Old 08-29-2012, 11:06 AM   #5281
Mini Trail
nb
Oddometer: 2,302
Anyone have an intake rocker 75036060044? Apparently there is a backorder and mine is destroyed.
Your cycle had a bell on it.
Mini Trail is online now   Reply With Quote
Old 08-29-2012, 12:34 PM   #5282
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Well, we plan on making a jig to be able to spit out a wiring harness. I suppose Matt could sell them to anyone that is interested and I could share my maps for a small donation. Dyno time is expensive
The plan so far is to use GM weather pack style sensors, because you can buy them anywhere and they're cheap. We're also talking about using an EV6 injector thats off the shelf and easily found for cheap $. Might even build an ethanol map for hill climbing
Sensors.....
Intake air temp......$16
http://www.diyautotune.com/catalog/g...tor-p-115.html
It's also a coolant temp switch!
EV1 injector....... $49 You can buy four of them for the price of one KTM injector!
http://www.diyautotune.com/catalog/d...hiz-p-272.html
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-29-2012, 12:37 PM   #5283
Evil Invader
Evil Invader's Avatar
Oddometer: 696
Thumb
Do it. Ill pay!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 08-29-2012, 12:43 PM   #5284
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
I need to find a 690 manual.....
Just say'IN
Old 08-29-2012, 01:02 PM   #5285
Evil Invader
Oddometer: 696
Hereyago
http://resmark.se/690e/repairmanual/690e10.pdf
M Motoadventures
Old 08-29-2012, 01:53 PM   #5286
Night Crawler
Night Crawler's Avatar
Oddometer: 101
I noticed a small amount of fine dust inside of throttle body when I took my air box off. Is this un-avoidable? Or am I missing something? I have The Uni filter trimmed to fit with a nice bead of grease around the edge. Also the clamp for the boot seems to slide off the back edge every time I tighten it.
Night Crawler is online now   Reply With Quote
Old 08-29-2012, 02:29 PM   #5287
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by Evil Invader View Post
Thank you sir!
I really need to document the build up process of the 690 project, I've got lots of great ideas. Since the wiring is all getting redone, I decided to move the battery location towards the front of the bike. I've never liked the airbox, so I'm building a "rain tray" that will hold the battery, circuit breakers and of course the ECU. Going with a Shorai battery for less weight. The intake will be longer and the filter box will be where the stock battery sits. The rain tray will be easily removed to be able to work on the engine and the filter changes will be super easy. No more heat soaked airbox for me.
Just say'IN
Old 08-29-2012, 03:15 PM   #5288
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-29-2012, 03:41 PM   #5289
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Thumb
I was going to try a Shorai until i ran into this thread:
http://www.advrider.com/forums/showthread.php?t=770364
Good reading. I now have 2 bikes running the Antigravity batteries. Hasn't been long enough to say for sure how well they will last, but they have been flawless in both bikes so far. The cranking power is unbelievable. I had an Odyssey PC545 in my street bike, which was a big improvement over stock, but the AG is half the size and 7 lbs lighter and STILL outcranks the Odyssey.
The AG in the 690 turns the bike over a bit faster than the stock battery, but it also only weighs 2.5 lbs. Its truly hard to believe that it will work when you pull it out of the shipping box and its so light.
My only regret is that I could have used one of their small format cells instead and used the extra room in the battery tray to carry a spare tube or something.
Roostre is offline   Reply With Quote
Old 08-29-2012, 03:52 PM   #5290
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
I just did that exact same thing. Dropped it off in my R&D department and let the EE's play with it some (We do a lot of DC stuff) and they all gave it a
I read that too, but figured screw it. If the EE's didn't like it I'd just expense it and leave it there
My bad
Old 08-29-2012, 03:59 PM   #5291
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,209
690 rider down here had his Shorai fail at 12 months. I'm 'running' a couple of them but they've spent the better part of the last year on a charger while my leg healed.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 08-29-2012, 05:44 PM   #5292
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
The air box is made out of three main parts. Left, right (which is essentially a mirror of the right) and the air filter support. All parts are thermo glue together.
I had an air box changed under warranty because the air filter support was not air tight. And it was very hard to see.
I do not use grease, but zipp-seal the hold the filter in place ...
Same here. I will not install that sh... again. It's cheaper and better to loose weight on a stationary bike.
I know for sure the wiring harness is different for 2008, 2011, and 2012 models ...
Paul Jr 8
KTM690r 2011
Gros Buck screwed with this post 08-29-2012 at 06:02 PM
Gros Buck is offline   Reply With Quote
Old 08-29-2012, 08:05 PM   #5293
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
I didn't have that safety net. The big reason I think the AG batteries may last longer is that they are watertight- the Shorai is not and lithium and water don't get along. Much of what I read on failed Shorais pointed to water ingress issues. They may have fixed this now, but I don't know.
Old 08-30-2012, 04:40 AM   #5294
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
most don't, but I figured if it shits the bed on me I'm only out a couple hundred bucks, and needed to save some weight up top after adding that corbin
We do a lot of testing batteries, and I figure if this one rolls over. I'll just give them the dims and tell them to source me one so I can assist them in "testing"
My bad
Old 08-30-2012, 06:30 AM   #5295
Pundy
Oddometer: 339
Can you tell me which battery # from AG that you got for the 690?
Pundy is offline   Reply With Quote
Times are GMT -7.   It's 07:50 AM.
