View Results: Please vote your situation & mileage AT FAILURE or multiple failures
NO failure - current mileage 0 - 20K miles 188 46.65%
NO failure - current mileage 20K - 40K miles 91 22.58%
NO failure - current mileage 40K - 60K miles 21 5.21%
NO failure - current mileage 60K+ miles 1 0.25%
YES - one failure at: 0 - 20K miles 11 2.73%
YES - one failure at: 20K - 40K miles 49 12.16%
YES one failure at: 40K - 60K miles 24 5.96%
YES one failure at: 60K+ miles 7 1.74%
MULTIPLE FAILURES 11 2.73%
Voters: 403. You may not vote on this poll
Old 08-10-2012, 05:47 AM   #46
vtbob
wanderer
Oddometer: 541
Chart update please. Move my earlier input from no problem less than 20K miles to no problem less than 40k miles
I would like to get more specs info on the new replacement. I'm thinking of doing a preemptive replacement this winter with either a new stock stator or the one that should be coming mentioned in an earlier post.
vtbob is online now   Reply With Quote
Old 08-10-2012, 07:13 AM   #47
JRWooden OP
Oddometer: 4,232
VTBob:
I do not have detail specs. on the Electrosport, but you can send an e-mail to: info (at) electrosport.com
They are not yet available on the website, but should be there pretty soon the production order of parts is in mfg. now ...
The price was indicated to me to be less than $150 ... vs. ~$800 for the BMW kit of flywheel+stator.
(For the record I have no affiliation with Electrosport)
JRWooden screwed with this post 08-10-2012 at 07:22 AM
Old 08-10-2012, 07:40 AM   #48
NotAllWhoWanderRLost
Lost
NotAllWhoWanderRLost's Avatar
Oddometer: 490
Originally Posted by rockinrog View Post
I really hated to vote in fear that I may jinx myself
2010 F800GS 9500 miles with no problems.
NotAllWhoWanderRLost is offline   Reply With Quote
Old 08-10-2012, 11:47 AM   #49
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,163
Dang I have a Rick's motorsport Stator on the way. I would have bought this one as it sounds like they actually put some serious thought and work into it to get it to survive higher temps. I don't know how Rick's built designed or tested theirs. I may have to look at picking up an electrosport one anyway
Mine failed at 34,900 miles and left me stranded on I-30 just west of Fort Worth. Buddy came with jumper cables and we charged it on the side of the road with his car for about 15 minutes. I unhooked the headlight and blasted to the house. Pulled into the garage right as it died.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 08-20-2012, 11:23 AM   #50
GoDag
Explorer
GoDag's Avatar
Oddometer: 11
My stator went out at 17,700 miles two days into a 10 day trip. Had to get the bike trailered 90 miles to the nearest descent sized town (thanks to AAA). Overnighted a Rick’s Motorsport stator to the hotel and installed it in the parking lot.
Thanks to you all here at Adventure Rider I was able to diagnose and fix the problem and continue on my way. Love this community/forum!
GoDag is offline   Reply With Quote
Old 08-20-2012, 06:01 PM   #51
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Not sure if my bike quit today because of the stator but it sure sounds suspiciously like that. I noticed the 'Trip 1' switching itself to the odometer as I started the bike at various times today, then it was reluctant to start, then while moving I noticed the top warning indicator come on, then the digital display went away, then it died.
Email sent to electrosport.com
And here I thought it died just to spite me.
Emmbeedee is online now   Reply With Quote
Old 08-20-2012, 06:10 PM   #52
rockinrog
rockinrog's Avatar
Oddometer: 2,868
Any special tools needed to change just the stator? How long did it take to change?
rockinrog is offline   Reply With Quote
Old 08-20-2012, 08:29 PM   #53
jeepinbanditrider
Oddometer: 1,163
They're pretty easy to change. A 10mm socket and something to turn it with, the underseat torx drive to remove the body work, and some snips to cut the zip ties with. It's defiantly an easy parking lot job if you have to do it, but having a garage and some beer handy sure is nice
I had mine replaced in about an hour or two all said and done. You do have to solder some wires together on the Rick's unit though it doesn't come with the connector so you have to cut your old connector off and go from there. The instructions say NOT to use crimp connectors. Not sure why guess the possibility of them coming loose that way.
The longest part of the job to me was soldering the connector cause I suck at soldering. Probably should have just said screw it and used good 3M connectors instead but oh well.
We'll see how long the Rick's unit lasts. Hopefully as long as my stock unit.
1978 GS 1000
Old 08-21-2012, 01:00 PM   #54
GoDag
Explorer
GoDag's Avatar
Oddometer: 11
Yep, what jeepinbanditrider said. I didnt have any soldering equipment or new gasket so I just twisted and taped the wires and used the original gasket to get me through the trip. Now I'm going to have to go back in to do it right but at least I have some beer this time. The parking lot job took me about three hours but I was going slow to make sure I wasnt going to have any more problems on my trip.
Old 08-27-2012, 06:53 PM   #55
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Finally got around to checking the F8 charging problem and the stator is toast, confirmed by my mechanic who's BMW factory trained. Oh well, that is the first thing we've ever had go wrong on the F650/800 bikes aside from expendables like steering head bearings, etc.
Sure glad I still have a Suzuki DR to ride.
Old 08-31-2012, 10:35 AM   #56
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Well, my stator bit the dust this past weekend at 45,509 miles. First sign was the ABS light flickering on and off while I was still about 100 miles from home, followed shortly thereafter by the loss of speedometer, tachometer, and the OBC display. I managed to make it to within a mile of my house, but when I pulled in the clutch at a stop light, the engine died and there was no way to restart it.
Got a Rick's stator on order. There's no way I'm paying US$900 for the BMW kit.
I can't change my vote now, but I'm now in the 40-60K failure camp.
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 08-31-2012, 12:46 PM   #57
JRWooden OP
Oddometer: 4,232
I'll see if I can figure out how to change your vote!
While you're waiting for the new stator, if you haven't done it already,
be sure to put your battery on the charger - AGM batteries hate to be left discharged!
Old 08-31-2012, 12:47 PM   #58
JRWooden OP
Oddometer: 4,232
OK, I can't figure out how to change a vote in the poll - mine or anybody else's for that matter....
If someone knows how this is done please PM me?
Old 08-31-2012, 02:14 PM   #59
TAMPAJIM
Oddometer: 449
Heres how I interpret this poll (as of 8/31/12)
A total of 116 respondents report under 20k miles. 6 have had failure for a rate of 5%
A total of 70 report having reached 20-40k miles. 22 have had failure for a rate of 31%
A total of 19 report having reached 40-60k miles. 9 have had failure for a rate of 47%
2 have gone over 60k miles, both failed. 100%
Would be interesting to build a chart using exact mileage. Looks to me if you get to 40k, your days are numbered.
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 08-31-2012, 02:31 PM   #60
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
It would be interesting to see if most of the failures happen to the 800 or if it's 50/50 800 and 650s.
Times are GMT -7.   It's 05:57 AM.
