05-07-2012, 09:08 PM
#16 |
looking for bionics
Oddometer: 594
That frame repair looks great. Did you notice a cracked rear engine mount? I have three XR500 frames and interestingly enough all three had a cracked rear engine mount/tab in the same spot. I also had some small cracks were the seat and air filter box cross members meet the frame rails. I think the stress of getting too much air combined with the sharp angles caused the cracks. Newer XR frames look to have curved ends on those cross members which probably handles the stress better.
I recall you just pull the pin on top that keeps the tensioner shaft from moving to the right, and then just grab the tab and pull it out while giving it a twisting motion. Once the shaft is out then tensioner can be removed from the top. There is a pdf manual recently linked on The XL600 thread if you don't have one. |
05-08-2012, 02:41 PM
#17 | |
Local celebrity
Oddometer: 124
05-08-2012, 02:53 PM
#18 | ||
Local celebrity
Oddometer: 124
![]() I just found a link on page 229 of that thread but the resource file's obviously been removed. Does anyone have a copy please? Is it emailable? JimRidesThis screwed with this post 05-08-2012 at 03:05 PM |
05-08-2012, 10:09 PM
#19 | |
looking for bionics
Oddometer: 594
Look at this post for link (XL600R* (Inglese)):http://www.advrider.com/forums/showp...postcount=5709 |
05-09-2012, 10:34 AM
#20 | |
Local celebrity
Oddometer: 124
Had a little garage time this evening: there are no cracks in the mounts on the frame and the tensioner shaft, tensioner, cam and cam bearings are now out and all look OK. No pics, but you've seen all this stuff before JimRidesThis screwed with this post 05-09-2012 at 02:32 PM |
05-20-2012, 08:58 AM
#21 |
Local celebrity
Oddometer: 124
Progress on the XL has been slowed by some good riding weather
Unfortunately, this has thrown up a small issue with my 1100GS - the clutch has started to slip As I'm riding down to Austria and Italy to indulge in some Alpine pass-bashing at the end of June, I suppose I'd better fix it before I go!Anyway, the result is that the XL engine has remained well wrapped-up on the bench, but I haven't been entirely idle. Now that the frame's oil tight I can start the 'dry build' to check the state of the engine and find out exactly what's still missing from the rest of the bike. The rear suspension and steering head bearings have been stripped, cleaned, inspected and re-greased. Everything checked out OK. So, now I have a moveable rolling chassis and I want to bolt on as much of the rest of the bike as possible. I only have a small garage space to work in, so I want to clear the decks for the GS clutch job. In the meantime I'll order the engine parts I need - cam bearings, helicoil kit, gaskets, etc. - and put it all back together. Here's where we stand today
07-07-2012, 01:01 PM
#22 |
Local celebrity
Oddometer: 124
Head, cylinder & piston...
Wake up at the back! Project XL is back on the bench...
I intended to just pop the engine back in the frame to see if it would run, but, when I started to clean out the clutch casing I started to come across some small chunks of debris, presumably from the broken decompressor cam. I don't want these getting into bearings, gears or oilways, so I'll to strip the engine, at least part way, to give me a chance to swill out any further bits and bobs that have found their way in there. With an engine this simple it's only a minor PITA :-) I made a start this evening by removing the head and cylinder from the engine... ![]() ![]() The head doesn't look in too bad a shape... ![]() ...and neither does the bore. No appreciable wear and no score marks that I can feel with my fingernail. The broken fins are NOT down to me! ![]() I can't believe how big that piston is! I think Honda might have got a job lot from Leyland trucks or something ![]() All these parts will be cleaned up, properly inspected and relevant tolerances measured. I've come across some small bits of debris or swarf in the timing side case so I'll remove the clutch to get better access for cleaning and strip the oil pump just in case. More to follow... JimRidesThis screwed with this post 07-16-2012 at 07:09 AM Reason: spelling |
07-16-2012, 05:31 AM
#23 |
Local celebrity
Oddometer: 124
Timing side strip-down
Having revealed bits of the broken decompressor cam in the timing side case, karma decreed a partial engine strip might be a sensible idea. It'll allow me to swill out the cases with paraffin and check the crank and gearbox bearings for any free play or 'grittiness'.
![]() It's what's missing here that I've found in the timing side case Here's where we start from... ![]() The following photos are really just my reference shots so I don't forget the order of parts, etc. :-) ![]() The kickstart camplate and associated gubbins ready for inspection and cleaning ![]() Holding the clutch centre without the correct tool could have proved tricky; but a strip of leather protecting the clutch centre, a pair of mole grips providing a positive stop against the outer drum and and extension bar on the socket did the trick ![]() The crank nut with assorted pinions and the cam chain. I guess I it would be foolish not to replace the cam chain seeing as it's stripped down this far. ![]() Almost a bare timing side case. So, all in all it's not looking too bad so far. The clutch basket has some indentations from the clutch plates, but nothing that won't be cured with a few file strokes. The gearbox shafts turn very smoothly as does the crankshaft; there's no detectable wear in the bearings but these will be replaced anyway seeing as it's this far apart. JimRidesThis screwed with this post 07-18-2012 at 10:13 AM Reason: accuracy/change of plans |
07-16-2012, 06:05 PM
#24 |
Oddometer: 1,625
Hey Jim! I would take your cylinder in to a machine shop and have them measure it. Just because it looks good doesn't mean it's in spec.
Maybe I'm just weird about things like this but I would replace all the bearings in your bottom end. The last two XR600s I built got all new bearings, new connecting rod, overbored piston etc. I guess I just feel since your in that far, might as well put new stuff in so you won't ever (hopefully) have to worry about anything going south. The original engine from my '84 XL600 had about 22,000 miles on it when it lost a mainshaft bearing. Not real common but it happens. How many miles on your engine?
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
07-18-2012, 10:03 AM
#25 | |
Local celebrity
Oddometer: 124
I've got access to good measuring equipment at work so I can check the cylinder and piston there. I'll price up the bearings and I might as well factor in a full gasket set and seals too. So the shopping list so far is... Full gasket set Oil seals Bearings Camchain Decompressor cam and spring Piston circlip Crankshaft/clutch casing oil seal and circlip Does anyone have a spare set of carbs-to-airbox rubber hoses, actually it's only the left hand one I need? Are there any essential or worthwhile mods to do while I'm in this far? I did read something about an oil pump upgrade from an XR650 I think... from one of Ghost Mutant's posts in this thread. JimRidesThis screwed with this post 07-26-2012 at 11:50 AM |
07-18-2012, 11:13 AM
#26 |
looking for bionics
Oddometer: 594
oil pump
The newer oil pumps have shaft seals internally. Those help prevent frame tank drain back when the engine is off.
But I think the bigger deal is the newer pump drive gear set. They run the pump a little bit faster for a given RPM. You can run the new pump drive gears on the old pumps if you don't think you have a drain back problem. I found the newer pump parts on ebay for my engine rebuilds. |
07-18-2012, 01:25 PM
#27 |
Local celebrity
Oddometer: 124
Thanks GM. That's a great synopsis of the thread I had in mind. I don't know if it was wet-sumping or not, but I'll check out the availability and cost of the alternative pump parts anyway. I guess it's not that difficult to change it later, if the current pump has issues.
07-19-2012, 12:46 PM
#28 |
Local celebrity
Oddometer: 124
Needless to say I haven't got the "special tool"
so...do any of you gents know an alternative for removal of the flywheel? e.g. use rear wheel spindle as slide hammer, that sort of thing. I do own a set of 2/3 legged pullers (currently in hiding) but I don't think they're going to be the right tool for the job anyway. Removed the kickstart shaft and took the piston off the conrod this evening and also cleaned up the clutch side casing threads, just in case any helicoils were needed - none were. Circlip added to the shopping list! JimRidesThis screwed with this post 07-19-2012 at 04:04 PM |
07-20-2012, 07:13 AM
#29 |
looking for bionics
Oddometer: 594
By special tool you mean the "bolt"?
![]() http://www.motionpro.com/motorcycle/partno/08-0074/ M22X1.5 Right Hand threads. To answer your question, no, I used the above motionpro bolt to remove my flywheels. |
07-26-2012, 11:33 AM
#30 | |
Local celebrity
Oddometer: 124
I'm afraid there's no real progress to report on my XL project. The crankcases are now separated but the flywheel is still attached. The main bearing I can see doesn't look too hot - the outer race is showing signs of pitting - so that just confirms that I'll replace all the bearings and seals suggested in a previous post. Jim JimRidesThis screwed with this post 09-02-2012 at 02:41 AM |
