04-03-2012, 03:05 PM
#991 | |
Location: Recent citizen of Stockholm. Earlier Boden, Sweden
Oddometer: 13
http://www.rolloxab.se/ Good service as usual. |
06-10-2012, 10:59 PM
#992 |
Sweden
Oddometer: 31
Electric failure
Hi
Just experienced a sad thing. Starter wont run. Turns out to be an uncharged battery. This is due to a broken regulator (The aluminium thingie next to the horn) Replaced it and all was fine until today. The battery is not charged enough to turn the starter but fuelpump and all other gadgets work just fine. My conclusion is: Alternator broke down again.. :-( . I will replace it but it is likely to break down again if i can not find the source of my trouble. What say you? Battery?, Stator?.... /TF |
06-15-2012, 11:05 AM
#993 | |
Olli
Oddometer: 27
I think the batery. Try with a car batery. Olli
--------------------------- Highland 950 Outland 1999 still with carb. Suzuki DR 650 R 1992 Honda CR 250 R 1994 BMW F800GS 2010
06-15-2012, 11:55 AM
#994 |
lizards,bugs and me
Oddometer: 525
triple application
06-21-2012, 11:03 AM
#995 |
City Dweller Crushperado
Oddometer: 283
Thumber:
I've been chasing some of the same issue with the electrics. i keep throwing parts at the bike with fleeting joy. I just ordered one of the sealed led voltage indicators from an inmate on vendors and will mount it on the bike to try and catch what is going on with the electrics before I toast another battery. Pennswooded NSX found a KTM triple don't know if it worked out for him or not. |
06-24-2012, 10:15 AM
#996 | |
Oddometer: 76
I really want to find a dual inlet system like John in Leeds uses and was developing, but it seems unlikely now. John hasn't posted anything in over a year. In one of his last posts he said: "With regard to the 'twinlet' system, Keithy has started machining the throttle bodies this week and is likely to be casting the manifold shortly. He is fully set up for a prototype and small production run so as soon as we have tested it we'll let you and the other members of the Highland brotherhood know. Rest assured we expect a simple to fit sytem that even I could do. However, unless you have access to the ecu mapping equipment where I could send you an appropriate map then we'll have to arrange some sort of system where the ecu will be sent off for mapping and then returned. Lots of details to sort out including price because obviously Keith will have to be paid for his expertise and efforts." Late last year Keithy posted pictures of the manifolds and said "I'll possibly have it cast and machined for spring....then find a victim to test it as John's engine let go" Then nothing. As I said, it doesn't look good. |
07-18-2012, 01:37 PM
#997 | |
Oddometer: 13
I fixed that and the rev counter works again but it does not charge the battery. How did you find out that your regulator was broken? What did you pay for a new one? Does anyone have the values to measure the alternator wireings to find out where my problem is? |
07-24-2012, 11:16 AM
#998 | |
Oddometer: 13
I solved my charging problems. One of the windings in the stator were loose. |
07-25-2012, 09:10 AM
#999 |
Oddometer: 283
950 - Glad you solved the charging issue.
With any luck I will be right behind you with a success story. What kind of out put did you get on the failed vs corrected stator? |
08-11-2012, 07:05 AM
#1000 | |
Oddometer: 5
Do they sell manuals too? |
08-15-2012, 05:25 AM
#1001 |
Oddometer: 13
08-15-2012, 05:57 AM
#1002 | |
Oddometer: 13
Infinite ohm through the stator. Connected a separate rectifier (cheap bridge with 4 diodes and 100V/25A specs) and no regulator. 8V at 3000 rpm and 12V at 7000rpm without any load means no charging capacity. Just the voltage that could "jump over" via the broken windings. If measured with the battery and regulator/rectifier you will just get the battery voltage which was decreasing when riding around. Fixed stator: Almost short circuit (approx 0,3 ohm) through the stator. When connected to the battery and regulator/rectifier the voltage is up to around 13,5-14V (about +1-1,5V more than the battery itself. The hard part was to get the hard "glue" away from the connection points. I used a soldering iron to loosen it up and were very cautious not to damage the wiring isolation. I used PL400 to fasten everything again after clamping and soldering the loose ends. |
08-16-2012, 10:10 AM
#1003 |
Oddometer: 283
Thanks 950
I got a new to me garage that is getting sorted out and will give the multi meter a go at the Highland. All I need now is multi-meter for dummies book. |
08-28-2012, 04:48 AM
#1004 | |
Sweden
Oddometer: 31
Since you are based in sthlm i assume your swedish is alot better than my english... could you please give me a ring? I live in Vallentuna. noll sju 02- sextioåtta 42 fem2. I need to find a way to take the flyweel off... |
08-30-2012, 01:44 PM
#1005 | |
Oddometer: 13
