Old 07-28-2012, 10:23 AM   #991
JGNC
JGNC's Avatar
Oddometer: 387
Ended up bringing it home. He had a brand new Sportmax front tire and rear lift he threw in on the deal. I'm happy but I was mistaken and it has a stock rear shock/spring. I'm wanting to replace it asap.
JGNC is offline   Reply With Quote
Old 07-28-2012, 02:55 PM   #992
Strog
Geek on two wheels
Strog's Avatar
Oddometer: 408
Yes, yes you do.
Why did I wait 24k miles to change mine?
Definitely a worthwhile upgrade.
Dale S.
Strog is offline   Reply With Quote
Old 07-28-2012, 05:33 PM   #993
PrtclMn001
Custom User Title
PrtclMn001's Avatar
Oddometer: 979
Originally Posted by Strog View Post
Yes, yes you do.
It's ridiculously easy as well.
PrtclMn001 is offline   Reply With Quote
Old 08-13-2012, 05:46 AM   #994
Jocassee
Petrolhead
Jocassee's Avatar
Oddometer: 354
New to me 650S
25,500 miles, 300 of those in the last week since I got it
Let me not then die ingloriously and without a struggle, but let me first do some great thing that shall be told among men hereafter. ~Homer
Jocassee is offline   Reply With Quote
Old 08-13-2012, 02:30 PM   #995
PeteN95
PeteN95's Avatar
Oddometer: 2,741
Nice little bike, congrats!
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 08-13-2012, 02:51 PM   #996
AlpineGuerrilla
AlpineGuerrilla's Avatar
Oddometer: 399
I would like to recommend a ride report of a trip to the Black Sea - with an SV 1000!
The Black Sea tour 2012 by Snowhite808
AlpineGuerrilla is offline   Reply With Quote
Old 08-13-2012, 04:26 PM   #997
m98
m98's Avatar
Oddometer: 59
Just sold my 2001 Suzuki SV650S. I have the center stand for sale in the classifieds here:http://advrider.com/forums/showthread.php?t=814811.
m98 is offline   Reply With Quote
Old 08-17-2012, 03:46 PM   #998
plutonic
Outsider
plutonic's Avatar
Oddometer: 3,936
I have questions to the SV650 collective:
The first gen SV650 rear brake rotor diameter is 240mm and second gen rear rotor is 220mm, right? Are they interchangeable? My main concern is the bolt pattern. Are they the same?
The rear wheel assembly has 3 bearings, one in the sprocket carrier and two in the wheel. The first gen bike should have a 17mmm axle and bearings, except in the sprocket carrier, which is bigger and there's a space/reducer.
The second gen bike has a 20mm axle but I don't know the size of the sprocket carrier bearing. I need to know if the OD of that bearing is the same like the first gen's bike? Also, what's the ID for the same bearing? 20mm like the other two?
Thanks.
" ...my life is an endless battle against maturity... "
"You are born. And you die. And if you are very lucky in between you get to ride motorcycles."
plutonic screwed with this post 08-17-2012 at 07:51 PM
plutonic is online now   Reply With Quote
Old 08-19-2012, 03:47 PM   #999
JGNC
JGNC's Avatar
Oddometer: 387
Here's another question...
My '03 nekked has a '04 GSXR 750 front end with the stock rear. It seems harder to turn in than it should. Would going with a shorter rear shock setup help? Do I need a shock with adjustable ride height or could I go with dog bones?
Old 08-20-2012, 05:14 PM   #1000
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,735
I think that used to belong to a friend of mine. I did some work on it if I remember correctly.
Nice ride.
Nuke Gay Whales for Jesus.
Porsche Audi VW
B.Curvin is offline   Reply With Quote
Old 08-20-2012, 05:16 PM   #1001
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,735
If it is hard to turn a longer shock would be a better bet. Or raise the forks in the triple clamps if ground clearance is not an issue.
Check your tire pressures first. I usually run 32psi front and rear if I'm riding sporty. 38+ if I'm just commuting.
Porsche Audi VW
Old 08-20-2012, 07:32 PM   #1002
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 683
I need a longer front brake line in order to raise my bars how I want them.
How should I go about acheiving this?
"The only way I knew I didn't miss a turn off was the occasional side by side tracks where you could see evidence of massive acceleration and fun." - Cobra5150
EastBoundAndDown is offline   Reply With Quote
Old 08-21-2012, 12:37 AM   #1003
alwayssummer
aspiring bikewhore
alwayssummer's Avatar
Oddometer: 171
Yes, yes you do.
I did Race Tech springs up front during the snowy season last year and am pleased with the results, but I don't understand what a rear-shock upgrade will do for my ride. What are the bad behaviors that result from a crappy rear shock? Thanks for enlightening me, I am suspension ignorant.
07 SV650 in Candy Sonoma Red & 99 KLR in Green
I'm alone even at home. I'm the only one in the house that is condemned to a lifetime of dreaming of far off places. -Larryboy
~R.I.P. Isaac A Klosterman a.k.a. Classic~March 22, 1982 - May 18, 2008~
alwayssummer is offline   Reply With Quote
Old 08-21-2012, 05:19 AM   #1004
JGNC
JGNC's Avatar
Oddometer: 387
I thought the GSXR shocks were shorter and that's what caused the issue?
-Jesse
Old 08-21-2012, 06:15 AM   #1005
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,735
Lets make sure we're on the same page.
The stock rear. Is it a stock SV shock or a stock GSXR shock?
In my experience (whatever that is worth) when I put a 2000ish GSXR600 shock on my 2000 SV650 it jacked the rear up quite a lot. I'm fairly certain a GSXR shock (at least early 2000 models) is longer than an SV shock.
Having typed all that, when I put a Penske on my 2000 SV race bike (my second SV) it was light years better than the GSXR shock. If you end up replacing your shock I would suggest an aftermarket.
Porsche Audi VW
Times are GMT -7.   It's 12:25 PM.
