08-23-2012, 07:28 PM
#51856 |
Adventurer Anonymous
Oddometer: 689
That'd be my guess also. I've experienced this, it doesn't take much to throw it off and give exactly the feel your describing.
08-23-2012, 08:11 PM
#51857 |
Curmudgeonly
Oddometer: 8,815
A'ight, thanks all. I will take good look at the tire bead when I get home, I can certainly inflate the hell out of it and pop it in if that's all it is. Didn't really even consider that.
It's not "more agressive tread" as these are the same brand / model of tires I always run, I'm used to them. But thanks.
Go forth, wander aimlessly, explore, have adventures and shit... |
08-23-2012, 09:31 PM
#51858 | |
Insert wit here.
Oddometer: 1,210
08-23-2012, 09:51 PM
#51859 |
Curmudgeonly
Oddometer: 8,815
I never do. I ride a lot, but I guess I'm not a connosieur. I don't know how much different a big ol' trailee would feel on quasi knobs if the tire is or is not balanced.
I don't really want to be a nuisance to my mechanic, either, I like him and he does the work for very little money, so I hate to take up more of his time by having him balance the tires.
#51860 |
Random Hero
Oddometer: 1,646
Balancing the tires on an adventure bike is pretty much pointless. Most tires go out of balance within 500 miles or hitting the first pothole.
Never turn your back on Fear. It should always be in front of you, like a thing that might have to be killed. |
08-24-2012, 12:27 AM
#51861 |
Insert wit here.
Oddometer: 1,210
An adv bike yes,even knobbies too. That i understand. He said strom, so im picturing 80/20 tires at best. All valid points, I was just wondering why is all. Once I hit about a 60/40 I wont bother with balance unless its pretty noticeable.
08-24-2012, 12:59 AM
#51862 | |
Curmudgeonly
Oddometer: 8,815
Checked the chain, rear wheel alignment. Straight / true. Checked the steering bearings in the Swingset manner, no looseness. I examined the tire, it appears to be seated on the bead. To be on the safe side, I rode to the gas station with a ball bat, tire gauge, and bottle of windex. "Drained" all the air from the back tire, waled on it with the ball bat, lubed the area of the bead, waled some more, hyperinflated the tire to 70+ PSI without seeing or hearing the bead popping, waled some more, dropped pressure to 41 PSI Rode home. Same as it was. I noticed the only difference between my bike and Meredith's is the rubber dust cover over the wheel bearings on the disk side of the rear wheel on mine is slightly dimpled, like the rubber is a little crushed; and on hers it is nice and flat. That's it; all other spacers are exactly the same between the two bikes. I'm not terribly worried, just curious. I'm gonna keep riding, I guess one of three things will happen - it will get better, it will get worse, or it will stay the same. Even if it gets worse I can't see a catastrophic failure since everything checks okay. Thanks for the advice.
08-24-2012, 03:58 AM
#51863 |
Oddometer: 813
[QUOTEBalancing the tires on an adventure bike is pretty much pointless. Most tires go out of balance within 500 miles or hitting the first pothole. __________________][/QUOTE]
I'm not arguing or disagreeing, because I don't even understand this stuff at a distance, but I am curious; why should this be true? How does hitting a pothole "unbalance" a tire? You balance a tire/wheel because all sections or segments of the tire/wheel don't weigh the same. You add weight to one section to attempt to "balance" these inequalities. I understand that tires wear unevenly and this weight distribution changes over time, but don't understand how hitting a pothole would change a tire/wheel weight distribution.
"I went to the Town of Cats and came back on the train." |
08-24-2012, 05:09 AM
#51864 |
Just another FF!
Oddometer: 1,192
Did you check the swing arm bearings for excessive play?
I like beer |
08-24-2012, 05:14 AM
#51865 | |
Random Hero
Oddometer: 1,646
You balance a tire/wheel because all sections or segments of the tire/wheel don't weigh the same. You add weight to one section to attempt to "balance" these inequalities. I understand that tires wear unevenly and this weight distribution changes over time, but don't understand how hitting a pothole would change a tire/wheel weight distribution.[/QUOTE] I'm not a tire engineer, but I can tell you that even on a car tire, it can be balanced to zero, driven into a curb, or driven a couple hundred miles, and be way out again. I have seen it time and time again.
08-24-2012, 06:21 AM
#51866 | |
Oddometer: 973
Does the bike have a center stand? If so, I'd put on the stand and put it in gear with the engine running (after making sure the rear wheel is off the ground) Then look for runout or a bulge in the tread or sidewall.
'95+'95+'96 BMW R1100RS/RSL '99 Husky WR250 '98 Honda XR 70 AMA, OMTA (ohio organization), BRC, BMWMOA rxcrider screwed with this post 08-24-2012 at 06:27 AM |
08-24-2012, 06:49 AM
#51867 |
Pumpkin Rider
Oddometer: 13,207
You know I'm wondering if the front rim might be bent. I bent mine before screwing around. Strom rims aren't exactly made for what the bike can do.
Don't trust links? Google ADVFilmer for videos. ![]() http://www.youtube.com/user/advfilmer |
08-24-2012, 07:53 AM
#51868 |
Turn it up to eleven
Oddometer: 4,513
I'm guessing the spacer from between the cush drive and the wheel was left out.
Or it's a bad tire. |
08-24-2012, 08:11 AM
#51869 | |
Oddometer: 1,668
Interesting! I stopped balancing street bike tires years ago, but I did balance my new adv tires. I figure, with that much rubber (semi-knobby, 50/50 tire) the chance of it being noticeably out of balance were greater. |
08-24-2012, 09:03 AM
#51870 | |
adventure imposter
Oddometer: 14,843
That is the worst chip seal job I have ever seen.
ImaPoser Save $5 when you open your own smugmug account. Use code: DeAGMxYPTdjUA Quote:
