Old 08-20-2012, 08:03 PM   #16
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,651
Acewell http://www.acewell-meter.com/ makes a similar speedo/ tach combo (looks like the pic you posted) that I used on my H1 project, it's kinda hard to see in some lighting.
Vapor http://trailtech.net/vapor.html also has a slick unit that I may change it out to.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 08-20-2012, 10:03 PM   #17
VietHorse OP
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,457
Great info Anony. Thank you.
Take a quick view on those speedo/tachno meters, and I wonder how could I connect with the bike!? I meant I am not good in electronics so don't really know how to modify the existing conenctor to fit with this type of meters? And how to calibrate, especially the Trip meter and Odometer.
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 08-21-2012, 12:00 PM   #18
anonny
anonny's Avatar
Oddometer: 5,651
My Acewell was pretty simple to wire in, it just required 12 volts plus some wires from the signal lights, high beam, neutral light. Tach function is from wrapping their wire around your spark plug wire inductive) and speed calibration is pretty simple. Just requires to know the diameter of the wheel the magnet and sensor are installed on.
The instructions were easy to follow.
Old 08-24-2012, 02:22 AM   #19
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Oh, that 's good. Wasn't thinking of an attached instruction/manual.
Thank you. I think I will buy one as yours.
Old 08-25-2012, 08:41 AM   #20
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Dual disc - done!
At the shop for around 2hrs discussing on how to make the dual front discs instead of original single disc.
After two days, they have completed the mounting with perfect air-gap from the wheel to both front forks, and also the two break calipers.
Right disc:
Left disc:
There are two shim plates have been inserted into both side of the "rim base" (well, I am not sure if I am using incorrect word!!??).
Because of the differences between two sides of the rim, so two plates have difference thickness. That was a difficult part for getting a correct measurement. Otherwise, the two discs could not fit with the two break calipers.
We used long bolts to mount the break disc and the shim plate to the "rim base".
So, here is how the front end looks like:
The wheel looks bigger than with the single disc, right??
Old 08-25-2012, 08:46 AM   #21
Bluebone
straight to hell
Bluebone's Avatar
Oddometer: 3,113
i'd like to know more about that LCD speedo, that looks badass!! and count me in to!
Bluebone is offline   Reply With Quote
Old 08-25-2012, 09:03 AM   #22
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
I am also so curious about that LCD speedo.
Ah, Anonny, do you still have the instruction sheet still around? If so, could you please help to take a photo and post up here? Frankly to say, I am still wondering how I can connect to the existing connectors from this old bike.
Thank you so much!
Old 08-25-2012, 10:03 AM   #23
anonny
anonny's Avatar
Oddometer: 5,651
I didn't keep the manual but..... go to their site, go to downloads, download the manual for the instrument you want in your preferred language.
Old 08-26-2012, 12:03 AM   #24
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Here is a ref link for the AceWell installation and configuration: http://www.advrider.com/forums/showthread.php?t=527749
Just noticed that only series 27xx and 28xx could give wide range of speedo (300kph). Other series goes up to 125kph only.
The manual from the site is just for the unit operating only, not for connection / installation. However, it provides detail tire circumference conversion.
Old 08-26-2012, 12:49 AM   #25
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Oh hell.. Mine looks too bad!!!
Old 08-26-2012, 01:22 AM   #26
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Just borrow the headlights:
Old 08-26-2012, 09:26 AM   #27
Bluebone
straight to hell
Bluebone's Avatar
Oddometer: 3,113
yeah, that fixed it...
Old 08-26-2012, 10:24 AM   #28
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
Somebody called that looks like scared owl............................................
Old 08-26-2012, 07:03 PM   #29
Bluebone
straight to hell
Bluebone's Avatar
Oddometer: 3,113
well.....it does look kinda familiar........
Old 08-27-2012, 05:58 PM   #30
VietHorse OP
VietHorse's Avatar
Oddometer: 1,457
New rear monoshock
This rearshock looks a bit old:
So that why I bought a Ducati 1198 OEM monoshock to replace - this monoshock is almost new, just on the bike for some hundred miles:
This is how I make the trial fit:
Side view:
We will make a support from the bottom frame, just about 2-3 inch height. All the rear frame will be chopped off:
Overview of the rear shock design would be like this:
I may need a little frame (diagonal brace) to support the rear seat. That's not an issue, as soon as I leave a room for the air filters.
Times are GMT -7.   It's 11:02 AM.
