Old 08-25-2012, 11:17 PM   #5221
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
I got 16 km/l yesterday over a 350 off-road loop using Vortex's economy map. I was the only bike that had severe range issues.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 08-26-2012, 12:52 AM   #5222
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,758
Originally Posted by Night Falcon View Post
Nice one B2..... that about sums up the seat comfort question....it's ok as long as you don't sit on it
yeah - if you only do rides that you sit down on buy a tiger 800 xc
Beer'o'clock Baz is offline   Reply With Quote
Old 08-26-2012, 02:25 AM   #5223
Frontwheel21
Oddometer: 43
Hi guys,
The damper does completely remove headshake on the new KTM 690 Enduro.
I went 110 mph yesterday on TKCs without any headshake. After advice from Scotts/California I adjusted some settings on the damper. It was essential to turn both Sweep control valves by 180 to the 6 o'clock position. (It is delivered and preset to 12 o'clock which damps only in a narrow angle.) At 6 o'clock the complete steering angle is damped. This made the big difference because it can compensate for the great force exerted at high speeds. Also the Highspeed valve is highly effective. I turned it 1/4 counterclockwise from the stiffest setting. This setting will remove the headshake completely.
2012 KTM 690 Enduro R
Frontwheel21 is offline   Reply With Quote
Old 08-26-2012, 07:37 AM   #5224
Night Crawler
Night Crawler's Avatar
Oddometer: 93
37 mpg's with the fuel economy map? What are you getting on the power maps?
Night Crawler is offline   Reply With Quote
Old 08-26-2012, 11:37 AM   #5225
ktmmitch
Oddometer: 632
Noah in UK at Rally-Raid HQ
We have had the pleasure of one of ADV Rider's US inmates,Noah from Montana visiting us on an unplanned stopover on his RTW trip.He had his 690 stolen in Ireland,and after a few days he managed to get a lift on the back of a bike to Rally-Raid HQ in the UK.We actually had a US plated KTM 690 which was left by Luke Swab,aka Fishfund,from his trip last year.So we are in the process of making it up to scratch for Noah to carry on his trip with.
He has had a great deal of support from bikers here in the UK & Ireland after his unfortunate start to his European leg of his trip,but we hope we can help him on his way.
It just goes to show what a world-wide phenomena that ADV Rider is,with contacts all over the world.
Noah has been pretty busy fabricating an alloy tool tray to go in place of the airbox,as Fishfunds old KTM 690 has a Uni-Filter fitted.
It is looking pretty good now,not bad metalwork for an electrician!!
He has also added our Rear Fuel Tank & Soft Luggage Frames to complete the set-up.
He has had good news from his brother in USA,the new licence documents are on their way so he can carry on with his trip.
Follow his blog
ktmmitch is offline   Reply With Quote
Old 08-26-2012, 11:49 AM   #5226
Velociraptor
TrackBum
Oddometer: 1,118
Fantastic news!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-26-2012, 12:19 PM   #5227
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Thumb
...so he can carry on with his trip.
Follow his blog
Roostre is offline   Reply With Quote
Old 08-26-2012, 12:56 PM   #5228
Biped
NooB Again
Biped's Avatar
Oddometer: 327
TPS Gremlins
My TPS gremlins continue....
Not sure if anyone else has had this issue or could point me in a direction for further diagnostics.
Issue: While riding, any gear, any speed, or bike stationary at idle, I randomly get an FI solid on light and the engine tone changes. Going to Neutral provides a 9 x long flash indicating a TPS issue.
Well, I first check all TPS related voltages via TuneECU and all were within spec. I checked all wiring for chaffing, short to frame etc and nothing. I then replaced the TPS with a new one and reset the voltages. Unfortunately same error/issue persists.
I decided to check the TPS voltages directly to see if I could find an abnormality. I used pins to back probe the TPS connector to a logging DVM. What I found was interesting. The working voltage was a steady 4.98V which is great. The sense line voltage was at 0.58V while idling normally, which is what should be expected. When the FI issue occurs the sense voltage jumps to 0.71V and stays there. The working voltage does not change. If I cycle the key or kill switch all goes back to normal.
From what I can gather is that somehow the stepper motor must be getting a signal to move the butterfly a set amount, independant of throttle position, at random times which seems the only way the sense voltage on the TPS would change a set amount and stay static.(some randon butterfly to throttle position offset) The wiring diagram does not have any info on the 8 position stepper plug pin-out for me to analyze. Are there any sensors that control this stepper (left side throttle body) or is it driven through the ECU only. I would prefer not to buy a new throttle body to see if the issue goes away or not.
Any thoughts....this just started happening about 250 miles ago. Have not done any mods/mapping for about 8k miles. Running a version of the Beaney map FWIW.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 08-26-2012, 01:01 PM   #5229
Biped
NooB Again
Biped's Avatar
Oddometer: 327
Originally Posted by Buzztail View Post
Also, thinking I may replace the quick disconnect with the NAPA filter (part number?) Will the filter fit in the stock location of the disconnect?
NAPA: 3095
FRAM (Autozone): G3606
WIX: 33095
You will need 2 fuel injection hose clamps for 5/16 hose also. The filter will replace the quick connect and fit snugly between the airbox and the frame in the same location of the quick connect.
Old 08-26-2012, 01:03 PM   #5230
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Originally Posted by Biped View Post
NAPA: 3095
WIX: 33095
Thank you.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-26-2012, 01:32 PM   #5231
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Thank you.
I got two clamps in the box with my NAPA filter.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-26-2012, 04:49 PM   #5232
garrett
garrett's Avatar
Oddometer: 458
Originally Posted by al m View Post
Hi there KTMers,
I'm looking at getting an single-lung adventure bike (2nd hand) for a big ol' Central/North American ride and am currently interested in the 690 Adventure or DR650. Some might say these bikes are chalk and cheese but this is what I've narrowed it down to for my own reasons...I've come here looking for your opinions on comfort of the 690 and to ask what sort of maintenance I'd be looking at if I owned one of these things.
Can any of you kind gentlemen shed some light on these topics? Obviously I'm looking at a ton of miles so comfort is paramount but so is maintenance once I get off the beaten track.
Thanks in advance for your help and hopefully I'll see you on the road!
Get a SeatConcepts seat. Just got one for my 690. Liked it better than the Renazco that was on it. I know I'll hear from the Renazco lovers, and truth be told, they ARE a good seat, but they are VERY pricey and I cannot say that the Renazco is more comfortable. I got a non slip cover for it and a local seat shop shop covered it for 35.00.
This is my 3rd seat from SeatConcepts and they were all great seats and good value.
Garrett
I like bikes...
garrett screwed with this post 08-27-2012 at 06:56 AM
garrett is offline   Reply With Quote
Old 08-26-2012, 05:21 PM   #5233
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,595
Originally Posted by garrett View Post
Get a SeatComfort seat. Just got one for my 690. Liked it better than the Renazco that was on it.
Garrett
Not surprising that a seat custom made for someone else didn't feel good to you. That's the whole point of getting a seat specifically designed to your specifications.
Old 08-26-2012, 05:22 PM   #5234
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Hey, if anyone needs a Vortex ECU..... $500 shipped.
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-26-2012, 05:23 PM   #5235
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 453
Check out this seat manufacturer. The seat looks pretty cool.
http://www.motorbikesaddles.com/KTM%...om%20Seats.htm
Also, I saw on the German Touratech website that they have a new Kohedo seat out.
thorinoakenshield is offline   Reply With Quote
Times are GMT -7.   It's 05:35 PM.
