Old 09-02-2012, 06:31 AM   #16
rade OP
Oddometer: 181
finally 3,2 kg
Originally Posted by Stumpalump View Post
Brilliant! Have you weighed it?
Rade
创创创创创创创创创创创创创创创创创创创创创
complete portfolio at: radegarage.com
rade is offline   Reply With Quote
Old 09-02-2012, 06:34 AM   #17
rade OP
Oddometer: 181
More people are asking for power coat - next pieces will be coated...
Originally Posted by Gordonktm View Post
Are you going to paint or power coat it
Rade
Old 09-02-2012, 06:37 AM   #18
rade OP
Oddometer: 181
Hi Joan - I hope your fever is over:-)
Could you just draw your idea simply and send it to me?
Btw. I am doing now carbon-kevlard skid plate, where I will re-alocate the tools.
cheers :-)
Originally Posted by DirtyADV View Post
Im looking at a solution with tank welded onto the subframe, but its quite far away, the dream would be a solution with fuel on the right side covering the muffler and a storage on the left side (2-1 system) and be able to keep stock under seat tool box.
Have scored 2 extra cheap subframes (one was a write off from a crashed bike so need to see if its still straight) the other should be fine.
Actually have a subframe in my apartment and have plans on starting to make some drawings on my dreams, will probably be around here asking for help about material thickness and similar.
But right now Im running a fever and have a hard time sleeping so drinking a little whiskey to kill some germs!
/Johan
Rade
Old 09-02-2012, 12:40 PM   #19
repho
repho's Avatar
Oddometer: 11
Hey, found this on ebay:
http://www.ebay.de/itm/Zusatzlich-Un...#ht_500wt_1413
Peter
repho is offline   Reply With Quote
Old 09-13-2012, 06:29 PM   #20
rwavaktm
rwavaktm's Avatar
Oddometer: 181
Underseat Tank
WoW that's an auxiliary tank I could get behind! Excellent work, are they available and how much?
___________
06 KTM 950
02 KTM 300
00 KTM 640
09 HD RKING
rwavaktm is offline   Reply With Quote
Old 09-14-2012, 04:27 AM   #21
DirtyADV
DirtyADV's Avatar
Oddometer: 2,241
cheers :-)
Gotten over the fever at least (a while back but busy times, friends getting married and taking care of a moose after the hunt and stuff).
Have started doing some drawings on the computer but nothing that is possible to present at the moment.
Want to play some with a cardboard mockup but right now the oil leak I have is highest priority want to decide what to do about it (bike is in pieces right now ready to see if the cylinder head nuts are torqued properly, had to look at my dads car while bike was cooling down and by the time that was done it was to late, had to get home.
http://www.dirtyadv.com/ktm-950-adventure-oil-leak/
Will share my plans and stuff later on, might need help with suitable kind of aluminum and material thickness later on.
See you have Prague as location, great city!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 09-15-2012, 03:50 PM   #22
rade OP
Oddometer: 181
/Johan
Hi Johan,
I saw the pix. of your bike. That is pitty. I understand, this is priority now.
Btw. I was talking with a friend and It would be possible to do the tank instead of the frame. Question is how much gas on top you get. It wont be more than 1-2 liters max. I will wait for your drawings.
good luck with the repair!
Rade
p.s. thx. Prague is nice :-)
Rade
Old 09-15-2012, 03:55 PM   #23
rade OP
Oddometer: 181
No problem to powercoat it, if anyone wish...
Rade
Old 09-15-2012, 04:03 PM   #24
rade OP
Oddometer: 181
Originally Posted by Cyclops Motorsports View Post
Great fab skills.
Has there been a lot of testing?? It seams possible that pipe temps might cause an issue with fuel expansion??
I saw you video - "killing" one enduro by one - nice job with ADV:-)
We did similar test and no problem with the tanks. Next I want to find someone who is crazy enough to do some real jumps :-)
Rade
Old 01-12-2013, 01:29 PM   #25
rade OP
Oddometer: 181
New development
Hey,
I decided for an innovation - to do polyethylen underseat tank!
Now (after the back wheel clereance test) I am sure on the correct shape and the fuel cap under the seat.
The 3D model is saying 8,5 liters volume, but in reality it will be one less I think.
1/ I did the shape from hand, specifically thinking about the clereance for the rear wheel.
2/ It was scanned and modified into 3D model
3/ Prototype attrape was billed by CNC machine from styroform
4/ Rear spring from the shock was removed to make a clereance for the rear wheel
5/ Finally dynamic hit and max. compression confirmed the clereance
... and here is the trailer :-)
http://www.youtube.com/watch?v=19234Jluh0E
Last three things to be solved:
a/ outflow - only spce is above the pipes...
b/ air vent - to avoid "air pockets"
c/ isolation of the pipes under the tank
Guys, pls. any thoughts, comments, recos, hints before it moves to the form production? (because it is as expencive as the bike it self.)
If all goes well the first pieces for testing will be ready in the end of Feb:-)
Rade
Old 01-12-2013, 05:56 PM   #26
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 968
That is brilliant !
My only thought is, was it a new tyre on the rear. Hopefully it is the biggest knobiest tyre you could find. You know cause if they clear, you should be sweet.
Looking forward to hearing prices etc.
Great work.
rossguzzi is offline   Reply With Quote
Old 01-12-2013, 07:48 PM   #27
Buddy_Holly
Imminent Train Wreck
Buddy_Holly's Avatar
Oddometer: 1,134
I'm kind of sure you have thought of this- but just in case- every tire is different by brand, and chain adjustments for stretch could effect where the wear is on this type of tank.
Nice work on both tanks.
BH
God is great, beer is good, and people are crazy.
Buddy_Holly is offline   Reply With Quote
Old 01-12-2013, 08:10 PM   #28
zgfiredude
Oddometer: 837
I would agree with BuddyHolly.....allowing for plenty of clearance front to rear for tire adjustments would be smart. Another suggestion would be to then reduce the overall dimension by a slight amount to allow for guaranteed fitment on all bike (would allow for KTM manufacturing variances) and perhaps to allow clearance for a Kevlar skin for further strength and abrasion resistance.
Very cool otherwise, keep it up!
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 01-13-2013, 05:32 PM   #29
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 838
two thumbs up on the concept. 2.5 gal would do nicely on the big twin. Beats pulling over and re-fueling with the roto pax! now just imagine this tank with rally tanks!
-Chrome don't getcha home, but carbon fiber sure is fancy
2005 KTM 950 Adventure - back from the dead, totaled.
2005 Yamaha YZ250F - low compression, because race bike
1989 Yamaha TW200 - clapped out from a tweaker
1978 Batavus 48 - back from the dead. Parked since 83'
MrSandman818 is offline   Reply With Quote
Old 01-13-2013, 10:56 PM   #30
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,397
Keep going bigger picture...
With the talent and resources you seem to have, why not go all the way and make a full subframe that incorporates a rear tank as well as rear rally side tanks?
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Times are GMT -7.   It's 05:01 PM.
