Old 08-19-2012, 02:02 AM   #1
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Honda VFR 750 XC Makeover
Greetings from Estonia,
In a search for a perfect ralley bike, I decided to test my engineering skills and build on by myself. For the power source there were alot candidates DL/SV/TL 650/1000, XL650/1000, VF/VFR 500/750/800/1000/1100 but after spending lot of time in forums doing research and discussing with the owners I deciced to go for Honda VFR 750. The 300.000 km without
any major overhauls and 4-5l per 100km fuel consumption when being easy with the throttle were the arguments. And I also like the looks of V4 combared to V2's out there.
There is no certain budget for the build, but I'm trying to keep it as cheap as possible and hoping to finish the build under 4000euros (ca.4900$). After couple of months donor hunting I found a crashbike from Holland's local advertising page. Got the bike for 400 euros and it was taken to Estonia in the back of the trunck in pieces. The papers say it's '96 year machine, though it has ''91 Model'' sticker on it. During the registration to the Estonian registry found out that the bike had been imported from US, so it's already an adventure bike. The odometer reading is 12467mi/20063km's, but no service book to confirm it, only owners words.
Design ideas and looks will be mixed from Tiger XC800, BMW F800Gs and KTM SMT and I hope to hit the roads next spring.
Here's 'before' pictures in my garage, 'after' will follow:
Quacamole is offline   Reply With Quote
Old 08-19-2012, 05:12 AM   #2
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,737
Subscribed.
Nuke Gay Whales for Jesus.
Porsche Audi VW
B.Curvin is offline   Reply With Quote
Old 08-19-2012, 06:39 AM   #3
DRTT
Oddometer: 15
Fantastic!!!
Just been looking at a vfr800 with exactly the same idea as yourself, fantastic.
Cant wait to see how you get on, very,very intrigued.
Best of luck & hopefully get to swap info,
Cheers,
Paddy,
UK based
DRTT is offline   Reply With Quote
Old 08-19-2012, 01:58 PM   #4
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Cheers and thanks alot.
Good to see there's some VFR building enthusiasts out there.
Today got my fork, swingarm and wheels with tires and discs from local hillclimb and KTM fan.
Going to build the frame around the parts and VFR engine.
Parts come from 2005 KTM Adventure 950 with unknow milage, but looks in good condition.
Haven't decided yet will I go for 26,6°rake like KTM's or 23,1° like F800GS and Tiger XC 800.
Old 08-19-2012, 02:26 PM   #5
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
SO in!!
I've neer replaced my '91 VFR cause there's nothing out there that will do everything it does while sounding like it does.....another one to do what I do with the 990 would be about perfect!
Get with it!
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 08-20-2012, 03:28 PM   #6
DRjoe
DRjoe's Avatar
Oddometer: 5,095
If your using the ktm tripple clamps and axle clamps then stick with the ktm rake so that the trail stays the same.
Trail is the important one not rake.
Old 08-20-2012, 09:12 PM   #7
ktmklx
ktmklx's Avatar
Oddometer: 689
You got some nice pieces to work with This should be good. What kind of weight do you think it will have?
ktmklx is offline   Reply With Quote
Old 08-21-2012, 12:11 PM   #8
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
Looks awesome, good choice in parts. Do you have a rear shock yet? I know lukas has at least one.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 08-21-2012, 01:30 PM   #9
zenjen
Go Outside
zenjen's Avatar
Oddometer: 2,662
That is definitely a '91. Had one just like it. Only year with the gold wheels.
Nice gear-driven cams motor. You will love the way it sounds when you get out on the road and hold the throttle WFO. Sounds like a mini V8.
zenjen is offline   Reply With Quote
Old 08-21-2012, 04:02 PM   #10
Quacamole OP
Quacamole's Avatar
Oddometer: 85
About the rake/trail, tomorrow I'll go and check out one damaged LC8 frame and if it's ok I rebuild it to fit VFR engine,
to keep original 950 Adventure dimensions cause I really like the seat position on those. Though the engine weight
difference is about 30kgs. VFR about 70kg and LC8 about 40kg - correct me if I'm wrong. Trying to keep the overall
weight of the bike around 200kgs.
Still working on the rear shock and brake calipers - smells like ebay.
Old 08-21-2012, 04:22 PM   #11
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
Send lukasm a pm he's in austria and usually has these parts plus a lot of knowledge. Fed with an inquiry vs. ebay
Nessmuk
Old 08-21-2012, 11:51 PM   #12
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,307
I have rebuilt and own/ed both a 950 and 990.
The engine is about 60kg's. So much less of a difference that you might have thought.
Good luck.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 08-24-2012, 01:59 PM   #13
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Thanks for the tip, but got shock coming from UK, my friend arranged it from local motorcycle salwage yard.
Old 08-24-2012, 02:12 PM   #14
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Some update:
Got LC8 frame from the same guy who arranged the fork and wheels. Though it is cut in half (god knows why) and
burned, also got a subframe. Frame is Superduke and sub is Adventure, nothing that some modification can fix.
Steering head angle on Superduke is 66.1° and on Adventure 63.4°, should I just ignore that or is it important and
should be considered when I start widening the frame?
VFR/LC8 Comparsion
Engine removed, probably next week I'll start with engine mounts and frame widening.
Does not fit really...
Visual design, how it will look, hopefully.
Quacamole screwed with this post 08-24-2012 at 02:28 PM
Old 08-24-2012, 02:19 PM   #15
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
Going to be bad ass :-)
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Times are GMT -7.   It's 09:43 PM.
