08-25-2012, 06:52 AM
#31 | |
Oddometer: 1,976
I'm not racing, my objective is getting from A->B without falling off, not as fast as possible. Just grabbing a handful of brake and leaving it locked isn't going to be much use agreed - but for me at least ABS lets me use more brake than I could otherwise, which means shorter stopping distances. All I can suggest is that you try one of the bikes with "known good" ABS, (S10, DL650, others ?) and play on a nice wide dirt road some time - I think you'll be surprised how well the ABS works. Pete |
08-25-2012, 03:43 PM
#32 |
Oddometer: 3,824
Not arguing that. All I am saying is that there are too many general rules running around. In some situations you will need to turn ABS off. Some bikes a lot sooner than others. Make an informed choice about the bike you are riding is all I'm saying. That requires getting to know it.
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. |
08-25-2012, 03:58 PM
#33 | |
Oddometer: 3,824
Some who have disabled it put it back to standard as it was getting a bit much for them. An off option would be good I suppose. And yes there is no substitute for getting to know the dynamics of a "RAW" bike. totally agree. I still prefer to have this stuff around. I am not always 100% switched on myself, especially when tired, distracted or just plain out of practice.
08-25-2012, 04:02 PM
#34 | |
Oddometer: 51
I should have mentioned that I have only ever had a 2012 DL650 and I have no idea how other bikes would react, might land you in a ditch on different models but mine worked well. I have rode down dirt road/muddy dirt road hills with unknown stuff and water at the bottom a few times since and just kept the back break on most of the time and it worked out. I'm guessing things are about to change a little since I just got my Heidenau K60 Scout tires in the mail to replace stock tires
08-25-2012, 05:49 PM
#35 |
Oddometer: 212
Remember that ABS works properly on a bike when it's going straight, not leaned into a turn... but then so do non ABS brakes. So for a panic stop get the bike steering straight if at all possible. When I asked a buddy with ABS, "Do I need it?" the response was "not until you do... and then you really need it." So far I've only had it activate once -- when I tested it out on a nice straight hard stop. Felt the pulsing and the stop was controlled and smooth. All that said I'll take ABS.
08-26-2012, 04:04 AM
#36 |
Oddometer: 1,321
There was the ABS-test in Motorrad that I mentioned. They also tested aggressive braking on a curve with a VFR1200A, and came to the general conclusion, that while theorretically possible, in reality the bike won´t low-side because of ABS. The VFR doesn´t even have the latest generation ´race-ABS´, like the CBR1000RR does.
08-26-2012, 09:57 AM
#37 | |
farnorth
Oddometer: 10
08-26-2012, 02:59 PM
#38 |
Oddometer: 3
abs
I would say yes..saved my butt a few times on the black-top..get a shut off switch for gravel and dirt..just from my experiences
08-29-2012, 01:43 AM
#39 |
Oddometer: 329
Modern ABS is great. I have been nothing but impressed with how good the S10 stops with it, including off road.
08-29-2012, 03:43 AM
#40 |
Oddometer: 1,321
For asphalt, it's a no-brainer. For gravel, depends on many many things incuding road condition, and rider's experience. Many riders, (who are not experts on riding outside the tarmac), will actually benefit from a modern ABS on gravel as well. Then there are a few riders, who are better off without it.
10-21-2012, 08:48 PM
#41 | |
Yankee
Oddometer: 4,460
), I've appreciated being able to easily turn off the ABS so as to be able to lock the tires unimpeded. I would say that this holds true for me also regarding my experience with the Stelvio's traction control system.But like some others have commented, the Wee (and most big ADV bikes, with the exception of the big KTM) isn't designed to handle the nasty stuff where ABS gets in the way. |
10-22-2012, 10:17 PM
#42 |
Oddometer: 820
I find the rear ABS very useful in emergency stops. The front not as much. The rear abs allows me to focus on maximising my front brake potential w/o trying to focus on the rear. When I practice emergency stops, my front may "click" just a time or three. I press the back and if it starts abs'ing, I don't really worry about it. If the front abs's, I ease off a tiny bit.
Off road, for gravel at high speeds, it's very nice, you can give the front a few good squeezes to find out where your traction limit is and adjust your speed accordingly. When going down steep, steep inclines, it scares me, but you can always shut down the engine and use the clutch as your rear brake and waddle on down.
• Indian Himalaya:Gangotri-Shimla-Manali-Pavarti-Spiti-Leh-Kargil-Padum-Sringhar-Daramsala (3 mo.--2x) • Kazakstan-Krygyzstan-Tajikistan-Xin Xiang to Lhasa, Tibet on China 219!-Nepal (7 months) • Santiago, Chile to Ushuia Argentina and up to Cusco, Peru (7 months) • Peruvian Andes (3 months) • N Chile - Medellin, Colombia (3 months) ••• Cartegena, CO to N Chile (3 months) |
