Old 08-15-2012, 05:05 PM   #1846
Shibby!
Oddometer: 1,658
Originally Posted by jules083 View Post
I see the pics and the mods of all of you guys, and there are some sweet looking pigs here. I was thinking about buying a DR650 for a second bike to use for longer rides, but a few deals fell through and now I am thinking about just setting the XR up a bit better.
My main questions are reliability, maintenance, and comfort.
How long are the motors/transmissions really good for, taken care of? I see a lot of conflicting stuff here all of the time, with numbers ranging from 80,000 to 20,000. Any rough ideas on when I'd be changing things like a crank, or internal transmission stuff? Piston and rings?
What oil change intervals are they actually good for? I know honda says 600, I've been doing them sooner and don't even have a speedometer or odometer, so I guess at this stuff.
Comfort wise, fix the seat, change gearing, and maybe a small bit of wind protection, right? Any recommendations on seat? Everything else I can figure out myself, but the stock seat is terrible. I have no natural padding.
I see luggage stuff being all over the map, and subframe concerns going every which way. It seems like I should be fine with the Giant Loop Coyote, right? Most of the breakage I've seen has been from way more stuff strapped on than just that. I'll probably have to strap a few things on the outside of the bag, maybe a tent, but nothing too heavy. Any and all heavy tools should be elsewhere somewhere, I haven't came up with a spot yet.
Thanks. I was kinda excited to have two dual sports and keep the XR light, but it's looking like I'll be better off spending some more money on her and having the 'one bike fits all' attitude.
Where to start... I'll try to stay in order:
1) A modified DR650 makes an ideal adventure bike. It tops my list right now followed by the X-challenge and KTM690 and
2) No idea what people are saying, but unless they have first hand proof I wouldn't take it for much. There was a guy on here from Japan I believe with 80,000 KM when he rebuilt the top end, then put another 40,000 KM on it before I believe it was wrote off.
I personally have 35,000-40,000 KM on mine. It's "loose" but still rips! Not a single engine issue yet.
3) There's lots of talk but few people get their oil checked. I run with 2000 KM oil changes and filter on every second oil change. I'm sure oil tests would show 4,000-5000 possible.
4) I run a Seat Concepts foam and cover. For the price I think it's pretty good. Haven't tried others so can't compare other then knowing it's a big improvement over stock.
5) Windscreens make a HUGE difference. Definitely put one on. Doesn't have to be large. Depending on your set-up even a cut down 990 screen works wonders.
6) Between myself and my friend we have 15,000 KM of HARD dual sporting with Coyote bags and no subframe issues. I did switch mine out to a steel subframe and have put on an additional 28,000 km's. (I was running a Coyote and Wolfman Expedition saddles). These have been tested on everything from gnarly single track, back road bombing to Baja at race pace, even included a 4.5 ft drop to flat.
By the way, 1.6 KM/Mile.
I've done some rides with others and depends where and what you ride. Locally I wouldn't switch the XRR for anything else besides maybe a 530 / 450 / 570 converted dirt bike. On the road the XRR sways more towards an offroad mostly bike. It'll do highway but it likes to be offroad. A DR650 can do both, and I would say it's middle of the line. The 690 and X-challenge are both expensive, modifications required as well (expensive), and open the door to much more to go wrong. Simple is key. No electric start, no batteries, very little electrical, blank sheet for customization = All good in an adventure bike.
Those that have and push FI haven't had a bike not want to run three mountain passes back into the back country. Once again, simple = better. You can fix a carb on the side of a trail with simple tools.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 08-15-2012, 06:29 PM   #1847
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
VERY nice response.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 08-15-2012, 08:25 PM   #1848
jules083
jules083's Avatar
Oddometer: 3,963
Thank you very much for taking the time to type all of that. Excellent answer, and gave me at least some sort of idea for each of my questions/concerns.
That's what I've read, and what made me start looking for one. A dr was actually what I started out looking for a few years ago when I ended up getting the XRR
That's good to know. I imagine any dual sport that gets ridden hard is going to feel 'loose' after 40,000 KM. I'm assuming you mean all of the little stuff, like foot pegs, levers, pivot points, bolt threads starting to get rough, that kind of stuff.
Sounds about right. I guess when I get a real odometer I can judge that a bit better. I'm thinking trail tech vapor, it seems to give the basic information for about the right price.
Looks like a good enough seat at the right price, I'm putting it on my wish list.
I'll come up with something, but I know one will be a big help.
Right now I have a borrowed KLR from a friend, he has my XR. We are both wishing we had something in the middle of the two for longer days. I'm liking the wind protection and smooth ride/power. He's loving the extra 20 HP and the 100+ pounds lighter weight.
I'm still on the fence between getting a second bike, probably a DR, or just putting more stuff on the XR. I'm thinking I could get the XR close to the long ride ability of a DR with the right mods. I guess the trick is to do that correctly without losing any of the off-road ability that the bike is great at.
Simple is better for sure in my mind. We still have the water cooling to worry about though, but in almost 20 years of riding water cooled dirt bikes I've never personally had a failure. I've crushed radiators before, but never had one leak. Both of my XR's radiators are actually squeezed in a bit from the previous owner, but it doesn't seem to cause problems at this point. I would like to someday add a KTM fan, DC power, and a cord for my GPS. I'm still running AC only on everything.
One of my complaints on the XR is vibration, and I'm sure a lot of that is caused by a worn chain, stock gearing, and the Trackmaster II tires. The KLR I have been riding the last few days is smoother, but seems to have similar engine vibrations if that makes sense.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 screwed with this post 08-15-2012 at 08:42 PM
jules083 is online now   Reply With Quote
Old 08-15-2012, 09:00 PM   #1849
Shibby!
Oddometer: 1,658
No, the bike itself is holding in there just fine. No bolts rattle out (other than seat bolts?) and everything is fine. I've done no repairs to this thing other then normal wear items and a pinched oil filter cover o-ring. I do check the valves every 4000km too while doing the oil filter change.
By "loose" I mean the engine is pretty easy to kick over. The compression is still there, but the stroke between the compression is pretty easy. I can still do wheelies and powerslides at 90-100km/hr.
My bike has all the things you mentioned and every one is worth it. DC voltage isn't too bad depending on your existing electrical system and how it grounds. The fan and GPS power cord are great! I've never really had a problem with mine overheating, but I knew it was running hot and the fan adds peice of mind to that. I know it's cooling off faster when Im going slow, and at least keeping the temps at bay while stopped. I've rode in 44 degree heat in the city without any issues. Same with coastal humidity and Moab dryness (38 degrees).
On top of what you listed I have heated grips, 12v plug that I've never used..., and I think that's it. Oh! Another good thing about the GPS cord is you can charge a cell phone with it using an adapter. I've recently added a small battery under the seat to help smooth low RPM voltage and charge cell phones using the GPS cord at night. I have done and do a lot of random camping with this bike so that small source of power is great! It's not big enough to run accessories once the bike is shut off though. After about 2 minutes my HID will start to flicker (35w).
I think rad braces are a must as well. The stock skid plate on these are pretty good and the nice thing about plastic is they slide over trees and rocks (at least better than aluminum). That being said I have a Ricochet on mine. Rad braces are a must. I come from the bush and see a lot of crushed rads, some of them leaking, etc. Even being able to bypass one is a good idea. Otherwise cooling is good in my books. Keeps oil temps reasonable and requires minimal maintenance. The downside is its another thing to fail.
Old 08-16-2012, 04:30 AM   #1850
jules083
jules083's Avatar
Oddometer: 3,963
Awesome man, thanks. You convinced me I think, I'm going to give up on a DR for now and focus on this. Either way I would have a winter project setting one of them up, might as well set-up the bike I already own.
Edit- I just finished reading this thread start to finish, my wish list right now is huge. The key focus for me at this point is to do as much as I can without adding too much weight, or detracting from the bike's ability. The only real weight adding stuff is going to be a small tool kit and mount, some electronics like a real speedometer, and bike protection stuff, like the skid plate and some radiator braces. I'm hoping to avoid adding a rear rack, I don't think it will be necessary with a Giant Loop. I've looked for ways to save weight elsewhere on the bike, there isn't much 'extra stuff' that can be taken off.
Hopefully my 4-wheeler sells to fund the project, if so then I'll have a build-up post this winter. I like to tear bikes down over the winter and do everything, so if it goes right I'll have a box of new parts to go on. My shop is coming along nicely, by winter I'll have a small area in the house set aside for bike work.
jules083 screwed with this post 08-16-2012 at 06:08 AM
Old 08-16-2012, 08:30 AM   #1851
AJ..
AJ..'s Avatar
Oddometer: 1,608
Glad that this thread had resurfaced.
This has been an awesome thread.
Will contribute abit next week with the rally fairing built off.
Cheers
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 08-16-2012, 09:44 AM   #1852
jules083
jules083's Avatar
Oddometer: 3,963
Cheers
Yeah, I didn't realize how buried this thread got until I started looking at it. Some good info here for sure.
Old 08-16-2012, 10:09 AM   #1853
Garthe
Garthe's Avatar
Oddometer: 4,356
Cheers
Can't wait.
2007 XR650R
2001 Montessa 315R
Old 08-16-2012, 10:57 AM   #1854
Shibby!
Oddometer: 1,658
That's a good way to go. Be mindful of what you add because of weight.
IMO, musts are:
- Rad braces
- Acerbis tank
- Windsreen
- GPS for speedo (if allowed in your state)
- Good headlight! (Think LED if you have the cash)
- Seat
Leave the skid plate if you don't need it. The Ricochet is heavy! The stock one protects well, has less chance of mud build up, and is way, way lighter. It's coverage is pretty good. It also allows the side cover to be taken off which makes valve adjustments that much easier.
Think about sinking that money saved into a TM-40 carb. I know it's expensive but it does a few things:
1) Adds fuel mileage! It begins to pay itself off! I went from 36-38 to 50+. I now get way better mileage then my buddies stock carb that used to get better mileage then mine! The savings aren't huge, but a few bucks at every fuel stop is nice!
2) Reduces throttle pull so you can lighten up on the bars and that in turn helps with your vibration issues.
3) Adds power/snap.
I built mine up for similar reasons as you. I had the bike, replacement cost isn't that high, and it's less room in the garage, less wrenching, and less insurance/plate cost. Sure, some days I wish it did highways better, but when I get offroad I'm so glad I have it over people with Xchallenges, DR's, XR's, F650's, etc. The thing is a toy in the dirt. Theirs becomes the struggle for what? Easier luggage options (that suck offroad) and ability to cruise at 110? (70MPH). Not worth it when you can do twice the speed of them on gravel roads, and do trails that they don't even think possible on a dual sport. Not only that, they often don't like the struggle of riding offroad, where you can do the same stuff and have FUN!
I'll probably continue to ride mine for as long as I need, but keep an eye out for a good deal on stock, low mileage XRR. When that happens I'll buy it, swap suspension and all parts, then sell the higher mileage XRR for a minor loss. You get a low mileage frame and engine, and because these things aren't overly expensive you don't have to pay that much for it. Only wear item after that is bushings in the suspension which aren't that much.
Old 08-16-2012, 12:04 PM   #1855
jules083
jules083's Avatar
Oddometer: 3,963
IMO, musts are:
- Rad braces
- Acerbis tank
- Windsreen
- Seat
I'm halfway there. Need some sort of speedo, rad braces, seat, and windscreen
I already have an xr's only skid plate. The weight is low at least. I cracked the case on a 4-wheeler once, I put skid plates on everything now.
3) Adds power/snap.
It's a possibility, but I don't know if I'll actually do it or not.
It does seem like there won't be a whole lot of difference between the XR and DR, except for 50 pounds, 10 horsepower, and luggage options. The girlfriend was hoping to ba able to ride on the back though.
Old 08-16-2012, 12:30 PM   #1856
Shibby!
Oddometer: 1,658
One ride on either of the two bikes and she'll change her mind.
Old 08-16-2012, 05:21 PM   #1857
Garthe
Garthe's Avatar
Oddometer: 4,356
2007 XR650R
2001 Montessa 315R
Old 08-16-2012, 05:29 PM   #1858
krisdkwiatkowski
krisdkwiatkowski's Avatar
Oddometer: 1
hi i have a Xr650R conversions and im trying to sell it and someone told me that is a good place to do it but i dont knoe how to post anything
krisdkwiatkowski is offline   Reply With Quote
Old 08-16-2012, 06:36 PM   #1859
Kiko
Kiko's Avatar
Oddometer: 1,820
Create a thread here :
http://www.advrider.com/forums/forumdisplay.php?f=52
Home page Advrider Scroll down to > Gear > Flea Market >Bikes
Near bottom of page at left column click on "new thread"
Conmigo piscas, y no moloncos.
Kiko is online now   Reply With Quote
Old 08-16-2012, 06:52 PM   #1860
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
Read the stickies about how to list it -like no price in the thread title.
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Times are GMT -7.   It's 05:37 PM.
