Old 07-29-2012, 12:11 AM   #1561
kajj
kajj's Avatar
Oddometer: 192
I have been waiting for this one
kajj is offline   Reply With Quote
Old 07-29-2012, 04:00 AM   #1562
jdrocks OP
Gravel Runner
Oddometer: 4,477
get those DRZ forks on there, easy swap. you'll never catch the V649 on those rough roads without them.
jdrocks is offline   Reply With Quote
Old 07-29-2012, 09:32 AM   #1563
kajj
kajj's Avatar
Oddometer: 192
Hehe, wanna race
I will do the fork swap during the coming winter. Also gonna swap the spring on the R1 shock.
Old 07-29-2012, 02:01 PM   #1564
jdrocks OP
Gravel Runner
Oddometer: 4,477
Hehe, wanna race
no contest there sonny, got the edge...suspension and cop motor.
Old 08-01-2012, 11:42 AM   #1565
kajj
kajj's Avatar
Oddometer: 192
hehe. well you better watch out next summer.
I have a few questions about the drz fork swap. How do you experience the brake capacity now when you only have a single disc brake?
Also, I now that I will need a 1.5mm thick sleeve to shim the lower triple clamp to the drz fork. How about the diameter of the wheel axle? Is it the same as the dl100? Can I use the versys axle?
Old 08-01-2012, 07:01 PM   #1566
marguyo
marguyo's Avatar
Oddometer: 32
i have stock front break drz 400 (caliper and disk) and stock master cyl versys 07, and ebc break pad ,next season i put a 285 mm disk and organic pad because my breake levl are strong and little bit poor to breake on sport cruising or emergency situation
all have two wheels which deserves to be run
marguyo is offline   Reply With Quote
Old 08-01-2012, 08:39 PM   #1567
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Looking over parts- god this thing is going to do my head in!
i am not looking to build a dirtbike out of this machine- something suitable for gravel roads will be fine. I assume I can get away with the stock triples for something like that?
I won't jump the bike, and to be honest doubt I'll so much as do a wheelie (I pulled several withthe bike from new while IW as trying to learn how to ride.. but haven't been able to figure it out since!!).
I'd be pretty happy to have this as a naked, long-suspension bike with street tires. Something akin to the KTM Duke, I think?
JAFO is online now   Reply With Quote
Old 08-02-2012, 05:54 AM   #1568
2fast4u
Oddometer: 747
Its only going to be long-suspension in the front. With the versys shock or r1 sho
ck its around 6" to 61/2".
I have a r1 shock, xr forks 41 mm, and SM motech motor guards if interested pm me.
2fast4u is offline   Reply With Quote
Old 08-02-2012, 11:57 AM   #1569
JAFO
JAFO's Avatar
Oddometer: 3,975
2Fast, those parts are mine.... thanks for the deal!
Old 08-03-2012, 01:32 PM   #1570
jdrocks OP
Gravel Runner
Oddometer: 4,477
brakes are fine with the OEM caliper, braided SS line, and either 290 or 310mm rotor. you might as well use a 310mm setup because you're going to fabricate a simple spacer/relocation bracket. i have a 4 piston caliper, but i feel the brakes are darn good without it. remember, you need a pair of rotors, because you're going to cut the center out of one for a hub block off plate on the right side.
late model DRZ400 uses the 20mm axle, same as the DL1000 wheel. the Versys and DRZ axles are the wrong length, so to make the correct size 20mm axle i used the Versys/ER6 swingarm bolt threaded and cut to length. these bolts can be found cheap.
Old 08-03-2012, 01:34 PM   #1571
jdrocks OP
Gravel Runner
Oddometer: 4,477
yup, go bigger.
Old 08-03-2012, 01:44 PM   #1572
kajj
kajj's Avatar
Oddometer: 192
ok, Thanks.
Old 08-03-2012, 01:52 PM   #1573
jdrocks OP
Gravel Runner
Oddometer: 4,477
in that case, i would build the LSL Urban X...clone it, my favorite in a 100% street bike built around the ptwin platform.
Old 08-04-2012, 07:39 AM   #1574
jdrocks OP
Gravel Runner
Oddometer: 4,477
out with a some buddies who were riding a pair of well equipped Dr650s, we took a break after a winding and near continuous 20 mile climb up the mountains on gravel, some seriously rough roads in there. the V649 was running well, i was whipped and needed a stop. over 200 miles of gravel roads before we were done.
interesting that the DR bikes banged the skidplates on the way up, while the rat didn't touch anything, plenty of ground clearance.
the V649HP passed the 20,000 mile mark on this trip, i'd say the design concept is proven.
Old 08-04-2012, 09:21 AM   #1575
kajj
kajj's Avatar
Oddometer: 192
Times are GMT -7.   It's 12:57 AM.
