Old 08-24-2012, 04:09 PM   #16
Dastard
Just another guy
Oddometer: 589
Are you worried about frame strength since the KTM frame was obviously in a fire (I may be worrying about nothing)? This is gonna be badass by the way.
D
WR250R converted to X
S10 (the faster, sexier, more awesome BLACK one). Its like a mustache, with titties!!
Dastard is offline   Reply With Quote
Old 08-24-2012, 11:12 PM   #17
Quacamole OP
Quacamole's Avatar
Oddometer: 85
I belive there were not enough degrees in that fire to change the structure of the chrome moly frame.
Quacamole is offline   Reply With Quote
Old 08-25-2012, 12:00 AM   #18
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,308
Adding Adventure model suspension to Super Duke frames creates the issue of the front wheel hitting the radiator.
So maybe you'll have to add a few degrees to the rake unless you use a different radiator?
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is online now   Reply With Quote
Old 08-31-2012, 10:43 AM   #19
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Ok I'll keep that in mind, though im using VFR radiator which is alot smaller.
Old 08-31-2012, 11:14 AM   #20
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Cutting, grinding, bending...
Back in action now, had one week business trip abroad.
Took the frames, engine and swingarm to the workshop at my workplace for
frame modification.
So what happened today - cut the Superduke frame into pieces since I need the
steering neck and swingarm brackets. Did some measuring before ofcourse.
Bent new upper tubes of 33mm st355 steel so I could just stick them over
existing Duke frame pieces. Does not look straight at the moment but for the
welding I'll use a jig ofcourse. Hopefully I'll continue on Sunday...
Used ol'school bender though we have machinery also.
First impressions
For upper tubes I cut small insert to bend them outwards
To get the lower tubes outwards little heating was needed
Final shot today...cant wait to hit the road!
Old 08-31-2012, 07:48 PM   #21
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,582
Wow, thats an ambitious project. I will be watching.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 08-31-2012, 08:16 PM   #22
MacNoob
MacNoob's Avatar
Oddometer: 1,601
This is so outrageous I have to see how it works.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 09-01-2012, 09:22 AM   #23
Twin-shocker
Oddometer: 1,673
frame modification.
First impressions
Might be a good idea before going any further with this, to fit front forks and wheel into the sttering head (less fork springs) and see if you are going to have enough clearance?
Old 09-01-2012, 10:18 AM   #24
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 09-01-2012, 10:37 AM   #25
markjenn
Oddometer: 10,424
I love the project as a project, but I gotta ask - what was wrong with the original frame?
- Mark
Old 09-03-2012, 12:24 PM   #26
Quacamole OP
Quacamole's Avatar
Oddometer: 85
- Mark
Really nothing wrong with the original frame (VFR it that's what you mean), just the Adventure suspension does not
really go with it, the engine will be too high from the ground and I want to keep KTM frame look alike.
Old 09-06-2012, 02:46 PM   #27
Quacamole OP
Quacamole's Avatar
Oddometer: 85
It's takeing too long...
I hoped that I'll be finished with the frame by now, but its a nightmare at work at the moment.
After long days I'm so exhausted to lift up any tools for bike buildin.
To get things straight I used an old Harley jig, but after installing all parts I noticed the the steering neck not
straight. Looks like my tubes are not equally bent, since the jig is in proper alignment, so I used chainblocks
to pull all even and tacked the parts together. Gotta use laser level befor welding I quess.
But here's some shots of the progress:
Old 09-06-2012, 09:42 PM   #28
anonny
anonny's Avatar
Oddometer: 5,582
I know exactly how you feel somedays I just don't have the drive to work on my bikes and I put it off until it will be enjoyable, it's a hobby not a job
Old 09-06-2012, 11:20 PM   #29
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,651
+100000
My first big project I worked on relentlessly. Lately I find it tough to get really motivated.out has to be fun or you'll hate it. since you have a really ambitious project just try and get small goals done to advance along helps with morale.
I also found making a list of small sub projects posted in the shop, and then crossing them off was good fun too. Keeps focus, easy to look at the entire thing and get over whelmed.
Looks awesome, admiring the fortitude it took to commit to that frame cut
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 09-06-2012, 11:35 PM   #30
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,852
I had a 91 VFR,hard to imagine wanting to put that engine in an adventure bike.
After this maybe turn a Gold Wing into a trials bike? But seriously,I'll be watching.
Best of luck!
In that last picture,from the side,appears to be no room for a front wheel to go up and down? Must be my imagination.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 07:52 AM.
