Old 08-24-2012, 03:47 PM   #68536
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,973
U-Haul, part of the Suzuki DR Experience.
My wife's bike blew out its countershaft oil seal and lost a lot of oil. I could probably have fixed it but we decided to load both up and come home to fix it properly.
The rail we found sitting beside the parking lot worked beautifully as a ramp. Sure came in handy, though it weighed a couple of hundred pounds.
After my alternator problem on the BMW F8 earlier in the week, I figured bad luck comes in threes, so let it happen at home.
Old 08-24-2012, 03:52 PM   #68537
edwardo
clever witticism here
Oddometer: 57
To mod or not to mod...
Hello all...hope you don't mind a somewhat retarded question...
I have added the pumper to my DR. Along with a 13/42, I am loving the ride I'm getting from it (secondary, gravel, moderate trail). From the thread, it seems the GSXR exhaust is getting harder to come by. I have the stock muffler currently and really like the lack of noise from it. BUT...if the GSXR or 'busa exhaust would open another door, I wouldn't mind spending the coin...
My question: what kind of performance increase could I appreciate from the exhaust modification??
Do not confuse enthusiasm with capability. ~General Peter Schoomaker ...
edwardo is offline   Reply With Quote
Old 08-24-2012, 06:12 PM   #68538
barko1
barko1
barko1's Avatar
Oddometer: 3,416
Originally Posted by dljocky View Post
173K miles, now that's what I'm hoping for!
And I have a nice ocean front property for sale in Nevada if you're interested
DR650, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), Triumph Thunderbird Sport, Triumph Daytona Super III, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 08-24-2012, 06:24 PM   #68539
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Flow-wise, the stock can isn't really too bad. It's heavy though; many replace it more to save weight (which helps performance in all areas) than to increase power output.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 08-24-2012, 08:10 PM   #68540
jugglingogre
Under the thumb
Oddometer: 229
With my 105kg (230lbs) + gear, a couple of kg's can is really not going to make a hell of a lot of difference. Me eating less might have a much bigger impact on performance
Plotting my next ride
jugglingogre is online now   Reply With Quote
Old 08-24-2012, 09:17 PM   #68541
TRAVELGUY
Old Traveler
Oddometer: 717
Changed to the Ti GSXR can a few weeks ago. Using my digital scales there is a 6 lbs 4 oz weight savings weighting both then GSXR muffler and mid pipe aganist the stock DR muffler. Made no changes to carb jetting. Mileage nor performance seemed to change. So if you want to save 6 lbs 4 oz make the change. I liked the quite of the stock pipe but wanted the weight savings since I always over pack when traveling.
TravelGuy.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 08-24-2012, 11:10 PM   #68542
toddiscdn
Take off, EH!
toddiscdn's Avatar
Oddometer: 1,039
Since weight came up
Its a little slow on the night shift tonight so I broght the DR in and put it on the scales out of curiosity.
Mostly stock, 08 DR, IMS tank=less than half full, , Dirtbagz rangers and racks, rear rack with wolfman peak bag, wolfman enduro tank bag, small gps, vapor, blah, blah, blah.....
Anywho it came out to 388 lb.s, better than I though. The gas is quite low though, likely 1.5 gals. left or so.
Things you do to kill time on the night shift eh!
"It's all about the beer"
drcool
08DR650 - Jack of all trades, master of none
toddiscdn is offline   Reply With Quote
Old 08-25-2012, 12:42 AM   #68543
jugglingogre
Under the thumb
Oddometer: 229
Lucky Catch Today
Took the sprocket cover off to check if it needed a degrease this arvo.....
Glad I did.
Missing one bolt completely, one is oh so loose (left) and the third (right) is moving. This could have been oh so bad. Sprocket moves if it's wiggled.
Hopefully the missing one is not snapped off and in the drive.
Cheers
Pete
Old 08-25-2012, 01:53 AM   #68544
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by dragnbiker View Post
Just finished my breakin service on my 2012 dr650. And im lookin into upgrades .. however the aftermarket for the bike has changed since i moded my 2001. Can someone tell me what exhust / jetkit and intake will give me the most hp gain. They dont make the yoshimura system i had on my 2001 anymore.. and have they made a racing cdi for it yet ?
A LOT has come into the DR aftermarket in the last few years. Some people are now making over 50WHP with these engines, through big-bore kits, cams, big-valve heads, and other mods.
Check out www.kientech.com and www.procycle.us for many of the popular performance mods. A popular air/fuel setup is an FCR39 or a TM40 flat-slide pumper carb, a GSX-R X40F0X muff with Kientech midpipe, a foam airfilter (Uni, TwinAir, etc.), and a cut airbox. Some people are also experimenting with EFI.
Kommando is offline   Reply With Quote
Old 08-25-2012, 03:26 AM   #68545
TrophyHunter
Oddometer: 2,312
Emmbeedee - sorry to hear the ride was cut short but probably the prudent choice. Just a hint on turning in the rental if you have a choice. Check how much it costs to turn it in at different return locations. Some are overstocked on certain trucks/trailers and charge you more to drop it there vs 5 - 10 miles away. I rented a car trailer one way and saved 30% by driving 4 miles.
It's good the two of you get out together.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 08-25-2012, 05:32 AM   #68546
thetable
thetable's Avatar
Oddometer: 1,482
Any warning. My tard is currently leaking at the seal when she gets hot, I'd rather not find myself hot in a corner with a well lubricated rear tire.
thetable is offline   Reply With Quote
Old 08-25-2012, 05:45 AM   #68547
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,973
No warning but it usually happens to a cold engine. Like first thing in the morning.
Old 08-25-2012, 06:58 AM   #68548
thetable
thetable's Avatar
Oddometer: 1,482
Far better that way. I mean, it makes for a crappy day regardless, but better that way than any other. I've known of a couple DRZSMs to lose the countershaft seal while everything is good and hot.
Old 08-25-2012, 08:16 AM   #68549
JagLite
JagLite's Avatar
Oddometer: 1,439
Cool2 No worries
Glad I did.
Cheers
Pete
One bolt will work fine actually. There is no load on the bolts and the sprocket can move around on the spline without problem. Some people use a snap ring (C-clip) instead of the bolt plate. The missing bolt just fell out on the ground and it may have been many miles ago.The 14-15-16 tooth sprockets use a 3 bolt retainer generally, the 13 tooth uses a 2 bolt retainer and they all work fine. Stock has a rubber gasket for anti-rattle I believe but is not required.
The important thing is to not have the sprocket come off the shaft, which I don't know if it can with the sprocket cover on. So, no worries.
Get a new bolt and use blue loctite and you can move on to real worries like running out of gas.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 08-25-2012, 10:34 AM   #68550
sandwash
sandwash's Avatar
Oddometer: 1,371
Here is a good write up for light reflection:
http://drriders.com/topic5526.html
97dr650
sandwash is online now   Reply With Quote
Times are GMT -7.   It's 08:35 PM.
