Old 08-29-2012, 08:05 PM   #5311
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Originally Posted by Buzztail View Post
I just did that exact same thing. Dropped it off in my R&D department and let the EE's play with it some (We do a lot of DC stuff) and they all gave it a
I read that too, but figured screw it. If the EE's didn't like it I'd just expense it and leave it there
I didn't have that safety net. The big reason I think the AG batteries may last longer is that they are watertight- the Shorai is not and lithium and water don't get along. Much of what I read on failed Shorais pointed to water ingress issues. They may have fixed this now, but I don't know.
Roostre is offline   Reply With Quote
Old 08-30-2012, 04:40 AM   #5312
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
most don't, but I figured if it shits the bed on me I'm only out a couple hundred bucks, and needed to save some weight up top after adding that corbin
We do a lot of testing batteries, and I figure if this one rolls over. I'll just give them the dims and tell them to source me one so I can assist them in "testing"
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-30-2012, 06:30 AM   #5313
Pundy
Oddometer: 341
I was going to try a Shorai until i ran into this thread:
http://www.advrider.com/forums/showthread.php?t=770364
Good reading. I now have 2 bikes running the Antigravity batteries. Hasn't been long enough to say for sure how well they will last, but they have been flawless in both bikes so far. The cranking power is unbelievable. I had an Odyssey PC545 in my street bike, which was a big improvement over stock, but the AG is half the size and 7 lbs lighter and STILL outcranks the Odyssey.
The AG in the 690 turns the bike over a bit faster than the stock battery, but it also only weighs 2.5 lbs. Its truly hard to believe that it will work when you pull it out of the shipping box and its so light.
My only regret is that I could have used one of their small format cells instead and used the extra room in the battery tray to carry a spare tube or something.
Can you tell me which battery # from AG that you got for the 690?
Pundy is offline   Reply With Quote
Old 08-30-2012, 07:06 AM   #5314
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Thumb
Old 08-30-2012, 07:29 AM   #5315
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Originally Posted by Night Crawler View Post
I noticed a small amount of fine dust inside of throttle body when I took my air box off. Is this un-avoidable? Or am I missing something? I have The Uni filter trimmed to fit with a nice bead of grease around the edge. Also the clamp for the boot seems to slide off the back edge every time I tighten it.
Mine was warrenteed because of a crack. Let some dust in.
KTM 690 R - "Its just a little crush..."
Bill the Bong is online now   Reply With Quote
Old 08-30-2012, 07:39 AM   #5316
Pundy
Oddometer: 341
Merci!
Old 08-30-2012, 08:58 AM   #5317
Velociraptor
TrackBum
Oddometer: 1,118
The clamp for the boot connecting the air box to the throttle body? That should not be sliding off. After a week of desert riding my uni filter was caked with dust on the outside but inside was totally dust free, so sounds like there is a problem somewhere. Just to ask the obvious, the filter has been oil treated right? They come already oiled so I am guessing yes. And those two tabs in the front of the airbox cover are sliding properly into the slots at the front of the air box. Hope you figure it out!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-30-2012, 03:56 PM   #5318
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Not a hint of dust in mine since the change over to the RR. Loud as piss though.
My bad
Old 08-30-2012, 04:03 PM   #5319
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
there a problem with the box cracking on the bottom welded jointhat runs down the centre
Mudguts is offline   Reply With Quote
Old 08-30-2012, 04:49 PM   #5320
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,670
I have a new in the bag air box I'll sell if someone needs it. PM me.
BK.RD.RNR is offline   Reply With Quote
Old 08-30-2012, 05:07 PM   #5321
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Pulled the harness out this afternoon.... what a big wad of useless wires
Moving everything forward is going to be pretty slick and the hole where the battery and fuses sat is going to be a perfect spot for the pod filter. The intake runner is going to be about 12" long in that configuration. Ordered the ECU and a few related goodies this afternoon and ordering the AntiGravity battery tonight. This weekend, I hope to make a cardboard mock up of the battery tray/ECU bracket. I hope to also have a small pocket for the basic tool kit and some tire levers. Looks like I'll also have room for a much bigger fuel filter and an external fuel pressure regulator.
Progress
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-30-2012, 05:12 PM   #5322
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Just say'IN
Old 08-30-2012, 05:21 PM   #5323
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by crankshaft View Post
Time to start a new thread Aaron ...
Where do you intend to install the air temp sensor ??? Also, This will impact your capacity to cross rivers, no ?
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 08-30-2012, 05:33 PM   #5324
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Paul Jr 8
With a valid passport he can use a bridge to cross the Rio Grande.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-30-2012, 05:45 PM   #5325
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Paul Jr 8
The intake runner is going to be tubular Alum and I'll weld a flange to it for the sensor. I also plan to make a wall to protect the filter and suck air from around the seat pan, which should also keep water from sloshing in. Like a baffle I guess. The filter won't be any lower than an EXC, so not worried about it. Anyway, my 390 berg is my nasty trail riding machine and it has a very high filter.
I own www.690rider.com and I thought I might start a Blog about the build and the prep for Mexico. My shakedown ride is a 3 hour endurance ice race in Wisconsin in January. I plan on running the ironman class and riding without stopping All the guys racing are usually on Motorcross or woods bikes with a tiny fuel tanks, the 690 will have 7 gallons Most of the riders are dirt trackers and very, very fast, so I need all the advantages I can get!
With luck I might even be close to 70 hp, which is great when you're swinging a 50# ice tire around.
Just say'IN
Times are GMT -7.   It's 12:13 AM.
