Go Back   ADVrider > Riding > Mapping & Navigation > GPS 101 - Which GPS For Me
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-01-2012, 03:50 AM   #1
LarryGee OP
Oddometer: 356
Garmin 550 - Can't find device
Open mapsource on Mac, using windows platform in parallel
plug my Garmin 550 via usb.
attempting to transfer tracks/routes from garmin to mapsource
window pops up "can't find device"
The device is registered. Has current maps.
What am I doing wrong?
LarryGee is offline   Reply With Quote
Old 08-01-2012, 04:57 AM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,939
Make sure the device is allocated to the Windows side; it can only be seen by one OS at a time, so look at that first.
Emmbeedee is online now   Reply With Quote
Old 08-02-2012, 05:23 PM   #3
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,430
Have a look here: http://www8.garmin.com/products/communicator/
This little bit of software makes the connection between your gps and mac/pc. Installing this will install USB drivers you need so the pc/mac sees the GPS.
Don't know if this is the problem, but worth taking a look.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 08-02-2012, 07:46 PM   #4
LarryGee OP
Oddometer: 356
Don't know how you would tell the device to allocate itself to one OS or the other.... Not on any settings. But, I don't think that's the problem because it won't work in Mac (Basecamp) either.
Old 08-03-2012, 04:21 AM   #5
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,939
In Parallels, this is how you check which OS has control of the device, and how you assign it to one or the other;
Old 08-04-2012, 05:10 AM   #6
LarryGee OP
Oddometer: 356
[QUOTE=Emmbeedee;19275583]In Parallels, this is how you check which OS has control of the device, and how you assign it to one or the other;[quote]
Excellent! Thank you very much for that. I was looking for it on the device.
I wound up calling Garmin and here was the issue(s).
1) They said you must have your power cord plugged in, even if you have a full battery. Something about the device needs whatever the power cord provides and battery doesn't. Didn't understand him.
2) Picky USB ports. He said sometimes, the device doesn't like the USB port you plug into. I swear. That's what he said.
Doing those two things... the laptop found the device... go figure....
HTML code is Off
Times are GMT -7.   It's 06:49 AM.
