Old 10-08-2005, 04:03 PM   #31
bikejunkie
Oddometer: 52
Are the lower triple clamp and locking tube the same on an 88-90 as the 91-95 GS? Max's has different part numbers (not always means their different). After replacing the steering head bearings in my 88 GS I want to know if the homemade thrust collar recommended on this site (the 3/4 copper connecting plumbing sleeve etc.) will work. Anybody done this mod to an 88-90 GS? If so, any suggestions? Thanks.
bikejunkie is offline   Reply With Quote
Old 10-08-2005, 07:33 PM   #32
bcostell
Oddometer: 192
The top and bottom triple clamp, plus collars etc are different on the earlier and later bikes. I've swapped the earlier to the later type, you can pick all of the parts up s/h if you shop around a bit.
bcostell is offline   Reply With Quote
Old 10-09-2005, 05:35 PM   #33
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
Seperate topics!!!!!!
On parts -
Originally Posted by bikejunkie
Are the lower triple clamp and locking tube the same on an 88-90 as the 91-95 GS? Max's has different part numbers (not always means their different).Anybody done this mod to an 88-90 GS? If so, any suggestions?
I don't know. Maybe take a look at some bikes?
On adjustment.
I don't know. I have not tried it. But in theory it should. Note To be clear. The 3/4 copper sleeve is a 'tool', not a part of the bike - it helps in performing an adjustment or setting.
Frank Warner is offline   Reply With Quote
Old 10-12-2005, 05:26 PM   #34
sharkey
XLV750R
sharkey's Avatar
Oddometer: 875
Originally Posted by Frank Warner
Just did this, following the instructions, and I can confirm it works.
Much tighter than I'd previously set them, and helps the low-speed
steering a lot. I still need to replace the bearings, though ... there's
quite a noticeable flat spot.
To cut the collar evenly, I used a dremel cutoff disc in my drill
press, with the drill press plate 10mm belot the disc ... then just
held the bottom of the collar with a pair of pliers and slid it along the
plate and into the disc, turning it until it was cut all the way around.
Makes a nice even cut, easy to clean up with only a little sandpaper.
Wear eye protection.
-----sharks
sharkey is offline   Reply With Quote
Times are GMT -7.   It's 03:49 AM.
