Old 08-30-2012, 05:50 PM   #68836
Chill
Chill's Avatar
Oddometer: 71
OK, I understand. Thank you. That's cool then.
Chill is offline   Reply With Quote
Old 08-30-2012, 07:04 PM   #68837
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,116
Originally Posted by MeterPig View Post
Doh! Should have looked there first-thanks.
Um, yea. Is there any where else? :
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 08-31-2012, 12:37 AM   #68838
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 731
Lams
Originally Posted by Chill View Post
Hello, I'm new. Long time lurker and browser of all the awesome pictures, first time poster.
Could anyone please confirm if the Australian spec DR650 is the same as the US and Euro spec. In Australia there is what they call a LAMS scheme (Learner Approved Motorcycle Scheme) and so some bikes are LAMS approved and some aren't. Some bikes they do two versions of so these bikes must have some sort of restricter in place, usually in the throttle. The DR650 is a LAMS approved bike in Australia but my question is, is this because it's power figures are such that it falls into that bracket, or does it have some sort of restriction in place?
I have a full licence so would prefer to unrestrict it if there is some sort of restriction in place.
Thanks,
Chill
The LAMS scheme allows bikes that don't exceed 150kw/tonne. At 32 KW on the DR650se, you do the maths.
The only restriction it has in reality is a weld in the header pipe,which many owners grind down, as I have, but which will hardly turn it into a mind blowing wheely machine. And from stock, the carby is on the lean side of life. There is no end of mods one can do to give the bike that involve buying new bits, not removing them from the stock bike, to give more power. Regardless (here in QLD), you get the letters LAM on your rego label to show the coppers you are riding a LAMS approved bike. Unless they carry a dyno with them, I doubt one would get sprung if on a learners.
If on an Open, go your hardest, they can't do anything about it.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 08-31-2012, 01:10 AM   #68839
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,431
let's not forget all the DR groundwork Jesse has done http://www.kientech.com/
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
eakins is online now   Reply With Quote
Old 08-31-2012, 03:33 AM   #68840
drsmiley
drsmiley's Avatar
Oddometer: 252
I with you on that , Jesse has done alot for the DR community!!!
drsmiley is offline   Reply With Quote
Old 08-31-2012, 05:56 AM   #68841
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,255
I tried finding a 13T front sprocket for a 520 conversion but it appears that none exists...is this true
I think ProCycle has one. I bought a Sunstar 31713. It fits fine, but you have to use the circlip that Jesse sells or one like it.
The sprocket, if I recall is one that fits a 1979-80 Kaw KLX 250 so maybe a long time Kaw dealer could have one still a OEM on the shelf that you could bargain the price down an save shipping.
you can even find 12 & 11 tooth sprockets for these bikes, Like the old KX500's on ebay
From an ebay seller:
SUNSTAR 31713 FRONT SPROCKET KDX400 79-80 / KX-KDX420 80-81 / KX500 83-86
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket screwed with this post 08-31-2012 at 06:33 AM
Rusty Rocket is offline   Reply With Quote
Old 08-31-2012, 07:20 AM   #68842
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 5,561
DR's are heavy
I was out playing last night and found some rocky, gnarly singletrack and decided to ride my DR down it. It was steep and knowing momentum is key I carried some speed. Well it got a bit out of shape and I couldn't bring it back and plop we went. Me over the bars and it slamming to earth. Broke the mount off of my hand guard and bent the shifter into the cover. Gouged the cover but it didnt leak. Picked the big pig up and had to decide if I wanted to ride up, or ride down not knowing where I was going. I chose the up route and decided that exploring unknown rocky trails riding solo on a DR is not for me. I will use my two-smoke for that.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 08-31-2012, 07:26 AM   #68843
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,791
Originally Posted by RichBeBe View Post
DR's are heavy
I went down a hydro line trail yesterday and managed not to fall though there were some steep up and down sections.
I didn't use momentum on my downhills, though. I used the rear brake and pussyfooted down since I was also on my own.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 08-31-2012, 08:06 AM   #68844
TinkerinWstuff
Take it apart
Oddometer: 1,116
anyone still accumulating parts for a quick change rear gear and rubber setup:
http://www.ebay.com/itm/2003-Suzuki-...d12389&vxp=mtr
no affiliation with the seller.
I've finally got a complete spare rear wheel and second drive hub for my ADV and singletrack setups.
someone snatched it up - anyone here?
1999 Suzuki DR650
Old 08-31-2012, 08:08 AM   #68845
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 1,707
DR's are heavy
This sort of thing is how I ended up with a KLX250S for that kind of riding. My DR rarely ventures off anything more "extreme" than a gentle two-track trail now. :)
Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1
The Lane Sharing Works Blog | My SPOT Page
Rob.G is offline   Reply With Quote
Old 08-31-2012, 09:00 AM   #68846
Rusty Rocket
Life behind "Bars"
Oddometer: 6,255
at the price, it was worth it for the sprocket or cushions alone. to get both with a hub was a no brainer. I have all that already,so I passed. the same guy is parting out a DR650 so there's a lot of other stuff available for those looking.
Old 08-31-2012, 09:44 AM   #68847
TrophyHunter
Oddometer: 920
DR's are heavy
..... and bent the shifter into the cover. Gouged the cover but it didnt leak.
Rich - as I'm sure you're aware, there's case protection available for those inevitable drops. I'm not on the home computer so I don't have the links to post but PC has a set and the maker of the AMP oil filter cover has some. They've saved me from an oil leak more than once.
www.dualsportmoto.com
2005 DR650
2013 HD Road King
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 08-31-2012, 11:00 AM   #68848
sect8dr
ride them all
Oddometer: 207
rear and side racks
Anyone use these racks yet? Just checking to see if anyone has anything bad to say about them. I am looking start adding parts to my 2012 and these look decent.
http://cgi.ebay.com/ebaymotors/1996-...item4d0437af34
sect8dr is offline   Reply With Quote
Old 08-31-2012, 02:06 PM   #68849
Rusty Rocket
Life behind "Bars"
Oddometer: 6,255
As Promised
Just got my new Seat Concepts 1" taller seat for the DR650
compare with stock:
on the bike:
Seriously nice product. I got the "standard vinyl because I want to be able to slide around and have my pants come with me.
I sat on it and it changes the whole feel of the bike. It feels like my KTM more. I feel like I'm on the bike as compared to in it. The stock seat always felt low to me.
I will be taking it for a ride tomorrow.
A big thanks to Lendon @ SeatConcepts for getting this done in time for my upcoming trip. They can now make them for everybody.
Sorry you had to see my bike without knobbies. She's dressed for a 1000 mile street ride. Not my usual type of riding.
One other added bonus.....it gets rid of the blue and yellow stock seat colors.
Rusty Rocket screwed with this post 08-31-2012 at 02:42 PM
Old 08-31-2012, 02:47 PM   #68850
TrophyHunter
Oddometer: 920
Listing ended. If they're the ones from a guy in San Diego, yes, I had them on the DR. Only reason I took 'em off was to spend money on Wolfman stuff....lotsa money.
They worked great and are very sturdy. I had soft bags on them with no issues.
2005 DR650
2013 HD Road King
Times are GMT -7.   It's 09:33 PM.
