06-09-2012, 10:33 PM
#226 | |
Semi-Occasional
Oddometer: 1,534
Why a neutral switch? I don't even have one now...
'74/'70 R98/6/GS Traveling Bike (construction under way) '91 Bill Holland Steel w/Dura Ace |
06-10-2012, 02:20 PM
#227 |
Old Guy
Oddometer: 2
Find a jeweler that will rhodium plate your contacts and they will last even longer.
07-17-2012, 11:06 AM
#228 |
Oddometer: 30
Thread necromancy ...
My R75/6 battery died and I need a replacement. Do we have a consensus or semi consensus on LiFePo? Do I go new tech or old tech? |
07-17-2012, 12:01 PM
#229 | |
Oddometer: 2,536
main advantage of LiFePO4 batteries are weight savings and low self discharge rate. Lead acid batteries have advanced too. if weight savings is not a concern AGM batteries also has low self discharge rates at sightly higher $$ with excellent performance. disadvantage of LiFePO4, technology is still fairly new, where marketing may not meet with reality. exaggerated amp hour ratings are a valid complaint. what battery mfg recommends is usually too small. one may need to go several sizes up to match performance of original wet lead acid battery. if LiFePO4 battery is going on say a motocross bike, savings several pounds is pretty appealing. especially if that motocross bike is only ridden in fair weather. new gen high tech adventure bikes have highest requirement of needing weight savings, cold weather and extreme cranking performance for extended crank cycles. as in recovering from bad fuel and/or diagnosing failed component(s). so if saving weight is not a concern. my recommendations is go with a high quality AGM motorcycle battery. airheads are not known for high output charging systems. so amp hour ratings especially come into play if one is running heated gear and doing short runs. if you should decide to go with much lighter LiFePO4. smaller LiFePO4 batteries may start your motorcycle fine, but do so with very little amp hour in reserve. my recommendations is to go with the largest LiFePO4 battery that you can afford. especially if you planning on riding your bike during the winter. if goal is to duplicate performance of original OEM battery (new gen adventure bike). say bike originally came with a 16 amp hour wet lead acid battery. replace with a equivalent 16 amp hour AGM. if going with LiFePO4, currently my recommendation is downgrade actual amp hour ratings by about 75% = 12 amp hour actual rating for LiFePO4 if replacing a 16 amp hour lead acid battery.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 07-17-2012 at 12:07 PM |
07-17-2012, 12:32 PM
#230 | |
Oddometer: 30
Of primary concern is reliability, secondary is weight & size By reliability I mean everything from hour blast around downtown to day long trip around the majestic Midwest. I'm also lumping in service life under reliability. I'd want at least a couple of years out of the battery. So that leaves me with option A - 100 to 120 for Deka, WestCo, Oddyssey or whatever else AGM and Option B - 150 to 300 (ideally somewhere in the middle) Ballistic, Antigravity, Shorai, Sycl, Zippy or whatever else LiFePo. So, what do I get? EDIT: for clarity. Bike is '74 R75/6. |
07-17-2012, 12:56 PM
#231 |
Oddometer: 1,097
lithium hasn't advanced enough
I'd go AGM unless you're doing something ultra high performance. |
07-17-2012, 01:04 PM
#232 |
Oddometer: 30
07-17-2012, 02:58 PM
#233 | |
Oddometer: 3,261
Anything else was stock and did not fail. p.s. It's an R-100
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside. |
07-17-2012, 03:26 PM
#234 |
Oddometer: 542
I have an inexpensive AGM that I bought from my local auto parts store for less than $100. It has lasted four years, and been on a Pulse Tech xtreme charger when stored during the winter. If I buy a lithium, my $100 battery charger is extinct, as it isn't meant for the lithium batteries, so I need to add the cost of that to the actual new battery. As of right now, I'll stick with AGM and a good charger for storage, and let the technology get better and the buy-in cost get lower.
07-17-2012, 04:33 PM
#235 |
Oddometer: 132
Odyssey AGM
Odyssey battery.
http://www.odysseybattery.com/powersports.html (guide is a 'pdf) Just put one in my R90. Guide says PC 925L, but on advice of many on the web I used a PC 680 and made up some timber blocks to fill battery box as it's a smaller battery. You will need a smart charger if you ride in frequently. Happy so far with it. HTH YMMV. ~OZ PS: thanks _cy_ for all your hard work so far, great info & technical info on the lithiums. oz_airhead screwed with this post 07-17-2012 at 04:36 PM Reason: extra info. |
07-17-2012, 04:42 PM
#236 | |
Oddometer: 30
What's a good smart charger for it? Will a Sears brand trickle charger do the job? Also, any kind of special considerations regarding terminal orientation, L bracketry, etc.? |
07-17-2012, 04:53 PM
#237 | |
Oddometer: 132
None of the chargers listed by Odyssey are suitable for here in OZ, so I bought one of these: http://www.batteriesdirect.com.au/sh...18/mxs5.0.html (sorry dunno what "sears" type is mate) The PC680 I bought comes with 6mm threaded receptacle, bolts and "L" brackets that can be used. For my particular bike/setup, I used one "L" bracket on the negative terminal, and just used the 6mm Stainless bolts to attach the Positive terminals. I also added a small square flap of rubber from an old tube threaded through +ve cable to make a rough terminal cover for that terminal. I also replaced the battery leads whilst I was there - made some up using cable and lugs from an Car parts store. Cheers HTH (sorry for thread hijack!) ~OZ oz_airhead screwed with this post 07-17-2012 at 04:57 PM Reason: more info |
07-19-2012, 07:54 AM
#238 |
Oddometer: 2,536
LiFePO4 fires
since this topic is going to come up anyways... might as well get started very few shreds of hard data are available. For the number of LiFePO4 batteries out in the field. very few instances of LiFePO4 fires. LiFePO4 batteries must be wired carefully to your bike's wiring harness, as they can source high enough currents to start some amazing fires in shorted wiring. Be dead certain positive connection(s) will not ground out. seldom are LiFePO4 batteries identical size/shape to factory battery. take extra care to strap non-OEM sized battery securely to prevent any possibility of damage to outer case. if an internal connector strap grounds out. a fire could result. note pictures below showing LiFePO4 fire are from wiring shorting out. Note LiFePO4 cells were still putting out full volts afterwards. wiring shorting out, not battery failure seems to be the common thread so far for LiFePO4 fires. it's worth noting that identical shorting problems could happen with wet lead acid, AGM or Gel cell batteries. dead shorts can easily result in a nasty wiring harness fire. more to come... here's an example of a LiFePO4 fire thought to be caused by shorted internal wiring. a valid example yes, but without laboratory analysis still not considered hard data. --------------------- The Lifepo4 FIRE!!!! (the top secret photos) Last year we had a problem with one of the boxes that Headway sent us. http://www.elmoto.net/showthread.php?231-The-Lifepo4-FIRE!!!!-%28the-top-secret-photos%29 The batteries were NEVER the problem nor the so-so BMS. It was the poor wiring job provided by hungover employees, at least it looked that way. I cannot say this enough times, FUSE your battery packs!!!!! (note this in context of Electric bike which draws aprox 33 amp continuous load) Just to show you the robustness of the headway battery, here is one that was burnt to crackly crisp and still have full voltage!!!! this is worth considering if one is looking into LiFePO4 batteries
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 07-19-2012 at 08:01 AM |
07-20-2012, 07:16 AM
#239 |
Oddometer: 35
I put an Odyssey PC925L-A in my '87 R80RT in early 2010, plug into a battery tender junior that I picked up for $20. With a new ignition coil, the old girl starts immediately nearly every time.
1987 BMW R80RT - "Lucy!" http://defendingcontending.com/ There is therefore now no condemnation to them which are in Christ Jesus. (Romans 8:1) |
07-20-2012, 08:41 AM
#240 | |
Oddometer: 2,536
tried starting R80G/S 3 days ago... normally one short crank does it.... dead .. yup a dead battery. R80G/S is the test mule, so been switching batteries around. for the last few months, battery on R80G/S Shorai LFX36L3-BS12... Not a single problem until now. measured volts was down to 6.5v ... not good.. charged battery very carefully. recovering from such low discharge conditions requires reforming cells. initially charged at .01C with HP regulated power supply. volts and amps was adjusted barely above what LiFePO4 battery would accept as battery slowly came back up. after Shorai LFX36 finally came back up to 12.85v. then switched to Powerlab 8 with balance board for charging duties. next phase was to form cells at .5C which brought battery back up to about 18% charged condition. then charged battery at 1C (12 amps) until battery finally accepted charge to 3.65v per cell. Shorai LFX36 recovered from a total discharged condition of 6.5V to a fully charged 14.2v. after letting battery rest overnight... measured 13.35v ... repeated charge to 3.65v per cell. measured 14.19v after charging. repeated process of resting and charging for four cycles the last three days. Shorai drops to 13.35 resting volts after sitting overnight. normal resting voltage after a full charge should be higher. naturally would like to know reason for Shorai battery going dead. measured milliamp draw of zero with Fluke 87V between battery and ground. No parasitic drain of any kind on R80G/S, unless drain is intermittent. did a few 150 amp load tests on Shorai LFX36, which it passed without a hiccup. will do a full discharge cycles to find out total amp hour capacity after recovering from 6.5V. the last few days before battery went dead. had been working on dialing in a Bean with points, experimenting with different ignition advance settings. every time front cover has to come off, battery has to be disconnected to prevent dead short. with all that battery cable moving around. problem could have been caused by all the recent activity. more to come...
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
