Go Back   ADVrider > Riding > Face plant
Old 08-25-2012, 06:29 AM   #1
colodak OP
Oddometer: 77
Swingarm spool mount sheared off, bike down
Friday night I was installing my rear rack and Givi top case. Had the bike up on the rear stand so it was level for working on. Had everything mounted and was making so adjustments, told the wife to get on the bike and lean against the case I could make sure she was comfortable. She said she was fine and suggested that I put one of my panniers on so she could check her footplacement with it.
Installed the right side pannier, she said it was still fine, but her foot was pretty far forward. She suggested that I get on as well to make sure her foot didn't interfere with me. Now, I probably should have take the bike off the stand at this point, but it slipped my mind. My wife weighs 140, I'm about 240, plus the weight of the bike, HT Teton panniers, and top case, was apparently too much and the right side swing arm spool mount sheared off the swingarm and the bike went to the right. I was able to stay upright, but the wife was thrown to the right, partially trapping her between the bike and the garage wall, with the bike coming down on her right foot/ankle. Thanfully for the pannier being there as it kept the full weight off her. This morning she has a lovely black/blue mark on her right calf and ankle.
I was able to lift the bike enough for her to get out and go get the neighbor to help me upright it. Apparently when it fell, he heard the crash as it went over. So far, the damage appears to be limited to the sheared mount and the right side mirror housing scratched to hell. My handguards came loose but easily retightened. Tip over sensor kicked in and the bike didn't start once we righted it. But I turned the key off/on/off/on and let it sit on the side stand for a few minutes and it fired up.
Needless to say I'll be taking the bike to the dealer this morning to have them look at it, and see what they think as far as if it was too much weight, metal fatigue, bad weld, if Mama Kawi needs to be brought it as well and if it can be repaired.
Mirror
Spool and swingarm
colodak is offline   Reply With Quote
Old 08-25-2012, 06:52 AM   #2
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Clean break. Find a good welding shop and have it TIG welded back on. Simple job.
The dealership probably won't have the expertise to weld it properly and will recommend a new swingarm just to cover their asses. Whether they will foot the bill for it is the question. I doubt it.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-25-2012, 07:44 AM   #3
colodak OP
Oddometer: 77
main reason I'm going to talk to the dealer is this could be a factory defect, wondering if Kawasaki would step up, bike is an '09, but it was sold new to me with 10 miles on May '12. Figure it's worth a shot, if not, then I'll deal with it myself.
Old 08-25-2012, 08:22 AM   #4
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 2,998
dealer will tell you the spools are not made to support the bike with a rider aboard let alone two people..and recommend you buy a new swing arm. You honestly pushed them well past what they are designed to support. I would just run it down to a local welder that could tig weld it throw him $20 and be done.
JeffS77 is offline   Reply With Quote
Old 08-25-2012, 08:42 PM   #5
Nialis
Super Motarded
Oddometer: 539
Yeah this is not a defect, this is just a case of using something outside of it's design limits. You got lucky tho :)
__________________________________________
07' Suzi SV650K7 "Mona"
03' BMW R1150GS ADV "Rene"
00' Aprilia Pegaso Cube "Pandora"
78' Suzi GS 750E
74' Harly Ableson Sportster
49' Hardly Davidson "Panny"
Love of My life...
88' Honda NT650GT "Pagosa" You will always be missed
Nialis is offline   Reply With Quote
Old 08-26-2012, 10:38 AM   #6
vade
Oddometer: 7
Would you put a Gold Wing on a stand designed for a sport bike.... probably not. The spool mounts were stressed way beyond their intended design. Have a welder tig it back on and you will be all good. Thankfully a cheap and easy fix.
vade is offline   Reply With Quote
Old 08-26-2012, 10:41 AM   #7
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,140
to my novice eyes, it was a low penetration weld. It looks almost as if it was just cradled in rather than 'becoming one' with the weld. Looks like a defective weld to me even if the circumstances that caused it's failure were above the design specs.
2007 BMW GS Adventure
2010 Harley Ultra Limited
1975 R90/6
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 08-26-2012, 03:04 PM   #8
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,543
Factory defect? C'mon dude. The swingarm spools are made to support the weight of the bike. Not the weight of the bike, a passenger, panniers, top box and you!
You fucked up, now deal with it instead of whining to the dealer.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 08-27-2012, 07:57 AM   #9
Josephvman
I'm the Decider
Josephvman's Avatar
Oddometer: 3,311
I would consider using a stand that cradles the swingarm instead of spools. I've got an adjustable Pit Bull that I use on my old Supersports, and it works very well.
'11 Ducati Multistrada 1200S Sport "Stormtrooper II"
'09 BMW HP2 Sport
'98 Ducati 900SS Final Edition "The old whore"
'93 Ducati 900SS "Slightly older whore"
"Gentlemen. You can't fight in here. This is the War Room!"
Josephvman is offline   Reply With Quote
Old 08-29-2012, 11:44 AM   #10
UNO_RIDER
Oddometer: 28
Seems to me that Kawasaki has some of the softest aluminum on their bikes. I have a 2011 KX450 and the swing arm and frame dent too easily. Additionally, the frame holes for bolts strip easily and the motor side cases are way too soft (I had a small get off and the clutch cover cracked and leaked all oil out while on a ride)...
However, the motor on the Kawi is awesome and can outweigh the other small issues so long that the integrity of the aluminum holds up; in addition to the fit and finish on the bike as a whole.
Nevertheless, depending on how new your bike is and if its under warranty, I take it to the dealer and make them replace the swing arm. If welds break on a tip over, it makes me question the integrity of critical welds within the swing arm/frame---Can be scary, especially if you're riding off road.
Everyone is trying to accomplish something big, not realizing htat life is made up of the little things. ---Frank A Clark
__________________________________________________ _________________
2010 KTM 530EXC; RaceTech, FMF, JD Jeted, Scotts
2011 KX450F, Race Tech, Scotts
UNO_RIDER is offline   Reply With Quote
Old 08-30-2012, 03:16 PM   #11
TrashCan
Scary Jerry
TrashCan's Avatar
Oddometer: 2,212
You didn't really read what the OP wrote, did you.
X the DY.
TrashCan is online now   Reply With Quote
Old 08-30-2012, 03:48 PM   #12
mitchapalooza
Rider is Air-cooled
mitchapalooza's Avatar
Oddometer: 71
Send a message via AIM to mitchapalooza
Heh, been there. Done that. (Sorta)
mitchapalooza is offline   Reply With Quote
Old 09-02-2012, 10:44 AM   #13
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,510
If you want to stay on good terms with the dealer you got it from, don't go there looking for a warranty job on this s/arm. Even IF the dealer replaced it for you, if he ever got wind of the circumstances of the failure, he'd fuck you at every chance he got, and rightly so. You fucked up. Now own up to it and get it fixed yourself.
Oh, and I'm glad your wife didn't get hurt during this debacle.
Chris
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Old 09-12-2012, 11:13 PM   #14
stumpy-ktm
stumpy-ktm's Avatar
Oddometer: 64
i can weld that back on for free .... only thing is i live a looooooooooooooooooooooong way from you .....would like to to see a pic of the wifes thigh and bruise .....
" lost a leg .....still riding "
2004 ktm 640 supermoto
stumpy-ktm is offline   Reply With Quote
Old 09-13-2012, 07:57 AM   #15
dirtrulz
Oddometer: 420
Have a welder weld it on all four side and you should be good. Something is going to give with that much weight on it, if the welds didnt break then the bolt in the spool would have gone next. You are talking abot maybe 600 pounds being held up by 1.5 inches of welded aluminum, not really a surprise it gave out.
It doesnt bode well for them holding up under any sort of crash if they are meant to be sliders, might as well have the other side re welded while your at it.
dirtrulz is offline   Reply With Quote
Times are GMT -7.   It's 06:50 PM.
