Old 07-22-2012, 10:41 AM   #16
2fast4u
Oddometer: 746
What about the ninja fuel pump?
2fast4u is offline   Reply With Quote
Old 07-22-2012, 10:42 AM   #17
RedRaptor22
Oddometer: 154
Originally Posted by thomas.tc.young View Post
service manual reveals fuel pressure is 294kPa, 41.81psi and discharge is 83mL (2.8US oz) and more/10 sec. i dont think it will work with that lower flow rate, anyone else know if it would or wouldn't?
It would with a regulator, your local autoparts store should have a couple of aftermarket performance brand fuel pumps sitting on the shelf as well.
When I replaced the 3psi stock fuel pump on my royal star venture I found a mr. gasket pump at autozone for a whole $15, the stock was remote as well and retails for $145.
RedRaptor22 is offline   Reply With Quote
Old 07-24-2012, 02:18 PM   #18
divimon2000
divimon2000's Avatar
Oddometer: 613
Great project. Good luck.
divimon2000 is offline   Reply With Quote
Old 07-24-2012, 03:54 PM   #19
thomas.tc.young OP
Oddometer: 858
oops
and all done with a handsaw because i'm cheap like that!
1969 CL350 permanent project
2000 Ninja 250
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 07-24-2012, 08:51 PM   #20
RedRaptor22
Oddometer: 154
Been there and done that on my old yamaha AT1, your going to look like a fiddler crab by the time this build is done lol.
Old 07-24-2012, 09:13 PM   #21
thomas.tc.young OP
Oddometer: 858
phew, thought it was because i too much
2000 Ninja 250
Old 08-01-2012, 02:42 PM   #22
SamM
Jeep Overlander
Oddometer: 1,471
Very nice! I pick up my KLRE tomorrow!
SamM is offline   Reply With Quote
Old 08-02-2012, 05:59 PM   #23
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,707
Where? Somebody doing builds?
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 08-06-2012, 03:22 PM   #24
JagLite
JagLite's Avatar
Oddometer: 1,121
Thumb External fuel pump
My '05 Honda VTX 1800F uses an external fuel pump.
(Some years have internal and some years are external)
Bike recycle yards probably have several of these if you want to try used.
Just FYI
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 08-06-2012, 03:52 PM   #25
2fast4u
Oddometer: 746
Have you given up already. Haha
Old 08-08-2012, 08:34 PM   #26
thomas.tc.young OP
Oddometer: 858
Low funds
2000 Ninja 250
Old 08-22-2012, 09:38 AM   #27
thomas.tc.young OP
Oddometer: 858
no real progress
issues that need to be addressed
upper engine mounts
exhaust
2000 Ninja 250
Old 08-22-2012, 12:44 PM   #28
SamM
Jeep Overlander
Oddometer: 1,471
Not sure if you want any constructive input but you may want to tilt that engine as far forward as possible. Moving it to the left, as far as you can will help with fuel tank clearance. I'm having issues with mine! My downtubes will probably not work as they are now and I don't think the Versys radiator will fit into my frame once I tilt the engine forward. It looks like the earlier swingarm may be the best fit as well. JMO!
Old 08-22-2012, 09:49 PM   #29
thomas.tc.young OP
Oddometer: 858
I was thinking either stock klr or drz radiator because they sit on the side of the main down tube. The exhaust will probably go through and around the front down tube before heading back something similar to an xr exhaust
2000 Ninja 250
Old 08-24-2012, 07:30 PM   #30
Krasniewski
I don't ride much.
Krasniewski's Avatar
Oddometer: 1,267
Just FYI - the 08+ KLR radiators are alu and a comparable size to the stock Ninja 650R rads, but the radiator fan is a bit smaller.
Best of luck with the project.
Krasniewski is offline   Reply With Quote
Times are GMT -7.   It's 02:58 AM.
