Old 06-28-2012, 06:29 PM   #1
Shmandy OP
Fat guy riding!
Shmandy's Avatar
Oddometer: 50
NUVI waterproof question
I have looked in multiple reviews and topic searches and still cannot find this answer!!!
I am looking at buying a NUVI 550 or Zumo 220, I just cant seem to tell if they are only waterproof when running on batteries??? Can you have then plugged in and still maintain the waterproof nature? is there a special plug that has some sort of gasket seal that keeps the power port on the unit from rusting or getting all screwed up? will the regular cord be fine?? Help
THANKS
-Confucios say that baseball is just wrong; A man with 4 balls cannot walk.
-Give a man a match, and he’ll be warm for a minute, but set him on fire, and he’ll be warm for the rest of his life
Shmandy is offline   Reply With Quote
Old 06-29-2012, 04:45 PM   #2
Shmandy OP
Fat guy riding!
Shmandy's Avatar
Oddometer: 50
Really?? Nobody has experience
With this?
Old 06-29-2012, 05:13 PM   #3
S/W
S/W's Avatar
Oddometer: 306
not the answer you are looking for
Get whatever GPS you want. Just carry a sandwhich bag and an elastic band and you have a water resistent unit. It's very cost effective, and short of being underwater, it works!!
S/W is offline   Reply With Quote
Old 06-29-2012, 05:54 PM   #4
biker128pedal
Super Lurker
biker128pedal's Avatar
Oddometer: 1,958
I have a NUVI 500. The plug just has a rubber cover that really does not make it anymore waterproof if it is not on. The only problem I have had is some green corrosion in the receptacle. This was cleaned off easy. I would say the submersion rating is either way. Mine did die after three years. $99 to replace.
Wee Stommin along.
W/ABS
biker128pedal screwed with this post 08-05-2012 at 07:19 PM
biker128pedal is offline   Reply With Quote
Old 06-29-2012, 07:36 PM   #5
BitesTheDust
BitesTheDust's Avatar
Oddometer: 160
I have a Nuvi 550. It also has a rubber gasket and I haven't had problems with corrosion on connectors.
It has a usb connector for power - so I suspect that over time it can become corroded.
BitesTheDust is offline   Reply With Quote
Old 06-30-2012, 06:22 AM   #6
Shmandy OP
Fat guy riding!
Shmandy's Avatar
Oddometer: 50
Appreciate it! I've got mine on order and just was worried as I do ride in rain a moderate amount and didn't know if I always had to disconnect it and run on batteries during those times.
Old 07-01-2012, 05:11 AM   #7
abhibeckert
abhibeckert's Avatar
Oddometer: 1,422
I reckon you'll be fine. Low voltage stuff usually doesn't mind a bit of water.
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community
abhibeckert is offline   Reply With Quote
Old 07-13-2012, 03:47 PM   #8
joeoldbmwrider
oldjoe
Oddometer: 9
Zumo 220
THANKS
Zumo 220 is waterproof whether on batteries or powered. Have 1 no problems wet or dry
joeoldbmwrider is offline   Reply With Quote
Old 08-05-2012, 12:22 PM   #9
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 6,739
Send a message via AIM to HaChayalBoded
Short answer, yes and no.
If the USB outlet has it's cover on you can submerge the unit.
If you have the power cable plugged it and it is mounted in the GARMIN cradle then water should not get to the plug as the Garmin cradle covers the plug.
If you are using a RAM cradle (slightly different) then the plug and cable are exposed to the elements. More so on a naked bike.
Eddie
Stuff FS
'00 Harley MT 500
'93 Concours, extreme farkle (for sale)
'00 Shadow ACE Tourer (for sale)
'03 Shadow Sabre (Gone)
'90 Honda Hawk GT NT650 (Gone)
Lookin' for a (cheap) '95 GSPD Classic
I've been stranded in the combat zone
I walked through Bedford Stuy alone
Even rode my motorcycle in the rain!
HaChayalBoded is offline   Reply With Quote
Old 08-17-2012, 11:22 PM   #10
srferrin
GS-Obsessed
srferrin's Avatar
Oddometer: 15
Ram Mounts AquaBox
Ram Mounts makes the AquaBox series of mountable cases. They are waterproof, allow you to add a lock for security, have a port for power/headphones, and best of all, allow full screen touch operation. Great for making the cheaper Nuvi series waterproof. Also work real well with iPods and iPhones. The screen on the box allows touch sensitivity on the i-devices.
Ram Mounts are super secure and I've never had one loosen or break.
"Being shot out of a cannon will always be better than being squeezed from a tube. That's why god made fast motorcycles!"
srferrin is offline   Reply With Quote
Old 08-18-2012, 07:25 PM   #11
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,826
The Ram Aqua boxes heat up really seriously in the sun. And the touchscreen is such a sticky material that using a gps inside the box was frustrating. I bought two and sold them almost immediately since they were useless to me.
YMMV, but I hated them.
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee is online now   Reply With Quote
Old 08-20-2012, 02:19 PM   #12
Umarth
Umarth's Avatar
Oddometer: 149
to prevent the connectors from rusting and will also act as a water barrier, you can fill the connector (female) with dielectric grease.
In my case, the gps unit never comes off the bike it's pretty much a fire and forget thing. if you take the gps off the bike and grease it more often.
Umarth is offline   Reply With Quote
Old 08-20-2012, 02:42 PM   #13
dmottv
Take the Long Way Home
dmottv's Avatar
Oddometer: 304
I've been using a Ram AquaBox with a Nuvi 750 for a few years. It's a good way to waterproof the Nuvi. The flexscreen works well with gloves on, though it gets abit dirty when riding off the beaten path. I wash it in the sink with dish detergent, rinse, and it's good to go. I have Ram ball mounts on all my bikes, and swap the Aquabox between them. If you don't have a waterproof gps, the Aquabox is a good solution until you can get one. YMMV.
Dave - NH Seacoast; RT-NH1; AMA; MVTR; NETRA;
'07 KLR650; '02 R1150RT-P; '01 R12C Montana; '00 KDX200;
Gone: '05 450EXC; '99 K12LTC; '94 KDX250; '92 R100GS; '77 R75/7; a few others...
dmottv is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 08:44 PM.
