Old 08-30-2012, 07:06 AM   #5296
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
Thumb
Originally Posted by Pundy View Post
Can you tell me which battery # from AG that you got for the 690?
Roostre is offline   Reply With Quote
Old 08-30-2012, 07:29 AM   #5297
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 982
Originally Posted by Night Crawler View Post
I noticed a small amount of fine dust inside of throttle body when I took my air box off. Is this un-avoidable? Or am I missing something? I have The Uni filter trimmed to fit with a nice bead of grease around the edge. Also the clamp for the boot seems to slide off the back edge every time I tighten it.
Mine was warrenteed because of a crack. Let some dust in.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 08-30-2012, 07:39 AM   #5298
Pundy
Oddometer: 339
Originally Posted by Roostre View Post
Merci!
Pundy is offline   Reply With Quote
Old 08-30-2012, 08:58 AM   #5299
Velociraptor
TrackBum
Oddometer: 1,128
The clamp for the boot connecting the air box to the throttle body? That should not be sliding off. After a week of desert riding my uni filter was caked with dust on the outside but inside was totally dust free, so sounds like there is a problem somewhere. Just to ask the obvious, the filter has been oil treated right? They come already oiled so I am guessing yes. And those two tabs in the front of the airbox cover are sliding properly into the slots at the front of the air box. Hope you figure it out!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-30-2012, 03:56 PM   #5300
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
Not a hint of dust in mine since the change over to the RR. Loud as piss though.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-30-2012, 04:03 PM   #5301
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
there a problem with the box cracking on the bottom welded jointhat runs down the centre
Mudguts is offline   Reply With Quote
Old 08-30-2012, 04:49 PM   #5302
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,808
I have a new in the bag air box I'll sell if someone needs it. PM me.
BK.RD.RNR is online now   Reply With Quote
Old 08-30-2012, 05:07 PM   #5303
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Pulled the harness out this afternoon.... what a big wad of useless wires
Moving everything forward is going to be pretty slick and the hole where the battery and fuses sat is going to be a perfect spot for the pod filter. The intake runner is going to be about 12" long in that configuration. Ordered the ECU and a few related goodies this afternoon and ordering the AntiGravity battery tonight. This weekend, I hope to make a cardboard mock up of the battery tray/ECU bracket. I hope to also have a small pocket for the basic tool kit and some tire levers. Looks like I'll also have room for a much bigger fuel filter and an external fuel pressure regulator.
Progress
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-30-2012, 05:12 PM   #5304
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Just say'IN
Old 08-30-2012, 05:21 PM   #5305
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Originally Posted by crankshaft View Post
Time to start a new thread Aaron ...
Where do you intend to install the air temp sensor ??? Also, This will impact your capacity to cross rivers, no ?
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 08-30-2012, 05:33 PM   #5306
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Paul Jr 8
With a valid passport he can use a bridge to cross the Rio Grande.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-30-2012, 05:45 PM   #5307
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Paul Jr 8
The intake runner is going to be tubular Alum and I'll weld a flange to it for the sensor. I also plan to make a wall to protect the filter and suck air from around the seat pan, which should also keep water from sloshing in. Like a baffle I guess. The filter won't be any lower than an EXC, so not worried about it. Anyway, my 390 berg is my nasty trail riding machine and it has a very high filter.
I own www.690rider.com and I thought I might start a Blog about the build and the prep for Mexico. My shakedown ride is a 3 hour endurance ice race in Wisconsin in January. I plan on running the ironman class and riding without stopping All the guys racing are usually on Motorcross or woods bikes with a tiny fuel tanks, the 690 will have 7 gallons Most of the riders are dirt trackers and very, very fast, so I need all the advantages I can get!
With luck I might even be close to 70 hp, which is great when you're swinging a 50# ice tire around.
Just say'IN
Old 08-30-2012, 06:15 PM   #5308
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
Cranky
make sure you do something to keep the filter from pulling the air from down low. the maintenance interval on the pod when I had the airbox fuel cell is what made me go back to the stock airbox....not that I like it and after geting the safari tank i built a tool box in the airbox place but the danm filter was clogged after 4 hours in the dez and i was too unskilled / lazy to make a baffle around the pod. with you moving it up and to the rear you should be in much better shape than i was.
you going to sell a kit for the loom?
you seem to have the same problem i do......hate the bike/love the bike
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 08-30-2012, 06:50 PM   #5309
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
I have had the same problem. My boot/flange seemed to be mis-shaped so I have ordered a new one and I have been advised to use a wider hose clamp instead of the narrow std KTM part to assist with proper fitment.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 08-30-2012, 07:09 PM   #5310
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 460
clean speed engineering brake lever
hi folks,
With the clean speed engineering brake lever , how far down can you adjust the lever? I can't get it lower than flush with the footpeg. Is that normal? I'd like it to be slightly lower.
thorinoakenshield is offline   Reply With Quote
Times are GMT -7.   It's 07:25 AM.
