07-27-2012, 10:30 PM
#4801 | ||
Красное октябрь
Oddometer: 150
Always do sober, what you said you'd do drunk. That'll teach you to keep your mouth shut. Ernest... 2000 Ducati 996::Several XRs |
07-29-2012, 01:05 PM
#4802 | |
Oddometer: 9
Sent from my iPad using Tapatalk HD |
07-30-2012, 03:27 AM
#4803 | |
Grumpy Old Bastard
Oddometer: 6,492
Check his references and maybe have a look at a past job of his.. Garages are really very simple for a competent builder. |
07-30-2012, 04:20 PM
#4804 | |
breaking wind
Oddometer: 2,569
I thinking of using this type between my ceiling rafters and the roofing and wonder if there needs to be a air gap between the roof decking and the foil? Thanks.
* 05FJR/74R90s * If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles. |
07-30-2012, 05:05 PM
#4805 |
Cupcake
Oddometer: 7,905
I'm not a builder nor do I play one on TV but they make plywood sheeting that has foil bonded to one side now. In California if you build with it and insulate you have yourself a "Green Roof" and get a tax credit for it (I did not use it but I did insulate to R38 in the ceiling and installed an attic fan).
Gerg
Greg ![]() OFFICIAL WARPED BEER MEISTER BOOF 160, AMA, RA, MOA, HOG Live life like you stole it! Your $5 off SMUGMUG Coupon is hESgLtqESqM1Q |
07-31-2012, 07:19 AM
#4806 |
Oddometer: 2,442
You have to have airflow, underneath your roof sheeting, to allow for moisture removal and cooling effect. I've seen frost, on the bottom-side of sheeting, in the winter. Not having that airflow, will void some shingle warranties, depending on the company and their inspector.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
07-31-2012, 04:32 PM
#4807 | |
t00 0ld 2b n00b
Oddometer: 1,284
You staple it to the bottom of the rafters, not to the top near the roof decking, so there's plenty of space. It's easy to install and works great, keeping the heat in in the winter and out in the summer. I wouldn't build anything without it. |
07-31-2012, 04:57 PM
#4808 |
Oddometer: 72
Haphazard,
did you use the Tekfoil with traditional fiberglass insulation in the walls and ceilings? |
07-31-2012, 05:41 PM
#4809 |
t00 0ld 2b n00b
Oddometer: 1,284
In the garage, no. I just stapled it over the empty wall cavities and the bottom of the trusses. Very quick, works great and REALLY brightens up the interior.
In my addition, yes. The only thing to be aware of is that Tekfoil is a vapor barrier. If your fiberglass insulation has a vapor barrier (like Kraft paper) slash the paper with a knife so you don't have 2 vapor barriers and get trapped moisture. Also, the foil/bubble wrap/bubble wrap/foil material I used is quite thick - if your are sheetrocking over it, use longer screws, and plenty of them. |
07-31-2012, 05:48 PM
#4810 |
breaking wind
Oddometer: 2,569
08-01-2012, 07:57 PM
#4811 |
VALE 46!
Oddometer: 958
Epoxy question. Previous owner of my new pad did the garage floor with the Rustoleum epoxy kit from Home Depot. He must have done something incorrectly because it's basically turning to dust. All of the better quality products seem to want you to have pristine cement. The Rustoleum product, while not the best quality, says you can apply it over top of an existing Rustoleum floor. If I recoated it then sealed it with an atrocious amount of clear coat would this hold up or am I just creating a shit show?
GET SMUGMUG NOW. $5 off code hYt2lOVPfVbjc 2007 KTM Adventure 990 2005 HD Road King (yeah yeah, I know) |
08-01-2012, 08:36 PM
#4812 | |
Oddometer: 414
Do some research but when I had my ( brand new) homes garage floor epoxy coated in PA they etched the floor with a muriatic acid wash the night before the epoxy finish went on. This was on a new concrete floor. I had spilled some motor oil on it and I told them was concerned the epoxy may not adhere to the area of the oil spill so they first washed the floor with muriatic acid. Not the kind of stuff you want to have a mishap with...dangerous stuff. The floor looked good for the 12 years I lived there. Sounds like you have some stripping to do before etching the floor. You may only have to strip the loose stuff, but you gotta think the more you remove the better the floor will look and the longer it will last. Maybe rent a rotary floor scrubber with a big 3M scotch brite pad to remove all the old Rustoleum. http://www.naturalhandyman.com/iip/infxtra/infmur.html Tech23
CRF 150/230/ Supermoto Conversion 2004 Suzuki DR 650SM 2000 Harley Davidson FXDWG |
08-02-2012, 05:53 AM
#4813 | |
"Cool" Aid!
Oddometer: 41,488
From here: http://garagejournal.com/forum/forumdisplay.php?f=20 Pretty much you need a very well prepped floor for Epoxy to stick over the long haul. Most of the professionals (they allow vendors to post what they want there) say it is best left up to a pro to get lasting results. From lurking there for a while it has become obvious that even pro work is a bit hit and miss. The prevailing trend has moved towards Porcelain Tile as the most durable, and DYI friendly, flooring system. Jim
08-02-2012, 08:54 AM
#4814 | |
Oddometer: 2,442
I've seen numerous epoxy kits, on the market. But, I've not seen a DIY kit that'll do what a professional can with industrial grade products. This is one area where "You get what you pay for." applies.
08-02-2012, 07:58 PM
#4815 | |
maximum shrinkage
Oddometer: 711
Happily consuming fermented beverages since 1974. "We are of two groups: 1, beer drinking, mechanically inclined, semi-normal airhead riders, and 2. the others."- Mista Vern |
