Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 05-28-2012, 02:27 PM   #511
Bevelhead
Bevelhead's Avatar
Oddometer: 72
It'd be a "hope for the best" with the Chinese HID kits. Some focus better that others I hear. Heat might be an issue in the Elefant's buckets also. If you haven't already upgraded the headlamp wiring that's worth at least 20 extra watts also. That and fresh bulbs is all I've done to mine and they're plenty bright.
Originally Posted by rarebear View Post
Hi all- Paul from Australia, i have a 1990 900ie elefant and was wondering if there's a HID headlight kit that will fit this bike that someone out there would recomend?
Yep the ol' "fit 65wt bulbs and the battery goes flat after extended running trick!!"
Can i fit a generic Chinese HID kit and hope for the best?
Thanks in advance Paul
'95 Elefant
'84 XL600R
'81 900 SD Darmah
Bevelhead is offline   Reply With Quote
Old 07-02-2012, 09:10 AM   #512
MotorCade
Rugby whore
Oddometer: 457
dual throttle cable?
Ok, so recently I purchased two 1994 Elefants... I just noticed a difference between the two. One is more stock than the other, and has two cables from the throttle. The other apparently used to have two cables, but now only has one. Both bikes seem to perform identically - I twist the grip and the trees move faster.
Without having to pull the fairings off and puzzle over a few things, can anyone tell me why the twin cable setup?
Thanks,
Cade
MotorCade is offline   Reply With Quote
Old 07-02-2012, 01:18 PM   #513
Wyvern
Wyvern's Avatar
Oddometer: 1,372
The main throttle cable pulls against the spring tension and is always tensioned in the pull direction.
The "push" cable only pulls if the throttle hangs up. It "pushes" or "floats" its entire life.... unless the slide hangs up.
I've seen many more problems with the "push" cable on modern 4 strokes than with the "pull" cable.
here is an interesting discussion bout twin cables
http://www.thumpertalk.com/topic/481...tle-cable-why/http://www.thumpertalk.com/topic/481...tle-cable-why/
Enjoy life ... eat out more often
Wyvern screwed with this post 07-02-2012 at 01:25 PM
Wyvern is offline   Reply With Quote
Old 07-02-2012, 02:25 PM   #514
Gone14s
Gone14s's Avatar
Oddometer: 107
Agreed!
Kurt
Def. of man:
We spend 9 months trying to get out, and the rest of our lives trying to get back in.
http://s1085.photobucket.com/albums/...900%20elefant/
Gone14s is offline   Reply With Quote
Old 07-02-2012, 02:54 PM   #515
MotorCade
Rugby whore
Oddometer: 457
Well, I'll be darned. thanks.
Old 07-03-2012, 10:08 AM   #516
bwallca
Oddometer: 128
The discussion on thumper talk is about 'thumpers' not twins, different situation. Some Ducati twins have a separate cable for each carb, others have a single cable going to a splitter which then goes to each carb.
Ben
bwallca is offline   Reply With Quote
Old 07-04-2012, 09:47 AM   #517
Wyvern
Wyvern's Avatar
Oddometer: 1,372
The ele is a double cable to an actuating rod . (not a cable for each one)
A twin cable set up is just that, a cable for each carb.
The Fant is a push pull (I have even had to temp ride with just the pull).
A push pull to a single carb or a mechanism that operates 1 (or more) are all the same
Old 07-04-2012, 02:46 PM   #518
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,550
Originally Posted by azcagiva View Post
Speaking of using an old unrepairable bike... this is what I will be running in the upcoming Mexican 1000.
-John
the con rod on the early modles always failed at speed.george at up/tite will be able to help you with this.
ancient adventurer
bajaburro is offline   Reply With Quote
Old 07-04-2012, 04:00 PM   #519
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
We ended up running my 72sl350. 888 was our number, it was the oldest and loudest bike in the race.
I told Malcom Smith that I was thinking of running my 510 but built the 350 instead he said that 510 would have blown up. His bike did but they were able to put a new top end on it on the side of the road. The husky would have been cool but I think the 350 turned out to be a good choice.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 07-05-2012, 06:13 PM   #520
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,550
so
so tell us,how did it go????????
ancient adventurer
Old 07-05-2012, 09:05 PM   #521
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Well, the first day we were doing really well, 5th overall out of 23. On the second day we had some mechanical issues which cost us 4 hours. We finished 2nd in our class (of 2) and 11th overall. Only four vintage bikes the rest were modern.
Great time got to meet some cool people.
Here is the thread A tale of two twins I think, bajaburro you will like our team logo.
-John
azcagiva screwed with this post 07-05-2012 at 09:27 PM
Old 07-09-2012, 03:45 PM   #522
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,550
good
good to have finished after all that drama.i'm sure you will cherish that finisher pin.
ancient adventurer
Old 07-09-2012, 06:52 PM   #523
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
The trophy is really cool.
Here it is on the back of the bike
The mexican 1000 would be a great rally to ride an elefant. There were a few tough sections but any good rider would have no problem on a fant. I am considering it myself.
-John
Old 07-10-2012, 03:58 PM   #524
ptr
Elefant-Tamer
ptr's Avatar
Oddometer: 57
hi
all ...
finally back in the forum. appended a short pic-story of modifications during this times
removal and overhaul of the engine
remounting
cockpit conversion to rallye-version
ignition modification to ignitech
somewhere in Switzerland on a test-ride to Marseille three weeks ago.
no pix available from today completed extension of the headlights.
just for pleasure
best
ptr is offline   Reply With Quote
Old 08-01-2012, 07:25 PM   #525
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 564
chain slider
Anyone want to talk about whittling out your own chainslider ?
I've never done it, but am about to be forced into it if I am to keep riding my Elefant.
Any tips or time/money saving advice for me before I start in on it solo ?
-CLC
"It's not a death machine, Mom, it's a LIFE machine" - a motorcyclist
Chadleys1 is offline   Reply With Quote
Times are GMT -7.   It's 06:29 PM.
