Old 07-14-2012, 05:57 PM   #16
Groundhog
Groundhog's Avatar
Oddometer: 188
Just had to replace my chain & sprockets (had 16/42 and stayed that way). If you want a damped 16T sprocket get the one for the newer models (16T for the 07 is not damped). Part #60033129016
Don't have any idea what the difference it makes, but that's what I got.
Groundhog
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 07-14-2012, 06:01 PM   #17
Whip
Onward through the fog
Whip's Avatar
Oddometer: 610
I just went to 16/44 and really like it.
2006 KTM 950 Adventure, 2006 1150 GS Adventure
2011 KTM 990 DAKAR, 1999 ZRX1100, 2015 500EXC, 1996 DR 350.
www.whip.smugmug.com
I'm their leader...Which way did they go???
Whip is offline   Reply With Quote
Old 02-09-2013, 11:07 AM   #18
macaroni
Oddometer: 771
Benefit of 16T over 17T and 45 over 42
So what's the benefit of changing the sprocket sizes? I've read that people like the 16T/45T arrangement for off-road but what does that mean? Do you have higher torque in first gear or what?
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
macaroni is offline   Reply With Quote
Old 02-10-2013, 08:44 PM   #19
sstewart
sstewart's Avatar
Oddometer: 1,056
Sprockets
Lower gearing all the way around,much more off-road friendly.
sstewart is offline   Reply With Quote
Old 02-11-2013, 05:53 PM   #20
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 941
Groundhog
You dont have a pic of a Damped one do you?
Interested to know if it helps reduce the vibes a bit.
Cheers.
rossguzzi is offline   Reply With Quote
Old 02-12-2013, 07:08 AM   #21
Korruptio
Oddometer: 23
Cheers.
Here is a picture of damped sprocket.
It has rubber disks on both sides of the sprocket and damping is only for the noise generated by chain, doesn't help a bit with vibrations.
Korruptio is offline   Reply With Quote
Old 02-13-2013, 08:54 AM   #22
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 941
Got it, thanks.
Old 10-26-2014, 11:26 AM   #23
Blur
Cunning linguist
Blur's Avatar
Oddometer: 4,302
Time to change my sprockets and chains. Ran across this thread while doing research. Thought I would reply and "pare down" the info in this thread:
Stock set-up: 17/42
Rear tire rotates .40476 turn per 1 front sprocket turn
16/42 combo
Rear tire rotates .38095 turn per 1 front sprocket turn
17/45 combo
Rear tire rotates .37778 turn per 1 front sprocket turn
And someone mentioned a 16/44:
Rear tire rotates .36364 turn per 1 front sprocket turn
Why use big words when any diminutive utterance will suffice?
Blur is offline   Reply With Quote
Times are GMT -7.   It's 12:27 AM.
