Old 01-29-2011, 05:06 PM   #16
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Video of dimmer
Installed using 3M strong plastic velcro. This dimmer is exactely what I was looking for since installing these super bright LED's, LED's are way too bright when it gets dark outside, the only other option would be pointing the beam downwards but then what would the lights be good for?
tallguy-09 screwed with this post 02-01-2011 at 10:37 AM
tallguy-09 is offline   Reply With Quote
Old 01-29-2011, 06:02 PM   #17
DiscoDino
DiscoDino's Avatar
Oddometer: 1,812
Thanks Tallguy-09...was that German Satellite radio ?
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 01-30-2011, 05:21 AM   #18
JamesK
JamesK's Avatar
Oddometer: 90
Send a message via Skype™ to JamesK
This looks like a great product.
2007 FJR1300A - 150K Miles Club
If you see my bike on a trailer call 911
TBA 904, IBA 27221
JamesK is offline   Reply With Quote
Old 02-04-2011, 10:44 AM   #19
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
I like the clean install of only having one switch and the dimmer controller away from the handlebar better than the potentiometer/switch combination. For me two brightness settings with the switch and a 3rd. with Hi-Beam is sufficient.
Old 02-07-2011, 08:11 PM   #20
cobrags
Lost ADVR
cobrags's Avatar
Oddometer: 546
Originally Posted by tallguy-09 View Post
Can you tell me Where/Name to get the dimmer switch?
I like this module also but been looking for waterproof dimmer also.
ChildsPlay Riding
ChildsPlay Racing
Of all the roads you take, Make sure a few of them are dirt.
cobrags is offline   Reply With Quote
Old 02-11-2011, 06:26 PM   #21
NomadS
Oddometer: 62
Originally Posted by jskene View Post
This product is now available here:
http://skenedesign.com/lights/IQ_170.shtml
any discount code for advrider.com inmates?
NomadS is offline   Reply With Quote
Old 02-14-2011, 06:59 AM   #22
jskene OP
jskene's Avatar
Oddometer: 182
We have a safe rider rebate on our P3Lights and Photon Blasters.
In order to encourage rider training, we offer a $20/set rebate on these systems:
http://www.lights.skenedesign.com/Rebate.shtml
________________________________________________________________________________
Visibility Lights - P3 Lights and Photon Blaster High Intensity Motorcycle Visibility Lighting Systems: Be Smart - Be Seen
jskene is offline   Reply With Quote
Old 02-15-2011, 08:28 PM   #23
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Received controller with updated software in exchange for the first one, now also working great on the BMW (R1200GS)
with delayed hi-beam on after ignition is being turned on (basically you have more time to enter programming mode...)
The dimmer now has a wider adjustment range at the lower LED brightness levels.
I'm not affiliated with the seller but that's really a nice product that intelligently fills a market niche.
Old 02-15-2011, 10:28 PM   #24
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 748
Thumb
Rocket Moto proudly sells and offers professional installation of all Skene Design safety lighting products, for over a year, now.
Terrific, innovative products from great company.
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your personal ADVRider discount code to use at RocketMoto.com
Autocom | Clearwater Lights | Sena Bluetooth
| Scala Rider
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 03-31-2011, 07:37 AM   #25
jskene OP
jskene's Avatar
Oddometer: 182
I have customers asking where to get the auxiliary switch shown to the right of your stock switches in your photo below.
Do you have a recommended source for this?
Old 03-31-2011, 08:14 AM   #26
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Hi Jerry:
I got it from here in the US:
http://www.cyclenutz.com/Mini-Handle...tch_p_210.html
Didn't like the cross lines on the switch so I took a sharp knife an removed them... also you can re-route the cable so it exits on the bottom.
The same switch I've seen in red in Germany at Detev Louis:
http://www.louis.de/_4036fd065f41a26...artnr=10032918
I like your controller, works very well, thanks for a great product.
Old 08-04-2012, 01:35 PM   #27
jskene OP
jskene's Avatar
Oddometer: 182
We have updated our popular IQ-170 Intelligent Lighting Controller with our unique ALERT feature. Simply double-tap your brakes to rapidly flash your auxiliary lights on & off for a second or so to ensure that you are noticed by oncoming traffic.
We have carried this feature over from our Photon Blaster front visibility lights, where it has received an extremely positive response.
Note that the flashing rate and sequence is very different from a normal high beam flash, so it will not be confused as such.
The new model offers the same LED lamp programmability as the original IQ-170, allowing you to set the brightness of your auxiliary LEDs to any brightness and rapidly switch between three different pre-programmed values, with a high beam override. It is compatible with virtually all aftermarket LED lamps of up to 60 watts power consumption.
More details plus a video of the ALERT feature may be found here.
jskene screwed with this post 08-04-2012 at 01:59 PM
Old 08-09-2012, 08:00 AM   #28
jskene OP
jskene's Avatar
Oddometer: 182
Some of our customers have asked whether our IQ-170 LED dimmer will work with their particular brand of LED. While we haven't tested every LED brand, we have tested our controller with several of the more popular brands, and have seen no issues.
Some LEDs can generate voltage spikes when they are turned off, and these spikes could potentially cause damage to the controller or the LED. Our controller's design includes circuitry that limits the voltage of these spikes, should they occur, minimizing the chance that they will cause any problems.
Many of our controllers have been in use since they were introduced last year and we have yet to see an instance where there was an incompatibility.
Old 01-31-2013, 08:34 AM   #29
greendy
greendy's Avatar
Oddometer: 22
Noob Question
Can the IQ-170 be wired in to the existing high beam switch. I have a 2003 BMW 1150GSA and don't really want another switch on the bar. I ideally id like to tap in to a daytime running lights (cdn bike) to power the LEDS's and then use the high beam switch to supply full power to the LED's. I am on the right track??
Any help you can offer would be super helpful
Thanks in advance for your info !!!
Your not lost until you're out of gas and money!!
greendy is offline   Reply With Quote
Old 01-31-2013, 08:47 AM   #30
LukasM
Oddometer: 4,900
Hello Jerry,
I sent an email to the support address given on your website, please let me know if you received it.
Best regards,
Lukas
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Times are GMT -7.   It's 12:50 AM.
