Old 08-09-2012, 01:23 PM   #1
Tr25w OP
Oddometer: 42
kx250 frame + lifan questions
My friend has a 92 kx250 roller(no motor). I see these lifan 200cc motors and thought it might be a good combo. What would be needed for the wiring since a kx250 doesnt have a battery?
Tr25w is offline   Reply With Quote
Old 08-09-2012, 07:26 PM   #2
tntmo
Oddometer: 505
You'd probably be best to just get an entire Chinese 200cc dirt bike and rob everything you need including a wiring harness. Everything I read about them says that the strong point is the engine, and the frame/suspension/wheels are junk.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 08-09-2012, 07:40 PM   #3
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,620
Pretty much what i have learned from people that I know that have them.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 08-12-2012, 10:56 AM   #4
hugemoth
hugemoth's Avatar
Oddometer: 2,944
You'll need the regulator/rectifier if you're going to run lights. It regulates the AC current as well as the DC. You'll also need the CDI unit and coil.
The Lifan 200 engine comes in at least 3 types, push rod, push rod with balance shaft, and OHC. I have the push rod type with balance shaft in my Lifan motorcycle. The engine is excellent if not overly powerful, it now has over 37,000 miles on it with no problems.
Old 08-12-2012, 12:14 PM   #5
JagLite
JagLite's Avatar
Oddometer: 1,302
Thumb Lifan
+1
I am watching for a complete bike to transfer everything over to the RM250 rolling chassis I have.
It is much easier to start with a running bike than to figure out why it won't start when getting just an engine.
Lifan and several others have excellent reviews of their engines.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 08-12-2012, 03:26 PM   #6
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,849
I toyed with the idea of doing this to a 2000 RM 250 i have sitting around that I never ride. Keep us posted if you move forward.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is online now   Reply With Quote
Old 08-13-2012, 04:50 AM   #7
hugemoth
hugemoth's Avatar
Oddometer: 2,944
Sellers of Lifan engines often supply everything you need as a kit. Engine, carb, manifold, CDI, rectifier/regulator, coil, kick start lever, shift lever, etc.. I've bought 3 engines this way and installed them in old Hondas. Makes it real easy. Wiring was straight forward and jetting in the supplied carbs was perfect.
Originally Posted by JagLite View Post
+1
Old 08-13-2012, 11:17 AM   #8
bobfab
bobfab's Avatar
Oddometer: 1,465
x2, thats what i have seen too!
CRF250L | KTM200SX
bobfab is online now   Reply With Quote
Old 08-15-2012, 01:53 PM   #9
JagLite
JagLite's Avatar
Oddometer: 1,302
Thumb Lifan complete
That's good to know! Do you recommend any of the sellers? Link?
I should have clarified that I am looking for a complete bike that is street legal to transfer everything over to make my RM a street legal trail bike.
Our laws here in Alaska don't allow a bike to be made legal unless it came that way from the mfg and says so on the title.
I will just get the title changed when I install my "custom" frame and get a state supplied VIN #.
I hope to find a 200cc street bike donor eventually.
If you only want a dirt bike engine, the electrical on it is simple!
Attitude ~
James
Old 08-21-2012, 10:14 AM   #10
hugemoth
hugemoth's Avatar
Oddometer: 2,944
Sorry about the delayed response, I've been doing some Lifan riding in the wilds of BC Canada.
I've bought new engine kits from hooperimports.com and dratv.com but I'm sure there are many other legit sellers.
Old 10-26-2012, 11:18 PM   #11
ibhayirob
Oddometer: 3
hi there q
are you putting honda clone lifans in your bikes or is frame modification required
tks
rob
ibhayirob is offline   Reply With Quote
Old 10-27-2012, 05:32 AM   #12
hugemoth
hugemoth's Avatar
Oddometer: 2,944
All the Lifan engines I've used are Honda clones. Minor grinding and drilling on the frame is required. These are the bikes I've done.
Lifan 110 into 1971 CT90.
Lifan 140 into 1968 CT90
Lifan 110 into 1965 Honda Cub
I also own a Lifan 200 GY5 motorcycle with the OHV vertical engine.
Originally Posted by ibhayirob View Post
hi there q
tks
rob
Old 10-27-2012, 09:15 AM   #13
Salsa
Oddometer: 400
Is the OHC better?
Which of the three is preferred?
Don
Salsa is online now   Reply With Quote
Old 10-27-2012, 10:51 AM   #14
hugemoth
hugemoth's Avatar
Oddometer: 2,944
All the horizontal engines are OHC. The majority of vertical engines sold are OHV which they say have a better power curve for dirt bike and dual sport use. There were some OHC vertical engines used in street bikes imported to the US.
The OHV vertical engines are clones of the Honda CG125 which is one of the most bullet proof engines ever made. The OHC vertical engines will eventually wear out the cam chain but otherwise are very similar in design.
BTW Lifan makes many different engines including parallel twins, V twins, shaft drive engines, liquid cooled engines, forced air cooled scooter engines, generator engines, industrial engines, car and truck engines, etc..
Originally Posted by Salsa View Post
Is the OHC better?
Don
Times are GMT -7.   It's 10:55 AM.
