the same part.
We will keep members informed of any further developments here in the UK
www.rally-raidproducts.co.uk
ktmmitch is online now   Reply With Quote
Times are GMT -7.   It's 07:01 AM.
