Old 08-21-2012, 06:33 AM   #256
Paulvt1
Paulvt1's Avatar
Oddometer: 2,821
It's certainly got the stats on it's side. Looking forward to throwing a leg over one.
Paulvt1 is offline   Reply With Quote
Old 08-21-2012, 06:56 AM   #257
wilmar13
Oddometer: 188
Originally Posted by v8toilet View Post
Yes it looks fine @ 45mpg, who's KTM gets that? (Bring on the three guys who will claim their bikes do, it's not the rule it's the exception.) I couldn't find much on the RC8 consumption numbers but I did see 35mpg at constant throttle. If it's detuned it should get slightly better mileage. I would think 42-43mpg at constant throttle. Ride it hard and it will probably drop to normal KTM 36-38 I think I can get my SE down in the high 20's if I try.
Since its fuel injected the 24 liters is probably not usable capacity with pump and filters. I think it will be a nice bike and a good alternative for folks looking for a Multistrada with more dirt capability. Maybe I'll buy one once the bugs are squashed, it only took me 7 years to try the 950.....
It would make a nice two-up tourer with the misses. Combined we weigh in at 270lbs, I bet 150hp would move us around nicely.
I get 45mpg on my rc8... The dual spark engine is more efficient than the original rc8. See post 80 in this thread.
http://www.advrider.com/forums/showp...1&postcount=80
I was on the fence between MTS for practicality and jack of all trades attributes, but chose the rc8 for many reasons (including sexiness and brand appeal to me over Ducati douchiness). The engine is actually a gem, with really smooth and tractable torque through the entire rev range, noticeably better than the multistrada. Even without detuning, this will make a great power plant for adventure bike.
'12 KTM RC8R, '07 Aprilia SXV 5.5
wilmar13 is offline   Reply With Quote
Old 08-21-2012, 10:25 AM   #258
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,294
Originally Posted by wilmar13 View Post
multistrada.
i don't get the hype about that bike. I rode one and it seriously sucked under 5k rpm and then took off, how that is beneficial on a dirt road is beyond me. Handled nice though. If ktm can manage to tune the fueling so it's not too twitchy off idle and still have good low rpm grunt it might be a special bike
MookieBlaylock is offline   Reply With Quote
Old 08-21-2012, 11:14 AM   #259
Katoom72
Katoom72's Avatar
Oddometer: 396
When pigs can fly my friend, when pigs can fly....
Katoom72 is online now   Reply With Quote
Old 08-21-2012, 11:28 AM   #260
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,580
Send a message via MSN to v8toilet
That is great news, my comment regarding mileage should have said "Who's LC8 gets that?"
v8toilet is online now   Reply With Quote
Old 08-21-2012, 02:50 PM   #261
Balsta
Oddometer: 341
It seems I may finally be forced to ditch my beloved SE. About the RC8, what would it take to get some more force than the 150 hp? Why not put the RC8 unchanged into the new 1290R? To be compared with my SE with the SD 990R motor, soo much more fun to ride than the oem 950, (yes, on gravel too, at high speed) I like the tighter gearing as well. About the 21/18 versus 19/17 rims, I'll buy both on day 1.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 08-21-2012, 11:10 PM   #262
srad600
srad600's Avatar
Oddometer: 411
Not quite 45, but my '11 990A (6,500 mi) has been getting 42.x (usually 42.3) mpg lately, bone stock motor/exhaust/emissions. This is also a mix of riding, both aggressive and cruising. Since I bought it, the mileage has steadily been going up. So I think 45 may be possible.
srad600 is offline   Reply With Quote
Old 08-21-2012, 11:16 PM   #263
zoomdude57
Oddometer: 637
Fueling on my 2011 RC8R is as good as any fuel injected bike I have owned and fuel economy surprisingly good. I think KTM finally figuring this out and hopefully these lessons make it to the adventure bikes.
Paul
2009 Husky TE610
2012 BMW R1200GS
2011 KTM RC8R
2006 KTM 200 XC-W
zoomdude57 is offline   Reply With Quote
Old 08-22-2012, 01:15 AM   #264
syzygy9
syzygy9's Avatar
Oddometer: 240
a 230kg Adv bike, you have to be kidding . . . .
After having just completes a 5,000 km ride across the Australian outback of which 4,000 kms was on dirt and some of it pretty gnarly, the last thing I'd want is more weight. What happened to a 180kg, 600-800cc 70-80 bhp adv bike with good dirt credentials?
Frankly, after having dropped, unloaded, picked up, moved to hard ground, reloaded my 200kg 990 Adv for the 3rd time in 20 kms (each one taking 30mins to get back going) the thought of adding more power (not needed) and more weight (definitely not needed) is an anathema to any serious Adv travelling.
As an aside, fuel consumption averaged over 5,000 kms (fully loaded), a mix of high speed tar, high and low speed dirt, was 42.3 US mpg (5.9l/100km) giving a 650+ km range with a Safari tank.
__________________________
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 is offline   Reply With Quote
Old 08-22-2012, 02:09 AM   #265
mousitsas
Oddometer: 2,148
Place your 990 on good scales and if it comes up less than 230 report back
Old 08-22-2012, 02:28 AM   #266
Terence FFM
prof. cat-herder
Oddometer: 343
My thoughts exactly. There is a DIN norm (don't know the number off hand, but trust me, there is a norm in Germany for EVERYTHING) regarding maufacturer claimed weights. It stipulates that all fluids must be on board which are required for operation (unlike the Japanese you used to like to weigh their bikes sans cooling water, brake fluid, or acid in the battery) plus 90% of the maximum fuel load. According to this, the ABS KTM Adventures came in at 231kg without crash bars or luggage racks which can easily add another 10 kg.
So to agree with Mousitsas, unless your KTM has undergone some serious dieting, your 200 kg estimate is a little conservative. The 950 SE weighed in at right around 200 kg, (wet, of course) if I recall correctly.
On another note, not mentioned so far is a final quote from the Motorrad article (I have to paraphrase since I don't have it with me here):
KTM: Our goal was to be number one off-road among the enduros (euro speak for adventure bike).
Tester: In my opinion, you have just built the best two cylinder enduro period.
The tester raved earlier how the dual spark heads, additional rotating weight, new mapping plus whatever other mods KTM has undertaken have completely transformed the engine. Lots of low end grunt, great mid-range and a top end rush that only the Multistrada can complete with were the raves. The added weight seemed to add a great deal of smoothness at low rpm without detracting from the quick revving character the KTMs are known for. Only complaint was a bit of roughness about 7000 rpm but that equates to 180km/h so not an issue in the real (non-Autobahn) world.
Also praised were the new off-road ABS (insert flame here). The system from Bosch allows for a high rate of slippage on the front before it kicks in, and the rear is completely free to be locked up. From the brief article, it really sounds like KTM made a lot of very intelligent design choices and/or compromises.
"The powerful will delegate to the untalented until failure is achieved" Dogbert, CEO
Terence FFM is offline   Reply With Quote
Old 08-22-2012, 11:58 AM   #267
crazybrit
crazybrit's Avatar
Oddometer: 8,039
I thought KTM published weights were always semi-dry. That's including coolant, oil, battery but no gas. My experience has always been that adding gas to a KTM and weighing it gets you pretty close to the published weight plus the weight of the gas.
The semi-dry weight of the 2012 990R is 207kg. So looks like the bike has gained 6 kilos, give or take.
The Japanese published weights are always dry, no coolant, no oil, no battery, even then they don't usually match reality. I've read that sometimes the bike is missing tubes/tires also.
crazybrit screwed with this post 08-22-2012 at 12:05 PM
crazybrit is offline   Reply With Quote
Old 08-22-2012, 12:49 PM   #268
Goti
Goti's Avatar
Oddometer: 796
The two or three test/reviews I've read about the 990 showed 210-212-214 kg with all fluids and no gas so yes, KTM figures seems pretty accurate.
Yep, they even remove the bike's soul.
KTM 990 Adv
Goti is offline   Reply With Quote
Old 08-22-2012, 01:15 PM   #269
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 1,562
The Japanese USED TO publish weights always dry, no coolant, no oil, no battery, even then they don't usually match reality. I've read that sometimes the bike is missing tubes/tires also.
Have you looked lately ?
Example: http://www.yamaha-motor.com/sport/pr...1/0/specs.aspx
Yamaha Super Tenere:
Wet Weight***
575 lb
***All standard equipment and all fluids, including full tank of fuel, not including options or accessories.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'08 KTM 950SE-R
'08 Ducati Hypermotard 1100S
Florida Lime is offline   Reply With Quote
Old 08-23-2012, 07:44 PM   #270
syzygy9
syzygy9's Avatar
Oddometer: 240
I have knocked off bout 5kgs of the back-end by replacing the stocks cans with Wings cans - but probably put those kgs back on with a light saddlebag pannier rack and rear plate.
My own experience on some pretty gnarly roads is that the current 990 Adv is probably a bit too heavy and overpowered for dirt road riding. On tar you can use the power and the weight comes in handy, but if that's what your doing there are 1000's of road orientated bikes that will do the job much better.
IMHO, KTM might be better off building their great for the road but useless off the road 1290 Adv bike but supplement that with dirt capable 600cc, 160kg single and a 700cc, 180kg twin for 'proper' adventure riding.
Frankly, the current 990 is right on the limit of anything I'd like to take off road and a pig in sand - after the 3rd pick-up in 20 kms, regardless of how good the suspension is, the 200 kgs and 110+ hp starts to wear very thin (and lower the gearing for chrissake! - the way to high for anything remotely tough off road).
Times are GMT -7.   It's 01:46 AM.
