Old 08-29-2012, 08:42 AM   #5296
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Gros Buck View Post
OK
I've read diagonaly Micro Squirt's web site ... You are really having a beer in the sub-basement now ... Is that pig gonna fly ??? You need Einstein ...
Paul Jr 8
I've done a few cars, so I know the drill. Having a good tuner is the key.
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-29-2012, 09:31 AM   #5297
Evil Invader
Evil Invader's Avatar
Oddometer: 691
Originally Posted by crankshaft View Post
I emailed Richard abourt my plan to make a new harness with the idea of eliminating the odd ball safety stuff and he didn't like the idea. For the average user, the Vortex is a great plug and play set up but for me, I don't think the added cost of buying the tuning software is worth it. Micro squirt gives me more options and is much cheaper. A friend of mine tunes rally cars for a living and he's an electrical engineer, I trust him.
He was helping me with my running issues this weekend and we had lots of good ideas about the direction we should go. His harnesses are a work of art!
PLEEEASE make more of them. IŽll buy a set!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 08-29-2012, 10:30 AM   #5298
Pundy
Oddometer: 341
+1! I love my 690 and anything I can do to make it more reliable, the better.
Pundy is offline   Reply With Quote
Old 08-29-2012, 11:06 AM   #5299
Mini Trail
n°°b
Oddometer: 2,268
Anyone have an intake rocker 75036060044? Apparently there is a backorder and mine is destroyed.
Your cycle had a bell on it.
Mini Trail is online now   Reply With Quote
Old 08-29-2012, 12:34 PM   #5300
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Well, we plan on making a jig to be able to spit out a wiring harness. I suppose Matt could sell them to anyone that is interested and I could share my maps for a small donation. Dyno time is expensive
The plan so far is to use GM weather pack style sensors, because you can buy them anywhere and they're cheap. We're also talking about using an EV6 injector thats off the shelf and easily found for cheap $. Might even build an ethanol map for hill climbing
Sensors.....
Intake air temp......$16
http://www.diyautotune.com/catalog/g...tor-p-115.html
It's also a coolant temp switch!
EV1 injector....... $49 You can buy four of them for the price of one KTM injector!
http://www.diyautotune.com/catalog/d...hiz-p-272.html
Just say'IN
Old 08-29-2012, 12:37 PM   #5301
Evil Invader
Oddometer: 691
Thumb
Do it. IŽll pay!
M Motoadventures
Old 08-29-2012, 12:43 PM   #5302
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I need to find a 690 manual.....
Just say'IN
Old 08-29-2012, 01:02 PM   #5303
Evil Invader
Oddometer: 691
Hereyago
http://resmark.se/690e/repairmanual/690e10.pdf
M Motoadventures
Old 08-29-2012, 01:53 PM   #5304
Night Crawler
Night Crawler's Avatar
Oddometer: 93
I noticed a small amount of fine dust inside of throttle body when I took my air box off. Is this un-avoidable? Or am I missing something? I have The Uni filter trimmed to fit with a nice bead of grease around the edge. Also the clamp for the boot seems to slide off the back edge every time I tighten it.
Night Crawler is offline   Reply With Quote
Old 08-29-2012, 02:29 PM   #5305
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Thank you sir!
I really need to document the build up process of the 690 project, I've got lots of great ideas. Since the wiring is all getting redone, I decided to move the battery location towards the front of the bike. I've never liked the airbox, so I'm building a "rain tray" that will hold the battery, circuit breakers and of course the ECU. Going with a Shorai battery for less weight. The intake will be longer and the filter box will be where the stock battery sits. The rain tray will be easily removed to be able to work on the engine and the filter changes will be super easy. No more heat soaked airbox for me.
Just say'IN
Old 08-29-2012, 03:15 PM   #5306
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-29-2012, 03:41 PM   #5307
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Thumb
I was going to try a Shorai until i ran into this thread:
http://www.advrider.com/forums/showthread.php?t=770364
Good reading. I now have 2 bikes running the Antigravity batteries. Hasn't been long enough to say for sure how well they will last, but they have been flawless in both bikes so far. The cranking power is unbelievable. I had an Odyssey PC545 in my street bike, which was a big improvement over stock, but the AG is half the size and 7 lbs lighter and STILL outcranks the Odyssey.
The AG in the 690 turns the bike over a bit faster than the stock battery, but it also only weighs 2.5 lbs. Its truly hard to believe that it will work when you pull it out of the shipping box and its so light.
My only regret is that I could have used one of their small format cells instead and used the extra room in the battery tray to carry a spare tube or something.
Roostre is online now   Reply With Quote
Old 08-29-2012, 03:52 PM   #5308
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
I just did that exact same thing. Dropped it off in my R&D department and let the EE's play with it some (We do a lot of DC stuff) and they all gave it a
I read that too, but figured screw it. If the EE's didn't like it I'd just expense it and leave it there
My bad
Old 08-29-2012, 03:59 PM   #5309
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
690 rider down here had his Shorai fail at 12 months. I'm 'running' a couple of them but they've spent the better part of the last year on a charger while my leg healed.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 08-29-2012, 05:44 PM   #5310
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
The air box is made out of three main parts. Left, right (which is essentially a mirror of the right) and the air filter support. All parts are thermo glue together.
I had an air box changed under warranty because the air filter support was not air tight. And it was very hard to see.
I do not use grease, but zipp-seal the hold the filter in place ...
Same here. I will not install that sh... again. It's cheaper and better to loose weight on a stationary bike.
I know for sure the wiring harness is different for 2008, 2011, and 2012 models ...
Paul Jr 8
KTM690r 2011
Gros Buck screwed with this post 08-29-2012 at 06:02 PM
Gros Buck is offline   Reply With Quote
Times are GMT -7.   It's 11:15 AM.
