Old 08-06-2012, 07:11 AM   #16
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Try the HUBB bulletin board for Latin America. You might even find someone nearby where you live who has done the trip. Send me a PM if you want and I can hook you up with a few people who have done exactly what you have planned.
Old 08-12-2012, 06:09 PM   #17
davidadv1 OP
davidadv1's Avatar
Oddometer: 97
Update!
Got a call from the dealer and the ECU is bad..
So thank god it didn't happen when I was in Ushuaia
So if you have that code.. It not just might be
The $36 ring! Thank god I have warrenty
davidadv1 is offline   Reply With Quote
Old 08-13-2012, 07:42 AM   #18
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Did they say what caused it?
Old 08-13-2012, 08:12 AM   #19
OnkelPopanz
Oddometer: 64
EWS means Elektronische Wegfahrsperre and shows that there is an issue somewhere in the anti-theft-system.
This can be the antenna our something else.
OnkelPopanz screwed with this post 08-13-2012 at 08:17 AM
OnkelPopanz is offline   Reply With Quote
Old 02-27-2015, 05:53 AM   #20
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
ok lads. EWS Error code on my bike now. Bike starts fine but won't shut off. Who has his money on ring antenna?
For those wondering about the ignition switch problem that I had about 2 month ago I checked with a new ignition switch (well I bought a used one, you never know) and that's not it.
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is online now   Reply With Quote
Old 02-27-2015, 05:57 AM   #21
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
Heading to the dealer to get some bearings for my 1150, will ask him to read out my 800GS. We'll know in a couple of hours. Fingers crossed.
Old 02-27-2015, 07:28 AM   #22
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,806
You need a new battery in your box.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 02-27-2015, 07:41 AM   #23
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,806
Or else it's the 700GS float you just put in it. Did you reshield the wiring? Was the battery disconnected for this?
I bet the ZFE got wrecked as well.
Old 02-27-2015, 09:53 AM   #24
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
Battery is definetly not the problem. Going more than strong.
Read the fault codes on the bike. Were alot of them since it has last seen a dealer but nothing concerning the EWS error. Last on date was me disconnecting the odo and before that 2k kms ago telling me that my heated grips stopped working.
The battery was disconnected for the fuel pump. Wirings didn't need reshielding or anything, they were perfect.
Talked with the BMW mech' about the fuel pump but he didn't think that this was it, neither the ring antenna since it's starting. Went for a 100km "ride in" for the tires and the fuel pump and now back at home the bike stays shut off. Weird electrical gremlin. My money is on the fuel pump and the ECU needing to adapt to the new sensor + battery disconnect.
Maybe that is why they write on the plastic seal thingy above the fuel pump "do not disconnect battery"? Inside news Reaver?
What the fuck is ZFE?
Old 02-27-2015, 10:09 AM   #25
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,806
Old 02-27-2015, 10:13 AM   #26
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,806
Pay attention boy.
The shielded wiring thing was just to confuse you. It worked too well.
The plastic thingy about disconnecting the battery???? The one that says "Don't rest the battery here dipshit, it's heavy and you'll wreck the wiring or break the plastic fuel barb". That plastic thing?
OK, your alarm box under your seat likely needs new batteries. Ever change those things?
Old 02-27-2015, 10:17 AM   #27
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
remember what we said with you and PUI? didn't end up that well last time now did it
Old 02-27-2015, 10:19 AM   #28
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
yeah the one saying keine batterie abstellen
Old 02-27-2015, 10:24 AM   #29
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,806
http://www.advrider.com/forums/showthread.php?t=314289
Old 02-27-2015, 10:26 AM   #30
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,715
yeah but for that i need an alarm system don t i
Times are GMT -7.   It's 02:47 AM.
